Member # 188092
22RE camshaft cap replacement
Sorry Guys, my internet is very limited right now (because Verizon SUCKS) and so I dont have the time to search this a great deal. Rather I need a simplish answer, PLEASE
![]() Went to adjust my rockers this morning and can see that my #2 camshaft bearing cap is cracked on one side, this is the one in the middle of the three. This would explain why it seemed to float at high RPM, ![]() Looks like I can run it OK for awhile with low RPMs but when I get to replacing it, can I simply use a new cap? Are these aligned honed? Do they use a bearing or are they simply run without bearings? I have`nt seen the bottom of the bearing so I dont know if its any good, but if it is, can I trough a cap on it and expect it to work? Thanks in advance. Randall |
Davez Off Road
They are head specific. I have had to replace one before. If you can get a hand full of the same # and try each of them till you get a good match it can be done. Too tight is bad and so is too loose. Just going to take a little time. If you find one that is too loose you can sand the mounting surface a bit to try and achieve the right tolerance.
Great deals on Toyota Parts: : http://www.davezoffroadperformance.com/ Most Trail-Gear parts FREE shipping.Yukon parts on SALE 3rd Members priced right. 530-622-2148 for all your electrical needs http://www.12voltguy.com/ WIN a fully built Toy p/u http://www.pirate4x4.com/forum/toyot...toyota-pu.html |
