Selling something in the Midwest? Post link here - Page 10 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Great Lakes States
Old 04-01-2010, 07:13 PM   #226 (permalink)
What!? I'm deaf!
TrailTamer XJ's Avatar
Member # 140878
Originally Posted by TrailTamer XJ View Post
anybody got any full floater GM 14 bolt rear axle? preferred with 4.10. disk conversion will be a bonus
bump, still looking
You can't say that you have wheeled hard till you have broken something or gotten stuck.
TrailTamer XJ is offline   Reply With Quote
Old 04-04-2010, 01:26 PM   #227 (permalink)
Member # 129381
Cummins 12 Valve
NT2HLBLY is offline   Reply With Quote
Old 04-05-2010, 07:18 AM   #228 (permalink)
What!? I'm deaf!
Member # 140878
bump, still looking
got what I need, thank Dave
Old 04-05-2010, 08:03 AM   #229 (permalink)
Member # 129381
Anytime!
Old 04-06-2010, 08:34 AM   #230 (permalink)
Member # 106142
Gooseneck Hitch FS
/forum/misc-stuff-sale/878233-b-w-gooseneck-hitch-il.html
blbronc is offline   Reply With Quote
Old 04-06-2010, 01:34 PM   #231 (permalink)
Kaiser5's Avatar
Member # 26472
2006 Chevy Silverado 2500HD Duramax LBZ LT3
/forum/vehicles-trailers-sale/878278-2006-chevy-silverado-2500hd-duramax-lbz-lt3.html
'84 Bobbed -8, LT-1, TH400, STaK 3 speed, front 60 with Detroit/35 spline shafts, rear 14 bolt with detroit, garage built rear four link, front radius arm, 42" TSLs on locked Racelines, PSC assist, WARN 8274, lots of plating.
'82 -'8 As stock as it gets...
Kaiser5 is offline   Reply With Quote
Old 04-07-2010, 07:44 AM   #232 (permalink)
playinwithit
ROXROES's Avatar
Member # 97574
Got a 4.2L out of an 88 YJ. Ran somewhat but smoked, has all accessories including starter, flywheel and clutch. Only thing I've robbed off it is the coolant temp sensor, air filter shroud and a drivers side engine mount.
Good parts for a DIY stroker!
$150
ROXROES is offline   Reply With Quote
Old 04-07-2010, 05:10 PM   #233 (permalink)
clankinstine's Avatar
Member # 141840
http://s241.photobucket.com/albums/f...00inches/parts this is about 75% of the parts i have.
12" lift, 6" lift, dana 60 front dana 70 hd rear, dana 60 rear, dana 44 front parts, hydro assist steering, 42" tsl with eaton 14" wise 8 lug streetlocks, rust free 73-87 gm truck parts, 350 sbc, 302 sbf, 379 cid diesel, th400 4x4, th400 with np203, sm465 4x4 with 32 spline out put, 16x8 8 lug eagle alloys, 15x10 6 lug eagle alloys, 3/4 ton 4x4 gm frame, 73-87 blazer/ jimmy suburban, crew cab parts.,
clankinstine is offline   Reply With Quote
Old 04-10-2010, 07:18 PM   #234 (permalink)
Member # 132710
Wanted....
I am looking for a set of small bearing dana 44 GM spindles.
Anybody help me out?
PM me what you got!
bdelf01 is offline   Reply With Quote
Old 04-14-2010, 02:26 PM   #235 (permalink)
NOBAMA!
FlatBlackXJ's Avatar
Member # 68916
Got a FF 14 bolt, bottom has been shaved, still needs replated. No brakes.
Shafts, hubs, R+P, diff, yoke, etc all there. Some pitting on spindles, but I believe it can be cleaned up.
Comes with the following Ballistic parts:
Pinion guard, leaf perches, shock mounts, bolt on caliper brackets
Stock perches are still on there, shock mounts are gone. Looking to get $225. Located 30 minutes south of springfield, IL.
Let's party, let's get tore up and get loud!
Vinyl deals in the works.
FlatBlackXJ is offline   Reply With Quote
Old 04-15-2010, 12:35 PM   #236 (permalink)
addict's Avatar
Member # 126546
86 jeep mj iowa
http://desmoines.craigslist.org/pts/1693072599.html
addict is offline   Reply With Quote
Old 04-18-2010, 04:34 PM   #237 (permalink)
FFX
Member # 136862
Coils
Looking for Rear TJ Coils. 4"
PM Me
Thanks !
FFX is offline   Reply With Quote
Old 04-18-2010, 09:13 PM   #238 (permalink)
NOBAMA!
Member # 68916
Thinkin about selling my wheels/tires. They are 17x9.5 Allied RockAThon Soft 8 beadlocks. 5x4.5 bolt pattern. 32 bolts per wheel that have been recently replaced. The rings have some rock rash on them, but are in otherwise good shape. When I had them balanced they said one of them was slightly bent. These sell for $230/ea new.
They are mounted on 33x12.5 Swamper TrXus M/Ts that have probably 1/4 tread remaining. Ive had them down to 4lbs with no issues. I really don't want to seperate. $475 obo, located 30 minutes south of Springfield.
