Valve cover to cam sprocket/timing chain clearance issue, wtf?! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-28-2011, 07:15 PM   #1 (permalink)
Member # 153254
Ok so a first off, I searched a ton already and came up with nothing. Next a lil background to the problem, I'm currently swapping my block (22re), due to a gouged up 4th cylinder with the block from my parts truck. So I put all my accessories, and head and timing cover and timing set, pretty much everything from my old engine onto this block.
Now 2 nights ago I'm buttoning it up and putting the valve cover on and notice that its not sitting down completely in the front of the engine. So I take it off and see its rubbing on the timing chain and cam sprocket. What the Hell? Im pretty sure it wasn't doing that b4. So I tried swapping the valve cover with a spare, same problem. The oem rubber gasket sits about 1/16 away from contacting the head. Nice and squashed though at the back of the valve cover.
Thinking that its perhaps my heavy duty aftermarket single row timing set I measured the parts engine chain around its sprocket with a vernier, same as mine, 115mm.
Anybody out there come across this or got any ideas? I'm really scratching my head here, and just wanna get back out on the rocks, thanks in advance guys!
Carter.S is offline   Reply With Quote
Old 03-28-2011, 09:03 PM   #2 (permalink)
Member # 64089
Send a message via AIM to 800MJ
its hard enough to get the cam sproket up onto the shaft alone, i donno how you can have it up so high that the valve cover is hitting it. can we get a pic?
[QUOTE=roastbeef;10323284]last night, this girl was sucking my dick and she stated licking my balls and then she starteld likcing my ass. i almost nuttd right on top of her fucking head before i got to stick it in her.
im drunk.[/QUOTE]
[QUOTE=sucker;10784484]ok straight six and reliable don't go together. But have fun with that one.[/QUOTE]
800MJ is offline   Reply With Quote
Old 03-28-2011, 09:14 PM   #3 (permalink)
Davez Off Road
TOYOTAPARTS's Avatar
Member # 61493
Sounds like you swapped everything from an 85 up to an 84 down engine,
Great deals on Toyota Parts: : http://www.davezoffroadperformance.com/
Most Trail-Gear parts FREE shipping.Yukon parts on SALE
3rd Members priced right. 530-622-2148
for all your electrical needs http://www.12voltguy.com/
WIN a fully built Toy p/u http://www.pirate4x4.com/forum/toyot...toyota-pu.html
TOYOTAPARTS is online now   Reply With Quote
Old 03-28-2011, 09:37 PM   #4 (permalink)
Member # 153254
I know man its driving me nuts, I don't know how this is even possible. What can I even take a pic of for you though?
Old 03-28-2011, 09:40 PM   #5 (permalink)
Member # 153254
I highly doubt it man, was a 91 2wd ext cab that I sasd, and now using a 91 4wd block, and they looked like the original engines for the truck.
Old 03-28-2011, 09:47 PM   #6 (permalink)
NATER623's Avatar
Member # 132507
Double check your cam sprocket isn't on backwards. I can't remember for sure if they're symmetrical.
ECV-1846
NATER623 is offline   Reply With Quote
Old 03-28-2011, 09:55 PM   #7 (permalink)
Member # 153254
Ok Im pretty sure I remember that it only had the dimple for timing on one side, but ill double check, keep em coming guys and thanks for all the input so far.
Old 03-29-2011, 08:00 AM   #8 (permalink)
Brian Ellinger's Avatar
Member # 1088
It is a single row chain, not double? Double wont fit in later valve covers without some work. Otherwise, maybe the cam gear is not completely on the cam, and is too far forward?
Just to be sure, both these engines were running fuel injection, and the intakes were bolted on with bolts in every hole, intake to head?
Thank you to our loyal customers!
Diamond Axle
http://www.diamondaxle.com
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
http://www.frontrangeoffroadfab.com
NEW BUILD FTOY #44
/forum/toyota-formula-toy-forum/562295-front-range-builds-new-toy-old-toy-44-a.html
Brian Ellinger is offline   Reply With Quote
Old 03-29-2011, 09:06 AM   #9 (permalink)
Davez Off Road
Member # 61493
was just a thought, I just got a 2wd 91 with an 84 engine in it
But I cant see on any of our engines how the valve cover could hit, is the baffle bent?
Old 03-29-2011, 10:10 AM   #10 (permalink)
Member # 50177
Like Brian said, the double row timing chain setup will not fit with a late style valve cover. Maybe your wider single row timing set is causing the same problem. I know that when I went to a double row timing chain I had to get an early style valve cover. In case you don't know the first pic is the early style and the second pic is the late style. It seems kind of backwards but the one with the sloped front actually has more room inside for timing chain clearance.
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More
www.MayhemMetalWorks.com
________________________________________________
05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy
my buggy build
http://www.pirate4x4.com/forum/showt...e33fc&t=488938
am4x4 is online now   Reply With Quote
Old 03-29-2011, 10:51 AM   #11 (permalink)
Member # 19077
This would make no difference as far as his problem is concerned. Deck height would not change the cam gear to valve cover clearence as its set by the center line of the cam, and the cam gears are pretty much all the same diameter.
