Tie Rod and Drag Link Material for HySteer - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-21-2010, 06:34 AM   #1 (permalink)
jtaco1's Avatar
Member # 34250
Send a message via AIM to jtaco1
I am getting ready to order up material for my tie rod and drag link. I already have a set of hysteer arms from a vendor. I plan on using heim joints instead of rod ends. Also, down the line I would like to possibly reuse the heims on the Dana 60 I have sitting in the corner, so that may play into the size of the material.
What size material and heims would you recommend?
88 4 Runner, dual cases w/ 4.7's, Tacoma E-locker rear, 37" PB Rockers and no lift, caged
jtaco1 is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 10:35 AM   #2 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
1.5" 1/4" wall dom with 3/4" heims.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 11:55 AM   #3 (permalink)
jtaco1's Avatar
Member # 34250
Sounds good, that is what I have been coming up with.
Old 12-21-2010, 07:04 PM   #4 (permalink)
Member # 20957
Send a message via Yahoo to Hyena
yes
Old truck
Jimmy's 4X4
Hyena is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 07:18 PM   #5 (permalink)
Mall Crawler
Edisonsteve's Avatar
Member # 46928
Send a message via Yahoo to Edisonsteve
Dom
I used a Stock tie rod with bungs welded in and 1.5 DOM slid over it.
1994 Toyota Extra cab, Exo, SAS, Linked, Kings, Air Bumps, 60s, 5.38, Detroit/Detroit, 40"MTR, Supercharged 3.4 5vz V6, A340F Auto Trans Manual shift, Atlas 4.3 4spd, Winch front and rear. CA smog legal and DD
2012 Jeep Sahara Unlimmited 4" lift 5.13 37s
2005 Dodge 2500HD Cummins 4x4 35s
Edisonsteve is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 07:23 PM   #6 (permalink)
Member # 107112
if your going to be running the truck on road at all and have to pass any type of inspections you will need to run a safety washer on top of the hiem or run a double shear type connection. safetywise i would run atleast the safety washer just in case the heim decides to explode on you.
lude and rude is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 07:29 PM   #7 (permalink)
Member # 20957
I have never ever seen a heim explode.
Old truck
Jimmy's 4X4
Old 12-21-2010, 07:31 PM   #8 (permalink)
Member # 100827
X2 on this but if that heim gives up And pops apart. You will lose control.
Old 12-21-2010, 07:44 PM   #9 (permalink)
Member # 20957
the only times i have seen a heim broken are either the shank or the body breaking at the end of the round part.
Old truck
Jimmy's 4X4
Old 12-21-2010, 08:59 PM   #10 (permalink)
Kaptain's Avatar
Member # 31353
Send a message via AIM to Kaptain
His is a trail only rig so he's good. Good to see you finally cutting off that IFS, JT
Rusted 93 X-cab on bald 37's
Kaptain is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 11:04 PM   #11 (permalink)
Mall Crawler
Member # 46928
if your going to be running the truck on road at all and have to pass any type of inspections you will need to run a safety washer on top of the hiem or run a double shear type connection. safetywise i would run at least the safety washer just in case the heim decides to explode on you.
I have had a few tie rod ends brake and come off but in 25 years of wheeling have only ever broke a heim but never had it just come apart. But it sill isn't a bad idea anyway.
Old 12-21-2010, 11:48 PM   #12 (permalink)
Member # 175915
But what about DOT inspections? You can pas with Heim joints? Who sells these safety washers?
1979 Toyota w/ '83 22RE,1994 Fuel injection/emissions system, Duals (marlin A)
1994 Volvo 854 Turbo
slo854T is offline   Reply With Quote Quick reply to this message
Old 12-22-2010, 06:14 AM   #13 (permalink)
jtaco1's Avatar
Member # 34250
No inspections for me, tires stick out 5" past body, no roof or windshield only tube
The IFS is staying for a little while longer since I didn't get out enough with it last year, may weld the front over the winter to see if it can handle it, then the Land Cruiser axle will be waiting to go in once it blows. Or say the hell with it and drop the 1 tons in that I just picked up
Old 12-22-2010, 06:23 AM   #14 (permalink)
Kaptain's Avatar
Member # 31353
Aww come on... you don't need tons, you can't even break the IFS
Old 12-22-2010, 09:41 AM   #15 (permalink)
Mall Crawler
Member # 46928
DOT inspection? When and why would need a DOT inspection in CA? I smog my truck every 2 years and thats it.