SOLD.
Old 04-20-2010, 10:15 PM   #239 (permalink)
boondox's Avatar
Member # 85842
Instead of selling, I WTB some ford 16.5 (8x6.5) wheels. I need 5.
2005 SAS xterra. d44 hp, d60 rear, 4 link front, 63 leaf rear, blah blah blah
boondox is offline   Reply With Quote
Old 04-21-2010, 07:00 PM   #240 (permalink)
Da Bears!
Jwbogger's Avatar
Member # 36682
1984 Chevy 1 ton, 60/14 bolt, 454, 44 gumbo's, good property/mud truck for cheap. $1800 or best offer. I'll get some pics posted when I get a chance. Won't take much to get it in wheeling shape.
Jwbogger is offline   Reply With Quote
Old 04-21-2010, 07:12 PM   #241 (permalink)
funk_1964's Avatar
Member # 121019
where?
"Yeah.... I spot for entertainment purposes... What of it?"
funk_1964 is offline   Reply With Quote
Old 04-22-2010, 06:58 AM   #242 (permalink)
Da Bears!
Jwbogger's Avatar
Member # 36682
Illiopolis, 20 minutes East of Springfield.
Old 04-23-2010, 05:34 AM   #243 (permalink)
THE GODFATHER's Avatar
Member # 96575
79 bronco 92 jeep wrangler and bronco or f150 lift new in box.
1992 jeep wrangler 6cyl. 5 spd. with spring over and 3 inch lifted spring mounts. slip yoke eliminator and custom built cv driveshaft (will be here in the next couple days) and one piece front axle shaft to eliminate the vacuum crap. also has hard top and hard doors. little rust but not bad. like to get 3800 or best offer. 217-855-0866
i also have a 79 bronco that has a 400 with edelbrock car and intake. it has blocks in the rear. on rollers but will clear 35's easy. the body is in great shape but ha a little rust around the rear fenders. other than that it is very solid and pretty clean. 1600 o.b.o. 217-855-0866
also have a brand new in the box lift with pitman arm and track bar drop bracket. will sell all for 375 o.b.o.
Jesus Rocks!
1993 Jeep YJ on 60's with chromo's and detroits 4 linked front and rear with re-centered H1's and 42" iroks.
2003 Dodge Crew Cab 4x4 Laramie Edition with 5.9 Cummins Near stock but so far undefeated! Soon to have a leveling kit and 35 inch iroks with 18" Ballistic Wheels.
THE GODFATHER is online now   Reply With Quote
Old 04-23-2010, 12:22 PM   #244 (permalink)
Member # 28644
Got my 99 TJ for sale, $6,000.00 located near Decatur, IL
Custom 2" x 4" frame, 4-link and coils on rear, leafs on the front. 38" TSL on 32-bolt beadlocks, 14-bolt rear w/ detroit, dana 60 w/ OX locker front, 350 engine, rebuilt B&M 350T with new torque converter, dana 300, hydro steering, alumn radiator. trans cooler. flat front fenders, cut out rear wheel-wells. Only has bikini top and half doors.
Phone 217-519-9502
Greg
00 TJ on 31's and big ol pile of parts laying next to it
HalfJ-7 is offline   Reply With Quote
Old 04-23-2010, 07:30 PM   #245 (permalink)
funk_1964's Avatar
Member # 121019
Phone 217-519-9502
Greg
i would like to see some pics of this!
Old 04-23-2010, 09:41 PM   #246 (permalink)
Member # 157851
Parting out whats left of my TJ crawler project
/forum/axles-tires-wheels-sale/879043-tj-crawler-part-out.html
Give a monkey a brain and he'll swear hes the center of the universe.
meatlord is offline   Reply With Quote
Old 04-23-2010, 09:59 PM   #247 (permalink)
TabooCustoms's Avatar
Member # 105073
I have some re-centered H1 rims and tires that I might be willing to part with here in a few weeks. Only have 4 though, I need five 16" steel rims 8 on 6.5" and 35" tires.
There is a pic at the very bottom of the link below.
http://www.taboocustoms.com/xjdrivetrain.htm#402139488
Team TABOO 2012 RRock
Thanks to:
LOCTITE
Tom Wood's Custom Drive Shafts
Central Welding Supply
Koenig Machine & Welding
Delta Tire & Yokohama
H&B Quality Tooling
Aire Serv of Quincy
TabooCustoms is offline   Reply With Quote
Old 04-25-2010, 07:44 PM   #248 (permalink)
Member # 105073
Need a 258 close to Quincy IL.
http://www.pirate4x4.com/forum/showt...4#post11329024
Thanks to:
LOCTITE
H&B Quality Tooling
Aire Serv of Quincy
Old 04-27-2010, 08:49 PM   #249 (permalink)
NOBAMA!
Member # 68916
How much for the H1 wheels? Im close to Springfield IL. Thanks
Old 04-27-2010, 09:30 PM   #250 (permalink)
Member # 105073
Id go $350 on them with the tires.
Thanks to:
LOCTITE
H&B Quality Tooling
Aire Serv of Quincy