It has to be something stupid that is being overlooked. I know it sounds stupid but is the head torqued? Rocker assy completely seated? No tools or vacuum lines in the way? Are you positive that its actually the cam gear making contact? Can you post pics?
yotamasters.com <-------- NEW WEBSITE IS HERE!!!!!
Max Volume is offline   Reply With Quote
Old 03-29-2011, 11:14 AM   #12 (permalink)
Davez Off Road
Member # 61493
I was thinking of the two row chain from an early which does not clear a late valve cover.
Old 03-29-2011, 12:50 PM   #13 (permalink)
Member # 153254
yep its definitely a single, i made sure to specify that, as i came across that in my searches. pretty sure its sitting far enough forward, ill double check, but i did torque the bolt and dizzy gear on there, and looked forward enough.
both engines were running, and were efi. ummm my intake isnt mounted though yet. the engine is on a stand and the intake is still pushed to the side in the truck, should this matter at all though?
Old 03-29-2011, 01:02 PM   #14 (permalink)
Member # 153254
nope doesnt look bent, if anything bent in a little from the contact. also tried the parts engine valve cover, it also was hitting on the baffle.
Old 03-29-2011, 01:05 PM   #15 (permalink)
Member # 153254
ya no its the square style valve cover, the newer style. i dont think my heavy duty set has a wider chain or sprocket, i think they just call it hd because of the steel backed guides.
Old 03-29-2011, 01:11 PM   #16 (permalink)
Member # 153254
head is all torqued down, with arp head studs, all are tight i tripple cheched. im pretty sure rocker assembly is all seated, but ill double check tonight. nope no tools, or vac lines in the way. its definitely the cam gear, there are clear marks from the chain contact on the baffle in the cover.
Old 03-29-2011, 07:10 PM   #17 (permalink)
Member # 1138
If there are any threads from the stud protruding past the nut, then the stud is hitting a rib on under side of the valve cover. This usually happens with the front two studs and the two rear studs. You can either remove the suds and shorten the end that goes into the block or grid the ribs off the inside of the valve cover. Not musch grinding required either way.
OBAMA
One Big Ass Mistake America
incontrol is offline   Reply With Quote
Old 03-29-2011, 07:47 PM   #18 (permalink)
Member # 153254
I wish that I had checked this thread before I got home, I just finished figuring this out for myself. Ya the front 2 studs are hitting that rib or webbing I was gonna call it. I sharpied the area where the chain marks were, and there was no shiny new marks coming coming thru the marker paint, so I started looking elsewhere and that is it. I'll take the carbide bit to those ribs now.
I immediately dismissed it being the arp studs cause I figured if it was hitting any it would be hitting all. I now assume the marks on the valve cover were from the a sloppy chain when the guides broke a while ago.
I also didn't relate it to the studs, cause I guess I didn't notice the problem when I installed them. (which wasn't long ago, I put em in when I replaced the headgasket, thinking that was my coolant and exhaust mixing problem, but it was the block)
Well thanks to all for your help, I can't believe I didn't hear about this when I put the studs in originally, I mean its a pretty common mod I think. Arp should really have a note In the box, maybe this should go in the faq too?
Old 03-29-2011, 09:00 PM   #19 (permalink)
Davez Off Road
Member # 61493
wow, I have never had that problem, I guess we will stick with our head studs.
Old 03-29-2011, 10:20 PM   #20 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Send a message via AIM to steveh
Glad the OP got it figured out!
Hmmm Dave, my Late model with the dual row conversion, square VC, fits fine !!! ...
85 Toy Xtracab
"I DON'T want to understand !!"
Click here to donate to the Rubicon Trail Foundation
"Wow this is unbelievable"
2013 Cantina for the 'Con supporters!
WIN a fully built Toyota pickup at Cantina 2013
Davez Off Road and Trail Gear are supporting Rubicon Trail Foundation
We have returning Platinum sponsors for Cantina 2013 with Raceline Wheels and Falken Tires!!
steveh is offline   Reply With Quote
Old 03-30-2011, 07:40 AM   #21 (permalink)
Davez Off Road
Member # 61493
I would guess the valve cover is modified?
Old 03-31-2011, 09:34 AM   #22 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Could be, In fact, I bet your right, heck, I know your right. I'll ask Tim next time I talk to him what he did.
85 Toy Xtracab
Old 09-30-2011, 01:24 PM   #23 (permalink)
Member # 168396
I'm dealing with this issue right now on an 84 engine with double row chain. Sure would love to know what others have done to the baffle inside that square cover!
helidaddy is offline   Reply With Quote
Old 09-30-2011, 01:44 PM   #24 (permalink)
94toytruck's Avatar
Member # 18614
IIRC the front baffle was very easy to remove and isnt a issue. I removed mine when I did a double row set on my old motor. I checked it before and it did hit and wouldnt sit flat.
Eric
www.rightcoast4x4.com www.dazednconfuzed.net www.atozfabrication.com www.alltechmotorsports.com www.davesoffroadsupply.com
Originally Posted by FLEXYSAMMY View Post
Yes you are correct Eric.
94toytruck is offline   Reply With Quote
Old 09-30-2011, 06:46 PM   #25 (permalink)
Member # 168396
Well, I just removed the oil filler part of the baffle... grinded the spot welds off. If I were to do this again, I would use another method because it made a mess inside the cover. Good thing I have a solvent tank!
