Selling something in the Midwest? Post link here - Page 49 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Great Lakes States
Old 01-02-2012, 10:39 AM   #1201 (permalink)
funk_1964's Avatar
Member # 121019
still got some ORIs for sale, as well as a th350... Link in sig
"Yeah.... I spot for entertainment purposes... What of it?"
funk_1964 is offline   Reply With Quote
Old 01-02-2012, 11:05 AM   #1202 (permalink)
6boltfreak's Avatar
Member # 188642
Originally Posted by TrailTamer XJ View Post
Thank you Brad.
I paid $2500 for it 1 or 2 years ago. I Didn't use it very often.
It's a trailer that have been built right and will not give you any problem. Bring your truck with 2-5/16" ball then just hook it up and load it up to 8,000lb and haul across the country without a problem. It needs nothing, maybe tires if you'd want to.
Many "cheap" trailers out there may need works. It may works when you buy it but sooner or later you'll need to fix something on it, very likely wiring and maybe brakes, bearings, deck, whatever, but you won't on this trailer.
Again, it's $2500 or best offer, I also don't mind to trade or barter if it's something I'd like.
little steep but its a difinate not over priced trailer i have seen worse for more, would be better if you finished the deck though. i told a buddy of mine whos looking GLWS
6boltfreak is offline   Reply With Quote
Old 01-02-2012, 07:58 PM   #1203 (permalink)
Member # 151804
Send a message via Yahoo to uglycherokee
ax5 needed southern indiana
Man I had a crappy xmas. Tranny in my yj went out xmas day. Damn santa emptied my wallet then blew up my ax5. Who's got one CHEAP??????
uglycherokee is offline   Reply With Quote
Old 01-03-2012, 11:27 AM   #1204 (permalink)
Member # 43433
Listing for a friend: 14 bolt ff from a late 70's or early 80's pickup. Unknown ratio, but he will be pulling the cover to check. Pictures then too. Located in Ransom, il. Could arrange to be brought to elk grove village area, or any where in between along 355/55/80
$100.00 obo
Flingarrows is offline   Reply With Quote
Old 01-03-2012, 11:31 AM   #1205 (permalink)
DMANbluesfreak's Avatar
Member # 163019
I may be interested depending on what gears/carrier it has.
2001 Silverado Ext Cab 5.3L
3" Body Lift, Rock Sliders, Bilstein 5150s, 37" MTRs
14B w/ Grizzly Locker, Dana 60 HP, NP241 - BUILD THREAD
DMANbluesfreak is offline   Reply With Quote
Old 01-04-2012, 02:16 AM   #1206 (permalink)
Member # 43433
ok, i'll post up when he get the info tomorrow
Old 01-04-2012, 07:56 PM   #1207 (permalink)
bsfarmer's Avatar
Member # 108046
Set of Rockwell 2.5 ton axles. U-joint style, been sitting high and dry inside for several years. Good condition.
$1000 OBO
bsfarmer is offline   Reply With Quote
Old 01-04-2012, 09:55 PM   #1208 (permalink)
Da Bears!
Jwbogger's Avatar
Member # 36682
Selling my Unimog Portals 404's, picked up a set of Mog9's. I will sell them with the PSC DE Steering Ram and the full Hydraulic set for a Jeep TJ or without. If I sell them without I am keeping the steering so it is not for sale separately.
The Portals have pinion conversions with a 1410 flange.
GM metric disc brakes and ford rotors
Brackets for a 3 link rear with wishbone upper. Front is 3 link with panhard.
I will also throw some other stuff in on the deal. These axles are tough and I have had a blast with them. If you have something I can use for my 6.0 swap and mog9 swap I would listen to trade offers. Ie. Ls parts, ORI'S, TH350 upgrades, 9 inch truss, Aftermarket rear bench seat, etc.
They are setup currently for a 8 on 6.5 bolt pattern.
These axles work best with hummer beadlocks using the factory backspacing. I just so happen to have a set of 8 bolts with boggers for sale as well. Would make a nice package deal.
