#601 (permalink) |
Member # 208176
Thanks. Most of it is 1.75" .120 wall HREW. The bracing right behind the rear window is 1.5" .120 wall HREW.
GASP!!!! I didn't use DOM!!!!!!!
If you can't fix it with a hammer, you've got an electrical problem |
#602 (permalink) | |
registered user
Member # 134734
finally got it back together enough for some pictures (rolled it and smashed the front before i got the cage done) ![]() ![]()
#605 (permalink) |
107
Member # 39660
Buddy came to help and did most all of it in 2 days. It's pretty tight all over the place, I'm really happy with it. All she needs is 2 roof spreaders finished and then final welding. Also need to incorporate the rear shock mounts and maybe get some new shocks to utilize the room as well as front shock hoops and their cage tie ins. I'll also be incorporating a rear spare tire tailgate deal. All in all, about 100' of 1.75", part of a stick of 1.5" and then the 1" windshield spreaders, all .120 DOM.
Big Boned Toyota Build The collective writing skills of the PBB is equivalent to a blind down syndrome-afflicted monkey with no hands and epilepsy. |
#608 (permalink) | |
Member # 21990
I'd like to see more pics of the back when its finished!
Rory Huber Photography, KI6TLV DJ Rockalot Mobile Sound & Lighting Creation Nonstop web/graphic design Sierra Treasure Hunters 4wdc my '82 Toy fabed w/help from 4x4Beast Fabrication |
#609 (permalink) |
Member # 21990
Nice minimal flatbed. With the tight fit on the spare you could forgo a mount and use air pressure i.e. build to fit w/no air and then air up to make it fit tight!
#612 (permalink) |
Mooseknuckle OG
Member # 139159
Look closer there's hinges...
"You break on the trail, You BECOME the trail!" - drunk guy MY BUILD http://www.pirate4x4.com/forum/showt...083&highlight= |
#614 (permalink) |
Member # 208176
Even with hinges, I'm guessing you can't be in a hurry to exit the vehicle? Hope it never catches on fire!
#615 (permalink) | |
Member # 81334
"Chrome won't get you Home" 85 Yota Sittin on 38.5 Sx's and a whole bunch of du-dads... |
#616 (permalink) |
Member # 22506
If the window is down, I can get the door open in just a couple of seconds.
94 4Runner with Cummins 4BTA diesel, 700R4, Unimog 421 Axles, Link Suspension, 46 Claws, STaK 3spd. |
#617 (permalink) | |
Member # 208176
Nice. Do you have a build thread or the 4bt swap?
#618 (permalink) |
Member # 22506
Here is my build thread Unimog Axled 4Runner
#619 (permalink) |
Here is mine,
All 1.75 .120 wall DOM except for the bracing which is 1.0 .120 wall DOM Overall I am happy with it, still need to add harness bar and a few cross supports in the back half area. ![]() ![]() ![]()
Richard -- NMTTORA Pres. 02' Tacoma SR5 DD, 89 4Runner SAS |
#621 (permalink) |
107
Member # 39660
How much up-travel do you have? Seems like you could have gotten a lot more if you mounted those shocks a little higher?
#625 (permalink) |
Mooseknuckle OG
Member # 139159
I highly doubt he has a whole foam on his truck, maybe a build thread
