Transfer Position switch - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-21-2011, 02:50 PM   #1 (permalink)
Member # 87514
Just picked up a 1994 4 runner with a "screwed tranny"
inspected the tranny, all is fine, threw her in 4 low, and i can drive it, however 4high and 2wd dont move at all.
Been searching around all day, does it sound like a transfer position switch?
No metal in the tcase fluid or anything, no grinding, sure seems like a sensor
crazy_mtb_2002 is offline   Reply With Quote Quick reply to this message
Old 03-21-2011, 03:13 PM   #2 (permalink)
Member # 93619
If the parking pawl does not hold, the high range is blown. In that case your best bet is to replace the trans/t-case assy.
SoCalWheeler71 is offline   Reply With Quote Quick reply to this message
Old 03-21-2011, 03:59 PM   #3 (permalink)
Member # 87514
It does hold, just pulled the transfer position switch and ohm tested, getting a reading on low and high 4, but nothing on 2, which going by the diagram i found it doesn't show anything reading wise on 2, so it looks like the switch is fine.
Tranny shifts perfectly thru all the gears in 4low, but not the others
at first thought i figured high range was blown
Old 06-11-2011, 09:30 AM   #4 (permalink)
Member # 192353
Transfer indicator switch - where is that puppy?
Ditto for me. But where the heck is the transfer indicator switch?!? I can't seem to find it!!!
sunonomo is offline   Reply With Quote Quick reply to this message