Asking $3500.00 w/ steering
or $2500.00 w/out
Jwbogger is offline   Reply With Quote
Old 01-04-2012, 10:38 PM   #1209 (permalink)
Member # 117013
looking for a D44 or 10 bolt 8 lug front axle, prefer 4.10, this is a temp on road axle, got quoted $450, I sold my last one (when I wasn't going to use it) for $125.
Also looking for SBC aftermarket Dual plane intake and throttle bracket to work with 700R4.
Afghanistan Veteran, US ARMY 13F SGT
vic_v8 is offline   Reply With Quote
Old 01-05-2012, 02:24 PM   #1210 (permalink)
Member # 163057
http://pirate4x4.com/forum/showthread.php?t=1033935
toyota 8" detroit 5.29 hi pinion. $900. i can take less if its not shipped. its never been ran before just installed then i switched axles
laskt9 is offline   Reply With Quote
Old 01-05-2012, 03:25 PM   #1211 (permalink)
THE GODFATHER's Avatar
Member # 96575
Got a couple of projects sitting I need to get rid of quick or I'm going to scrap them. First up is a Suzuki Samurai with a 4.3 v6, turbo 350 I think and probably 203. It was on the trail with stock axles and was a bad ride. Then my brother bought it and started putting in toyota axles and cut the back off. then he took out the dash and started to re wire it and he didn't get much farther than that. $350 without the axles or tires $450with the axles.
Next is a toyota I built for a buddy and then he never bought it. It went out once and did great but the carb messed up and when he had it rebuilt it didn't run right. tires and wheels are gone has a clean title. $695
Also have a detroit locker and a set of 4.88 thirds, one open, one spooled
Jesus Rocks!
1993 Jeep YJ on 60's with chromo's and detroits 4 linked front and rear with re-centered H1's and 42" iroks.
2003 Dodge Crew Cab 4x4 Laramie Edition with 5.9 Cummins Near stock but so far undefeated! Soon to have a leveling kit and 35 inch iroks with 18" Ballistic Wheels.
THE GODFATHER is offline   Reply With Quote
Old 01-05-2012, 04:47 PM   #1212 (permalink)
funk_1964's Avatar
Member # 121019
motivated on the ORI's
Old 01-05-2012, 08:07 PM   #1213 (permalink)
Da Bears!
Jwbogger's Avatar
Member # 36682
38.5 Boggers and Hummer Beadlocks & Inserts
For sale thread;
http://pirate4x4.com/forum/showthrea...0#post13825960
$1500.00 obo
Old 01-06-2012, 11:09 AM   #1214 (permalink)
Member # 157644
4.6 jeep wrangler stroker motor
I have a 4.6 stroker motor out of a 1999 jeep wrangler. This motor includes a high flow water pump, 24 lbs injectors forged pistons, oil pan and valve cover. If you use a cold air intake, header and cat back exhaust system it builds over 280 HP.
This motor is a fresh rebuild with no miles on it at all. The cam failed last fall and I had to pull the motor. I put in a junk yard motor while this one was being rebuilt. now I need the cash. It was re-built under warranty by Component Machine here in Indianapolis. It will need to be broken in and comes with instructions to do so. $2800.00 317-590-5610 Indianapolis, IN
Kris_Kris is offline   Reply With Quote
Old 01-06-2012, 12:28 PM   #1215 (permalink)
Member # 52815
Send a message via Yahoo to jeep_87_cherokee
YJ windshield frame
http://www.pirate4x4.com/forum/showt...5#post13815525
I have about every part for a 14 bolt and some complete axles
don't touch the trim
jeep_87_cherokee is offline   Reply With Quote
Old 01-08-2012, 07:19 AM   #1216 (permalink)
MR. HOGG's Avatar
Member # 146572
Having some light construction work done to my garage. As a result i had to move everything in it. I have several items that i dont see needing in the immediant future. Feel free to make offers or trade offers on any of the Items.
