Dent puller - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-13-2002, 09:33 AM   #1 (permalink)
TK
TK's Avatar
Member # 274
Send a message via Yahoo to TK
Dent puller
What is everyone doing to pull out "minor" rock dents?
Obviously I could pull off the interior panels and door panels and hammer out the accessible ones, but are there any quickie tools out there? This is something I can imagine will need to be done rather frequently, so easier = better.
Flame if you must...
Molon Labe
TK is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 09:36 AM   #2 (permalink)
Visa Master
Mutt's Avatar
Member # 8649
Pull them out , leave those beauty marks ;-)
It really depends on the type of dent...if it has a crease in it then it will most likely pull and still leave a mark, if its just a panel pushed in or a fairly large dent it may pull out with a suction puller...
Its just really dependant on how deep, the size, how you want it to look in the end, $$$$, and where it is on the vehicle.
-Steve
43" Grooved SX's, H1's, Ori's, Ord Magnum/np205, D60/D70, lq4, th400, bentfab chassis ....some assembly required...Muttlock guy
Mutt is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 09:37 AM   #3 (permalink)
Member # 3553
Send a message via AIM to FreakAccident
I dont mess with dents unless I cant drive the truck because of them. I suppose you could use a dent puller and fill the hole up with weld then repaint but that would be a pita. Go to the paintless dent people and have them fix them or learn to do the paintless dent thing yourself.
13 years?
FreakAccident is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 09:40 AM   #4 (permalink)
TNToy's Avatar
Member # 5776
  • Punch out the acessible ones from rear. MUCH easier than from front.
  • Plunger coated with vaseline for a strong seal can suck out big, shallow ones.
  • Paint it flat tan or green so the dents hide better. That's what I did. Easy touch up w/ a $3 can rules.
  • Build a flat bed
  • Build a tube buggy
Also, simply learn to live with them. When you dent the truck the steel is actually stretched. So unless you're a master body man who does this for a living, it will never look stock again.
But that's all right. Now you can run the trails where you have to potential to drag the side of the truck down something without fear.
Old 11-13-2002, 09:40 AM   #5 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
Re: Dent puller
i suggest you use a big rock and turn that "minor" rock dent into a major bash so we don't think you are such a pussy.
Millennials, making hippies look tough since 1980
camo is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 09:44 AM   #6 (permalink)
TK
TK's Avatar
Member # 274
This truck will never be straight! Just looking to fix some of the easy/huge ones, and if there is an easy way, why not?
I'm not worried about getting it perfect in any way. Just trying to keep the heap looking roughly like a 4runner until the body can no longer hold itself together.
Molon Labe
Old 11-13-2002, 09:48 AM   #7 (permalink)
TK
TK's Avatar
Member # 274
find a straight panel...
Molon Labe
Old 11-13-2002, 09:49 AM   #8 (permalink)
TK
TK's Avatar
Member # 274
Molon Labe
Old 11-13-2002, 10:24 AM   #9 (permalink)
Booger Weldz's Avatar
Member # 2931
when i bought the canback i had to fix some areas of my body where it mounted in order for it to fit(seal) up. you gotta pull the interior panels, then youll be amazed at how "straight" you can get everything with just a couple of wacks
color="lime">
Ducati street fighter 1098s. Spoiled 1wd.
Booger Weldz is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 11:55 AM   #10 (permalink)
Banned
4RnrRick's Avatar
Member # 3933
I know what you mean.
I just pull the inner panels and use a 2x2 piece of wood and a hammer. sometimes I also just use a long pry bar. I don't mine dents or ripples but if they are esy to pop out, then thats what I do. Also in the terrain I normally drive, I don't get much rock rash. I just want to keep the rig looking pretty good from 30 ft away. and rattle can is the best paint job any real 4x4 can have!
4RnrRick is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 12:37 PM   #11 (permalink)
RE:Todd's Avatar
Member # 422
Cool
This is what I have my 16 yr old do .
Todd Steele
TINBENDERS
Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper.
RE:Todd is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 01:07 PM   #12 (permalink)
Man Child
Priest's Avatar
Member # 2175
You just need to move to a different neighborhood where you can blend in better....
Dream big
Work hard
Don't be an asshole
Priest is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 01:18 PM   #13 (permalink)
BlueYota's Avatar
Member # 14544
Sheet metal screw and a slide hammer
But I do agree with the rest of the guys, if its never gonna be straight, than screw it, so long as you have a level mouting surface for you top. The pics dont look bad at all from where I`m standing, at least no ones gonna steal it
Its not rust til you can see through it.
85 Toy mini, Marlin Hysteer, u-bolt flips, 5.29s f/r, long travel shafts, 5" lift w/ unkown leaves, rebuilt top end
Next Project: fix the bed, and fix my open diff. situation.
BlueYota is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 01:48 PM   #14 (permalink)
TK
TK's Avatar
Member # 274
I've added... uh... a "few" since those pics. LOL
Molon Labe
Old 11-13-2002, 05:31 PM   #15 (permalink)
Member # 5561
If the panel just got pushed in, then the suction cup things can usually put it back out. But if the metal was creased, they wont help much - might make the dent more shallow, but it will be just as noticable. There is no quick easy way to straighten creased body panels unless you have easy access to the back side, so, just look at them and smile
Maybe just paint the dents with flat paint - soon enough you'd have a nice camo paint job with the patern determined by nature
dknightd is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 08:41 PM   #16 (permalink)
splatt's Avatar
Member # 6557
sheet metal sucks,
cant wait to get rid of mine
trail plug under construction
splatt is offline   Reply With Quote Quick reply to this message
Old 11-13-2002, 10:47 PM   #17 (permalink)
Member # 3132
I don't get them little small dents. When I do get a dent I cut it off. except my roof rockers and doors
Old 11-14-2002, 10:22 AM   #18 (permalink)
Member # 2931
this thing looked like crumpeled tin foil up close but the flat paint hides a lot like dknight said
color="lime">
Old 11-14-2002, 11:09 AM   #19 (permalink)
JW
Member # 222
I would recomend scraping off the 1/8" of rust off the panel before you try to pull and paint.
"See that double? Do that double!
If you start thinking about it, you'll never do it. People who think too
much end up living longer, making more money, vacationing in Tavarua,
marrying wisely and investing well-but they don't clear as many doubles."
budbuilt.com & highangledriveline.com
JW is offline   Reply With Quote Quick reply to this message
Old 11-14-2002, 12:38 PM   #20 (permalink)
TK
TK's Avatar
Member # 274
it is 1/4"! don't shortchange me
Molon Labe
Old 11-14-2002, 05:12 PM   #21 (permalink)
4x4Search's Avatar
Member # 7732
Send a message via AIM to 4x4Search
Lots and lots of bondo.
Loren
- '88 4Runner. SAS, locked, 5.29, 4.7, winch, 35" MTRs
- '02 Reg Cab F250 XLT, 4x4, 7.3L, 6SPD, LOUD!
4x4Search is offline   Reply With Quote Quick reply to this message
Old 11-14-2002, 07:07 PM   #22 (permalink)
Member # 4666
most whate till after damage to do XO do it befor it it so nice to scrape along rox and trees and not care about the body i do not beleave the [ chics dig dents] i have never heard a hotty say ha there, ugly truck wont to take my home chics dig nise trucks jm.02
Vincent
toy 4 rox is offline   Reply With Quote Quick reply to this message
Old 11-14-2002, 07:13 PM   #23 (permalink)
Member # 4666
Vincent