Old 12-22-2010, 09:57 AM   #16 (permalink)
DWT
DWT's Avatar
Member # 19850
You want a BEEF tie rod and drag link? PM Bunk about solid CroMo cut and tapped to your needs. Tell him Trashy sent ya.
That's all I'll run on my junk, had one on the old yota axles and now on the 60 I'm more worried about the 3/4x5/8" CroMo heims and grade 8 bolts than I am about that tie rod.
'89 auto x toyota pickup, most fun I've ever had with my clothes on.
Taiwanese Garbage should stay in Taiwan.
DWT is online now   Reply With Quote Quick reply to this message
Old 12-22-2010, 10:05 AM   #17 (permalink)
Shane_C's Avatar
Member # 42934
Send a message via AIM to Shane_C
X2. Bunk made my lowers and mini tie rods for my double ended ram. When I did my stuff, Bunk recommended using a 3/4" x 7/8" heim.
Shane_C is offline   Reply With Quote Quick reply to this message
Old 12-22-2010, 10:11 AM   #18 (permalink)
DWT
DWT's Avatar
Member # 19850
He says he owes me another tie rod for hauling some tires for him so the next one will be 1 1/2" solid so I can step up to a 7/8" shank. The tow rig will get the old stuff.
Old 12-22-2010, 10:40 AM   #19 (permalink)
crash's Avatar
Member # 1588
My rig has a tie rod that bunk did along with a few other rigs I have done.
Mike Crash Kash
Old 12-22-2010, 10:44 AM   #20 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Heims (rod ends) are not DOT approved which means nothing in California, we do not have inspections. However, if a cop pulls you over and notices them they can have your vehicle impounded for un-safe vehicle, you pay all costs. Now you are going to say "most cops would not know the difference" which is true except the CHP, they know their shit. If you are in a MAJOR accident and your steering breaking causes it, and they inspect you could be found at fault for unsafe vehicle.
Now with all that said I have never been hassled as I drive down the road in my bead locked, full hydro, heim jointed rig in California-------------YET.
Old 12-22-2010, 10:48 AM   #21 (permalink)
Tech Editor
Air Ride's Avatar
Member # 1656
We have a bunch of 1-1/8 solid 4130 heat treated rod. Makes great tie rods, your axle will bend first. We also have some 1-3/8 heat treated 4130.
camo is my hero, even if he is gay
Air Ride is offline   Reply With Quote Quick reply to this message
Old 12-22-2010, 10:51 AM   #22 (permalink)
Roc Doc's Avatar
Member # 20631
If you're running hydro assist or single-ended full hydro, that's the minimum going in spec's as far as I'm concerned. I taco'd a tie-rod in BFE, and I don't tend to push my assist very hard. Moab 4x4 made me a new one that's been holding up just fine, but a buddy had one go south on his full hydro rig over Thanksgiving. I think the heim spec is fine as long as they're high quality, but a bigger diameter tube would be stronger, obviously.
Or you could just truss it like we did!
Pussy!
Suck it up buttercup, pirate takes care of its own. Even when they are post whoring retards!
Roc Doc is offline   Reply With Quote Quick reply to this message
Old 12-22-2010, 11:24 AM   #23 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
That is not saying much, considering it is a Toyota axle----LOL
Old 12-22-2010, 02:41 PM   #24 (permalink)
Member # 86280
The only thing I can say as far as size goes, I would reccomend a 7/8 bore heim. I say this Because once you put in high misalignment spacers you are going to be down to a 3/4 bolt. I would want at least a 3/4" bolt holding it all together. As for material 1.5 .25 wall Dom minimum.
David D is offline   Reply With Quote Quick reply to this message
Old 12-22-2010, 02:54 PM   #25 (permalink)
jtaco1's Avatar
Member # 34250
Hopefully I can get out more this coming year than this year. Rolling the rig early in the season put a big damper on things.
Thanks for the info guys.
