Toyota truck repair - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-21-2011, 12:01 AM   #1 (permalink)
Member # 188826
Toyota truck repair
toyota truck blower repair
toyota truck front wheel bearing repair
toyota truck repair panels
online toyota truck repair manual
toyota truck repair
toyota truck transmission repair
1980 toyota truck 4wd brake repair
1981 toyota truck clutch repair
1981 toyota truck repair clutch
1986 toyota truck repair manual
1987 toyota truck ignition repair manual
1991 toyota truck repair manual
1992 toyota truck repair manual
1995 toyota truck repair manual
1996 toyota truck door repair
86 toyota truck rocker repair panel
93 toyota truck repair
free toyota repair manual 1986 truck
heater repair on toyota pickup truck
manual repair toyota truck
repair dimmer switch 1994 toyota truck
repair manual for 1986 toyota truck
repair manual for toyota truck
repair manuel 1986 toyota truck
toyota 1992 truck repair manual
toyota fork truck repair
toyota fork truck repair memphis tn
toyota truck ball joint repair
toyota truck bed repair
toyota truck bed repair parts
toyota truck body repair panels
toyota truck brake repair manual
toyota truck fuel line repair
toyota truck horn repair
toyota truck hydraulic clutch pedal repair
toyota truck hydraulic clutch repair
toyota truck manual repair
toyota truck repair guide
toyota truck repair las vegas
toyota truck repair questions
toyota truck repair questions and answers
toyota truck rust repair panel
toyota truck rusted floor pan repair
toyota truck steering gear repair
toyota truck window repair
1989 Toyota truck repair question car not going to overdrive?
I have Toyota truck (pick up) and can't figure out why it doesn't go to overdrive. I recently replaced solenoid and there is power going to it. What else it could couse the ca not going to overdrive?
frensy is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 08:05 AM   #2 (permalink)
Provience's Avatar
Member # 138976
Is it completelt up to normal operating temperature? The ecm locks out od until fully warm, if you are running cold or without a thermostat it may never make it.
Have you seen our handy toyota faq? Only it can answer all of your vaugue questions....
Oh, your tranny could be fucked as well, that can cause no od.
I just want to build cars, collect watches and get tattoos.
