Member # 160632
Easy disc brake conversion
Ok Guys, Not sure if anyone else has covered this in this manor but I want to look at a new option for EASY disc brake conversion. This was on my offroad buggy. (91 Truck)
![]() ![]() ![]() So. I went to autozone and purchased 2001 montero sport rotors 4wd, REAR. they have 180mm centers and 6 on 5.5 and fit PERFECTLY. You can use the same vehicles calipers from junkyard as well. Or Isuzu trooper or Pathfinder/Montero Sports. We took 3/8" plate set our pattern for axle tube bolts and made a quick measurement for ride height on caliper retainer, cut the steel, drilled it and shimmed it out for center of rotor using washers. WALA I have $85 and 2 hours in rear disc brakes. BTW.. No brake line adapters needed. These calipers were double flare also like Toyota (I used nissan pathfinders 1994 rear) Step By Step: Pull axle from truck Remove all mechanics from old drum brakes. Pull all 4 axle retaining bolts on each side. Slide individual axles loose and setup to cut with plasma or torch. You will need water or a thermal brake liquid OR you can totally dissasemble the axle to protect bearings/seals. (Or you can take your chances).. Cut backplate tight around axle flange (where 4 bolts are) Re-install each axle ONLY putting nuts on the bottom 2 bolts. Remove top 2 bolts (using a hammer pound studs out) Go buy you some 2 1/2" grade 8 3/8" bolts, lock washers, and nuts. Also buy an assortment of flat washers (needed to shim) Stick a bolt in each of the top 2 holes with the bolts going towards the center of axle. (tack welding the bolts to axle flange is easiest) Cut a piece of 3/8" Plate to hold caliper retainer over rotor (From memory I believe the top spread for caliper was 5.125", spread on axle flange was 3.5 and they were on an angle seperated by 2.25" center to center. You are going to need to cut an arch in the plate for the axle tube and an arch on top for the caliper to drop basically making a "H" shape. Installing the plate to the back of axle flange using a small stack of washers for shiims. I beleive it was 3 washers totally 3/16 to 1/4" which centered it perfectly. Then place plate, lock washer and nut. Install rotor to axle. (2001 Montero Sport 4wd Rear Disc rotor) Install Retainer using bolts from junkyard donor. Install caliper and connect brake hoses. (using flexible hose from junkyard donor connect to hard line from drums) Wala - Bleed and enjoy.. Disc brake conversion done for less that $100 !!!! Last edited by isophase; 04-03-2011 at 04:42 PM. |
Do these include a provision for a parking brake?
GET INVOLVED - Join the Blue Ribbon Coalition SIGN THE PETITION - SAVETHEHAMMERS - #85 '93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K '85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild) |
White Trash Fab
Pic with a 15" wheel to show clearance?
"If you are gonna live life on the edge you better have good balance" 06 Tundra DC The "Trifecta" 3 seat yota buggy ![]() http://pirate4x4.com/forum/showthread.php?t=1027210 http://www.AddictedOffroad.com/ www.ruffstuffspecialties.com http://f-o-a.com |
White Trash Fab
Sweet, good tech.
Except it won't pass anywhere where you need a parking brake for inspection. Looks like a pretty good setup for a trail rig, though.
#12 (permalink) |
Shifting for all
Member # 68266
Swaps
This is awesome info, this proves there is still a few of the researchers and builders out there that can contribute. Thanks.
RADesigns Products LLC - Shift to the Best The 2nd Amendment is not to be screwed with, I am a card carrying member of the NRA. If this offends you please don't buy my products. http://radesignsproducts.com/Accessories.html Jeep, Toyota and Nissan automatics, Shift controllers and shifters, Toyota Triple Stick levers! My stuff: /forum/toyota-truck-4runner/996438-2rz-82-w-a340-duals-radesigns-way.html John 3:16- He is the answer. |
#13 (permalink) |
does the stock master cylinder push enough fluid for these?
[QUOTE=roastbeef;10323284]last night, this girl was sucking my dick and she stated licking my balls and then she starteld likcing my ass. i almost nuttd right on top of her fucking head before i got to stick it in her. im drunk.[/QUOTE] [QUOTE=sucker;10784484]ok straight six and reliable don't go together. But have fun with that one.[/QUOTE] |
#14 (permalink) |
Member # 160632
My truck is the IFS MC with the 1" Bore. Although not tested im expecting it to be fine.. BUT I will let you know if this isnt the case. Worst case scenario, JUnkyard and a 1 ton chevy MC.. Fabricate the adapter..
#16 (permalink) |
Member # 152631
one thing to add you say pull axels loose i hope you pulled the entire axel out of the tube and did not just let it hang half way out this will ruin the axel seal and it will now leak when you drive the truck again just a heads up for anyone else doing this swap
R.I.P Derek James Black 1995-2010 I miss you BUD! |
#17 (permalink) |
Member # 32726
great tech. This looks like the way to go....
this needs to be in the FAQ
5/8 Yotabuggy - duals + 4.7, 5.29's, locked, 40's, linked rear/fox airs, shift knob ΜΟΛΩΝ ΛΑΒΕ |
#18 (permalink) |
Member # 187757
I started on this setup a few years ago, but never finished. If I recall correctly, my wheel studs (90rear axle) had a shoulder on them that required me to drill out the Montero rotor lug holes to the next size up. No big deal, and only took a few minutes for both rotors. I believe I also tried the Isuzu calipers, and they hit my 15" wheels. My wheels are aluminum, and yours appear to be steel. Basically, fitting inside a 15" wheel may depend on the wheel itself. At any rate, I'm glad you did this, as I may have to do it myself so I can use that montero rotor that has been sitting in the garage for the last few years. Oh, and by the way, Mitsubishi has a Montero Sport, and a Montero. The Montero uses different rotors that will not work. Just to restate the original post, ask for Montero SPORT rotors.
#20 (permalink) |
Member # 146049
That was a good write up. I'm glad you said to use montero sport rotors. I was going to use trooper calipers because of the ebrake. But the trooper rotors won't fit. I was going to turn the hub of my axle down slighty until the trooper rotor would fit over. I think your ideas better though.
#21 (permalink) |
Member # 160632
Ya. I have friends that have done just that.. They ended up paying $20 for the machine shop... For that and the cost of other rotors.. This is a in-out deal.. Bolts right up.
Should have my rig running in the next couple weeks.. Will let you know how well this setup is.. |
