steering wobble - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-25-2011, 10:18 PM   #1 (permalink)
Member # 108161
steering wobble
I have a 86 SAS runner with a 3.4l, 40” irocs ext
I am getting a wobble in my steering at 60 to 70km
I replaced all my tie rod ends and trunnion bearing recently and its still there.
I noticed my that my tie rod has a bend in it but was told if my tow in is good that it wont affect anything and it is at 3/16 in.
Any thoughts
Thanks.
spotvangogh is offline   Reply With Quote Quick reply to this message
Old 05-25-2011, 10:26 PM   #2 (permalink)
Taco-Runner's Avatar
Member # 110365
When was the last time you had your tires balanced?
"THE" Link System Specialist for your Toyota Truck, 4Runner, Tacoma and 80
Custom Tuned Shocks for Leaf Springs & Coilovers
Taco-Runner is offline   Reply With Quote Quick reply to this message
Old 05-25-2011, 10:31 PM   #3 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
When was the last time you checked your spring and shackle bushings. The preload on your trunnion bearings and adjustment on your wheel bearings? Check your toe-in.
Old 05-25-2011, 10:32 PM   #4 (permalink)
Member # 20957
Send a message via Yahoo to Hyena
check everything.
Old truck
Jimmy's 4X4
Hyena is offline   Reply With Quote Quick reply to this message
Old 05-25-2011, 10:32 PM   #5 (permalink)
diefree's Avatar
Member # 2337
wheel bearings and spring bushings
If u have revolutionary potential u have a moral imperitave 2 make the world a better place.01GMC8.1
diefree is offline   Reply With Quote Quick reply to this message
Old 05-25-2011, 11:42 PM   #6 (permalink)
wades_76_cj7's Avatar
Member # 15808
Are you running wheel spacers and/or <3" of backspacing on your wheels? If so your Ackerman angle is all out of wack and will cause death wobble. I ran the 1.5" spacers when I put my SAS on. After driving it one trip I took them off. With 2" bs wheels and the spacers it was scary to drive over about 20 mph.
I still get the shakes on the road about 30-35mph but above or below that and it settles down.
04 Dodge Cummins tow pig.
06 LJ Rubicon with some stuff
'15 RZR 900S trail toy
wades_76_cj7 is offline   Reply With Quote Quick reply to this message
Old 05-26-2011, 07:13 AM   #7 (permalink)
Member # 118757
Way to be helpful!
Originally Posted by Hyena View Post
check everything.
To the OP, along with everything mentioned, also check your caster angle.
People have had lots of luck with Davez no death wobble shackles. The stress that we put on a shackle without the sleeve (any Trail Gear Shackle) results in looseness in the setup, and results in deathwobble. This gets worse if the shackle plates don't sit flush with the bushings, or if the bushing hole has been worn out. People can temperarily fix this by tightening down on the shackle bolts... as a result of this is just makes them worse over time.
DTCsk8er is offline   Reply With Quote Quick reply to this message
Old 05-26-2011, 08:17 AM   #8 (permalink)
howyadoin's Avatar
Member # 84132
Search "death wobble"...though everyone above has pretty much layed it out for you. In addition, realize toe doesn't have a magic number, toe-in for 40's will be different than toe-in for 27's when using the standard method of measuring. .02
"They are Just as stupid as dumbage is." ...Landslide
howyadoin is offline   Reply With Quote Quick reply to this message
Old 05-26-2011, 08:22 AM   #9 (permalink)
shoes optional
drewp's Avatar
Member # 142117
yep death wobble its something you will just about always have. and if you fix it, great, but one trip wheeling and it will probably be back again...after a while you will get used to it and it wont be a big deal...just dont drive by a cop while shaking they tend to pull you over while in that 35-40mph death wobble sweet spot
I NEED A HARLEY SS175 PISTON!!!!!!!!!!!!!!!!Found and now its time to build a bobber
drewp is online now   Reply With Quote Quick reply to this message
Old 05-26-2011, 08:51 AM   #10 (permalink)
Trailbusters4x4 club
FuzzyZ's Avatar
Member # 117547
Originally Posted by DTCsk8er View Post
Way to be helpful!
Most of the luck with going to those is mainly from people replaceing there worn out bushings they had on there rigs when they replace those shackles. Dont get me wrong though they are quality and i do have a set on my truck. But bet just replaceing the bushings with good quality ones would be just as effective a and cheaper in the long run.
83 toy pickup, 02 TJ, 02 GMC 2500HD, 86 4runner
Trailbusters4x4 club Solano County
ECV 1004
FuzzyZ is offline   Reply With Quote Quick reply to this message
Old 05-26-2011, 08:53 AM   #11 (permalink)
FuzzyZ's Avatar
Member # 117547
Any thoughts
Thanks.
that actually sounds a bit much for 40's.
ECV 1004
Old 05-31-2011, 11:39 AM   #12 (permalink)
TOYOTAPARTS's Avatar
Member # 61493
I agree, if you dont mind changing the bushings often you dont need our shackles. Our design (Toyota factory style) the bushings will last much longer.
Great deals on Toyota Parts: :
RCV 30 Spline axles FREE shipping.
Yukon parts on SALE
3rd Members priced right. 530-622-2148
for all your electrical needs
TOYOTAPARTS is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 12:14 PM   #13 (permalink)
GloNDark's Avatar
Member # 2482
I was literally replacing shackle bushings every other trip out. Then I bought the "Anti death wobble shackles" and haven't needed to replace them since. Been over a year now without issue. I'm pretty happy with that.
Running 38.5 SX's I had some pretty serious death wobble. And it took a lot to get it under control. I replaced/adjusted the following
- Leaf spring bushings/Shackles
- New Trunion bearings
- BB balanced the tires
- Adjusted alignment
- Replaced the stock steering arm studs with ARP studs.
And I still have a little shake to the truck in that awesome 30 to 40 mph zone.
BUILD THAT FUCKING WALL!!!
GloNDark is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 12:32 PM   #14 (permalink)
11bcacti's Avatar
Member # 154643
Send a message via Yahoo to 11bcacti
This might sound stupid but I had some scary death wobble at about 40-45 MPH and I put a new steering stabilizer on and it helped. This was on a stock suspension 84 though
Hey yall!! Watch this!!
11bcacti is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 04:42 PM   #15 (permalink)
Member # 29757
This may sound retarded, but mine turned out to be blown motor mounts. With the drive train slopping around it made the whole truck shake going down the road. I had really bad death wobble even after fixing/checking/replacing all of the stuff listed above. I replaced the torn motor mounts with Dave'z and the wobble is gone.
'88 Toyota
Dual cases and dents.
BeaterToyota is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 09:27 PM   #16 (permalink)
Member # 108161
Thanks for all the replies.
I am still trying to sort it out. It’s not by any means a death wobble. It can be if I hit a big bump at low speed but if I stomp on the gas it’s gone.
I have checked just about everything and through in a steering dampener.
The spring bushings are the next step I just need to figure out what the springs are out of. The bushings in them look like the ones in the 63” Chevy’s.
