Exhaust manifold glows red hot after 3 min of driving...WHY - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-04-2011, 12:43 AM   #1 (permalink)
Member # 126047
Its a new crate motor I pulled from an 83 pick up I got to part out. Tapped and threaded a knock sensor in and put it in my 87 EFI 4runner. the truck had no major issues before besides the starter would stick sometimes.
I have checked the fuel pressure, the AFM, the TPS sensor, new O2 sensor, the timing is on and TDC, the coolant temp sensor, No vacuum leaks, new fuel filter, new plugs and wires, intake plenum is super clean.
It runs good has a slight hick-up or hesitation at very slight throttle but pulls good at half to full throttle I'd say.
Why is the exaust glowing after such a short time. I mean its glowing from well above the o2 sensor all the way down past the flange and into the single pipe. Over a foot in length of glowing metal after a trip around the block.
Is it really that lean? Why?
Ill get a pic of it tomorrow night.
Unil then please help. What do i check next
Toyota Parts Heaven... davezoffroadperformance.com
Cody3570 is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 12:58 AM   #2 (permalink)
Member # 95146
Well, been my exp that the only way to get exhaust temps that hot is to run way lean. It would almost have to be a vac leak to get that lean. Is it hard to start? If so, does it fire right up if you step on the gas? These are telltale vac leak signs.
losiripper is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 01:07 AM   #3 (permalink)
Member # 126047
its not hard to start but somesimes it wont start first crank but seccond.
I sprayed the shit out of all the lines with starting fluid and no changes in idle
Ill have to try it again
Old 02-04-2011, 03:17 AM   #4 (permalink)
Member # 1860
my buddies rig did that when the egr valve was plugged with carbon.
cleaned it out and it stopped glowing.
the more i play with it, the bigger it gets...... my truck that is
derek is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 05:21 AM   #5 (permalink)
GRW
Member # 9515
A friend did a rebuild and after putting it back in it did the same.
The timing was off just enough (he said said his was dead nuts on to).
Just a thought, double check everthing (to the manual).
Gary :)
GRW is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 06:57 AM   #6 (permalink)
FuzzyZ's Avatar
Member # 117547
long shot. but check for a pluged cat converter also. could cause this but id doubt it. sounds fuel mixture related to me.
86 4Runner, 02 TJ, 02 GMC 2500HD
Trailbusters4x4 club Solano County
ECV 1004
KM6KZI
FuzzyZ is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 07:02 AM   #7 (permalink)
Member # 144756
Um pretty sure its to rich not lean. Mine did this after i installed a weber, rejeted it and adjusted the timing some and it stopped.
hijack is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 07:07 AM   #8 (permalink)
Member # 126047
Thanks for the imput fellas. Keep the suggestions coming(long shot or not)
Ill pull the EGR and check the CAT today. And tripple check the timing.
Thanks again cause im stumped
Old 02-04-2011, 07:47 AM   #9 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
Send a message via AIM to jhama78
the timing is probably retarded and firing after the exhaust valve is already starting to open....
two things tell me this...
1. it doesnt rev freely
2. exhaust manifold is glowing.
-j-rOd
wear life like a loose garment
84 Toy Farm Beater
85 Toy SR5 xcab DD
86 GMC K1500 SWB
88 4Runner Fambly Beach Ride
11 Tundra Double Cab Rock Warrior
jhama78 is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 08:45 AM   #10 (permalink)
Member # 163057
oops
laskt9 is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 08:47 AM   #11 (permalink)
TOYOTAPARTS's Avatar
Member # 61493
Like said in a few posts.
burning fuel is coming out of the exhaust ports causing the manifold to be too hot. Rich running condition: vac leaks, leaking or stuck injectors, retarded timing will cause late ign timing and cause burning combustion to exit too early.
Just try advancing the dist to see if it helps.
Great deals on Toyota Parts: :
RCV 30 Spline axles FREE shipping.
Yukon parts on SALE
3rd Members priced right. 530-622-2148
for all your electrical needs
TOYOTAPARTS is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 03:31 PM   #12 (permalink)
Member # 172763
It was timing...
So I think there is a timing gremlin that lives in my motor. I had the timing perfect. then i tuned and fixed a few things a never checked it again. always check timing after any mods or fixes i guess.
Thanks for all the advice.
Jeff or Steve
DEALERS FOR : MARLIN CRAWLER, INCHWORM GEAR, POWERTANK, ORI STRUTS & Metal Cloak
GoldenState M-sports is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 04:54 PM   #13 (permalink)
Member # 61493
Have fun at KOH
Yukon parts on SALE
