22REC and 22RE...differences? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-08-2011, 12:16 PM   #1 (permalink)
Member # 167898
Question 22REC and 22RE...differences?
I'm currently on the market for a rebuilt engine. A fellow wants to sell me a 22REC, is this different from a 22RE? I'd like to know before I fork over a $1000 for an engine and I can't use it...
81 4x4 Pickup LB
4twnty_YOTA is offline   Reply With Quote Quick reply to this message
Old 04-08-2011, 12:19 PM   #2 (permalink)
Ronzo1989's Avatar
Member # 113904
Just typed a search in google and in another forum they said the C stands for being California emissions compliant.
"R= head design, Single overhead chain driven cam.
E= Electronic fuel injection
T= Turbo
C= California emissions compliant for that vintage
22= 22nd overall variant of that engine family. Engines in this family were in everything from forklifts to Celicas to who knows what else."
Ronzo1989 is offline   Reply With Quote Quick reply to this message
Old 04-08-2011, 12:54 PM   #3 (permalink)
Member # 118757
Does the new engine come along with the computer/harness? I believe they are different (due to the additional sensors and such). Here are two diagrams showing the differences:
22RE:
22REC:
The following link has much more information on the different flavors:
/forum/toyota-truck-4runner/579557-22r-22re-22rte-vacuum-diagrams.html
DTCsk8er is offline   Reply With Quote Quick reply to this message
Old 04-08-2011, 06:11 PM   #4 (permalink)
Member # 138976
Do you need the entire thing, or are you just getting a good long block?
To be clear, this is not to suggest that in similar circumstances, a person who engaged in this activity would face no consequences. To the contrary, those individuals are often subject to security or administrative sanctions. But that is not what we are deciding now.
- Comey on Clinton 2016
Old 04-08-2011, 08:25 PM   #5 (permalink)
Member # 167898
I'm after a long block, going to be carburated...
81 4x4 Pickup LB
Old 12-29-2016, 05:16 PM   #6 (permalink)
Member # 697993
So heres a question.... looking at getting a runner with a factory 22REC tomorrow.... Is this just more stuff to take off and eliminate, or will I need a new computer etc?
SirSasquatch is offline   Reply With Quote Quick reply to this message
Old 12-29-2016, 07:18 PM   #7 (permalink)
shoes optional
drewp's Avatar
Member # 142117
Do you care about a check engine light....if not then no...
I NEED A HARLEY SS175 PISTON!!!!!!!!!!!!!!!!Found and now its time to build a bobber
drewp is offline   Reply With Quote Quick reply to this message
Old 12-29-2016, 07:52 PM   #8 (permalink)
Member # 103782
I would worry about it as long as you have all your trucks original intake, wiring, and accessories you should be good to go as far as swapping in the long block.
-'86 runner SAS cookie cutter build....links coming soon!
-'89 xtracab mild built 22re, stock ifs with timbren bumps, 4.56s, 95 4runner front clip, fresh paint, full dynamat, clean interior, heated seats, a/c.... Nice 20mpg dd, wish it had cruise control.
iwannabemro is offline   Reply With Quote Quick reply to this message
Old 12-29-2016, 08:49 PM   #9 (permalink)
Mr Stubs's Avatar
Member # 102813
Its just more smog shit. You wont need a new ECU to run it.
Help bring back Swartz Canyon, Join
The good guys...
Marlin Crawler, Hellfire Fabworks, Dave'z Offroad, gearinstalls.com (Zuk), Diamond Axle, RADesigns, Advanced Adapters, Jantz Engineering, G-Fab motorsports, Got Propane, JHF
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 12-30-2016, 08:53 PM   #10 (permalink)
Member # 70087
EC is for electronically controlled, I believe that's how it's worded in the 85 fsm I have. That 22REC won't have any aditional smog stuff. The early California emissions efi motors actually had less smog stuff than the federal motors, based on the emissions diagrams. All have egr's, all have a catalytic converter, all have evap setup so what more does a Ca. motor have, I don't believe anything. If it's above an 87 or maybe it's 88 then you start seeing more emission stuff in general.
When I shop Napa auto parts for example, they don't have parts for RE or REC, it's either 22REC(efi) or 22R(carbureted). No question wether it's a Ca truck or federal emissions model.
lunarmist02 is offline   Reply With Quote Quick reply to this message
Old 01-04-2017, 12:41 PM   #11 (permalink)
Member # 52443
T= Turbo
A -- Valvematic variable lift intake head
B --Twin SU-style side-draft carburetors (After 2000 indicates E85 Ethanol fuel )
C-- Carburated / California Emissions Controlled
D-- Twin Downdraft carburetors
E -- Electronic Fuel injection
F-- Economy narrow-angle valve DOHC
G-- Performance wide-angle valve DOHC
H-- High compression High pressure charged (example: 2L-THE)
I --Single-point fuel injection
J-- Autochoke (Early models) or unknown pollution control
L-- Transverse
M-- Philippines' market (meaning unknown)
N-- CNG fuel P LPG fuel
R-- Low Compression (For 87 and below octane fuel)
S-- Swirl intake (1980s)
SE-- D-4 Gasoline Direct Injection (1990s)
T-- Turbocharged
U-- With Catalytic converter Japan-spec emissions
V-- Common Rail Diesel Injection (D-4D)
X--Atkinson cycle (typically also indicates a Hybrid engine, as Toyota only uses the Atkinson cycle with hybrids)
Z-- Supercharged (For example, the 4A-GZE code means that it's an engine from the 4th generation of the A family, supercharged, electronically fuel injected, with performance cams.)Note: Toyota, in 1987, began assigning dual letter engine codes to some of the "engine family" categories in some engine lines, particularly six cylinder models. This can create potential confusion. E.g. 1MZ-FE - This is not a supercharged, narrow angle, fuel injected M-series engine, but a narrow angle, fuel injected MZ-series engine. Confusion is easiest to avoid when using the dash to separate between the engine series and its own characteristics: for instance, 1MZ-FE rather than 1M-ZFE.
eVil.TwiT
A man that brings more trash from nature's trails than he brings to them is a hero.
ev13wt is offline   Reply With Quote Quick reply to this message
Old 01-05-2017, 08:09 AM   #12 (permalink)
Member # 52443
Long blocks are "the same". I know because I put a RE into an REC (REC everything except longblock, ie intake, distributor, exhause, pies for cooling, starter, alt, etc)
eVil.TwiT
Old 01-06-2017, 09:31 PM   #13 (permalink)
Member # 70087
What are you trying to say, you put an RE into an REC?
Old 01-06-2017, 09:45 PM   #14 (permalink)
Member # 70087
I just noticed post#3, from 2011, thats bullshit. I can't believe no one corrected him. That diagram that's supposed to be a "22rec" is a carbureted motor lol.