Racetrim Youth suspension seats SOLD
http://www.pirate4x4.com/forum/showt...967&highlight=
Tuffy Center Console - Damaged SOLD
http://www.pirate4x4.com/forum/showt...972&highlight=
OLD Metal Gas Can / Jerry Can
http://www.pirate4x4.com/forum/showt...000&highlight=
Corvette Fuel Filter / Fuel Pressure Regulator (For LS Swap) SOLD
http://www.pirate4x4.com/forum/showt...990&highlight=
86-91.5 Ford Dana 60 Kingpin in Illinois
http://www.pirate4x4.com/forum/showt...290&highlight=
Yamaha shop banner SOLD
http://www.pirate4x4.com/forum/showt...976&highlight=
B&M Mega shifter
http://www.pirate4x4.com/forum/showt...971&highlight=
TJ 1/2 doors and uppers SALE PENDING
http://www.pirate4x4.com/forum/showt...965&highlight=
96 F250 4x4 ex cab short bed 7.3 5spd
http://www.pirate4x4.com/forum/showt...993&highlight=
May have more to post later, sell / trade let me know if you want somthing.
"Professional Driver on a Closed Course"
Off-Road Supply
4x4 Syndicate: Hardcore Offroad Club
MR. HOGG is offline   Reply With Quote
Old 01-09-2012, 01:09 PM   #1217 (permalink)
Kaiser5's Avatar
Member # 26472
1998 Winnebago Adventurer Class A motorhome for sale.
/forum/vehicles-trailers-sale/1035440-koh-ready-winnebago-adventurer-class-motorhome.html
'84 Bobbed -8, LT-1, TH400, STaK 3 speed, front 60 with Detroit/35 spline shafts, rear 14 bolt with detroit, garage built rear four link, front radius arm, 42" TSLs on locked Racelines, PSC assist, WARN 8274, lots of plating.
'82 -'8 As stock as it gets...
Kaiser5 is offline   Reply With Quote
Old 01-10-2012, 02:13 PM   #1218 (permalink)
Member # 102522
Originally Posted by vic_v8 View Post
looking for a D44 or 10 bolt 8 lug front axle, prefer 4.10....
I assume you are looking for a passenger-side-differential axle only? Since either a D44 or a 10 bolt will do?
fordmonkey is offline   Reply With Quote
Old 01-10-2012, 09:44 PM   #1219 (permalink)
Member # 117013
Yes, maybe just the outers if thats all I can find
Old 01-12-2012, 06:09 AM   #1220 (permalink)
Member # 193081
Ive got a 32-spline np241 that came out of an 88 Chevy behind an sm465. It is on craigslist st. louis but I thought I should throw it up on here also.
If anyone has a 32 spline 203 for sale, I would be very interested.
arwolf is offline   Reply With Quote
Old 01-14-2012, 05:48 PM   #1221 (permalink)
Member # 174380
I'm looking for a set of 17" rims cheap, 8 on 6.5.
I HAVE A BUILD THREAD SOMEWHERE..........
Pinkcrawler is offline   Reply With Quote
Old 01-15-2012, 12:49 PM   #1222 (permalink)
Member # 126352
EB 44 and 9 with spare parts
i have a set that came out of my side when i switched to my 14b and hp60. the front is 4.10 , aftermarket front shafts , disks new calipers and lines to the calipers. ready to roll. 9 in i have a couple of housings with parts for spares.the rear has drums that work with matching 4.10s. i ran my early bronco on 38" skinny tsl for a year or so until i broke a shaft . i had the tons waiting so i put these back together for my daughters tj but another set of tons came up so these are up. i frequent dirty turtle offroad in bedford ky and work in indy so can deliver as long as its on the way or close. open to parts trades. 600 bucks for the axles and the spare stuff.
im out of columbus in
812-603-5070
fordman47201 is offline   Reply With Quote
Old 01-15-2012, 05:06 PM   #1223 (permalink)
Member # 199086
Hey Kevin can u send me pics of those beadlocks?
MyTJ13 is offline   Reply With Quote
Old 01-15-2012, 05:08 PM   #1224 (permalink)
Member # 199086
Looking for a set of trxus mt or cooper stt's. 35 or 37 on 15's. Located in moline, il.
Old 01-16-2012, 03:24 AM   #1225 (permalink)
Member # 65365
big hammer drill
/forum/tools-equipment/1037103-bosch-11244e-spline-drive-drill-w-bits.html
91YEEPER is offline   Reply With Quote
