Toyamurai Project - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Islands and Territories
Old 07-13-2010, 12:10 AM   #1 (permalink)
Member # 161461
Toyamurai Project
87' Samurai
Tearing it Down
Fabbing a New Frame and Spring Hanger
Custom Frame Gussets and Shackles
down2rock is offline   Reply With Quote
Old 07-13-2010, 09:53 AM   #2 (permalink)
Member # 91088
looking good...so whats the plan for this Sami.? axles? what motor are you going to run in this thing...?? so how did your cage handle that roll i saw on youtube..? looked pretty minor....
ISLANDCRAWLERUNION.COM
1010 is offline   Reply With Quote
Old 07-13-2010, 10:24 AM   #3 (permalink)
Member # 146853
sick! Ive always wanted a samurai with toyota drive train.. cant wait to see how it comes out..
solidmaui78 is offline   Reply With Quote
Old 07-13-2010, 11:44 AM   #4 (permalink)
Member # 161461
What's up keha? How u doing? For the drive train I'm going full Toyota, dual transfer cases, and a 22re. Might just end up with the hood of the Sammy by the time I'm done but. We'll see. As for my truck. The caged did it's job very well. No real body damage. Just flat spotted the passenger leaf spring. But it was about time to tear it down n do some maintenance and up grades.
Old 07-13-2010, 12:45 PM   #5 (permalink)
Member # 91088
im doing good, been working on the new section of trail..quit a bit.. glad to hear your cage held up, from seeing it first hand i knew it would. the sami is going to be mean...cant wait to see what you end up with..!!
Old 07-14-2010, 12:10 AM   #6 (permalink)
Member # 161461
finished up the shackle mounts and shackles and finally got the axle mounted
stretched the wheel base about a foot up front
donor motor and trans
Old 07-14-2010, 12:12 AM   #7 (permalink)
Member # 161461
and enough pipe to wrap a few rigs
Old 07-14-2010, 09:04 AM   #8 (permalink)
Member # 146853
sweet, where do you get your tubing from? what sizes are you using?
Old 07-14-2010, 10:27 AM   #9 (permalink)
Member # 78331
Nice work so far. My friend Kawe was tossing the idea around of stretching his wheel base too. What springs you running up front??
dirtchicken is offline   Reply With Quote
Old 07-14-2010, 01:55 PM   #10 (permalink)
Member # 161461
For now I'm running the yj's but I think the spring rate may be to soft. But I'll just have to wait and see. Thinking about linking the rear. Not sure yet.
Old 07-14-2010, 01:58 PM   #11 (permalink)
Member # 161461
I get most of my metal from Borsma steel. I use 1 1/4" black pipe. It's half the cost of tubing and holds up just fine for what we do here. But if u got the $ for DOM. Go for it.
Old 07-21-2010, 01:06 AM   #12 (permalink)
Member # 161461
Not to much progress this week to much wheelin and other projects. Got started on the front axle, fabbed up a upper axle truss some knuckle ball gussets, steering bump stop gussets and some knuckle ball gussets
Old 07-21-2010, 01:12 AM   #13 (permalink)
Member # 161461
I would'nt recommend making these. took more time grinding them then I planned on.
Old 07-21-2010, 01:32 AM   #14 (permalink)
Member # 146853
nice!
Old 07-21-2010, 11:12 AM   #15 (permalink)
Member # 91088
right on, looks like your making some good progress...i hate getting into something and realizing that its more work than you planned on...haha..usually happens every time...
Old 07-27-2010, 11:48 PM   #16 (permalink)
Member # 161461
Another slow week for the samurai. finally got all the parts and hardware together for the front axle. but thats what I get for buying it in pieces. You know those 5 gallon buckets you keep under your house for years? Yah, spent the week digging threw those.
Oh yah new calipers, brake pads and resurfaced the 27 year old rotors.
Old 07-28-2010, 03:46 PM   #17 (permalink)
Member # 78331
Nice work. Where you at on Oahu?? I'm over on the eastside. I'm getting ready to redo my Toy in the next month or two. I have lots on my to do list but a cab swap in the first thing on the list. Next is a front Diamond, my front axle is fawked from welding the gussets on. I can barely get the long side shaft in.
Old 07-28-2010, 10:55 PM   #18 (permalink)
Member # 161461
I live Kaneohe. Did the axle bend or get warped by heat?
Old 07-30-2010, 12:39 PM   #19 (permalink)
Member # 78331
I live Enchanted Lake side. It's warped from the heat and I tend to be a tad rough on my vehicles.
Old 07-30-2010, 12:59 PM   #20 (permalink)
Member # 146853
the rear on your truck doesnt flex very much? looks like a home brew leaf pak...what are you running?
Im about to put the Marlin gusset kit on my axle...I think read some where about how to weld w/o warping the axle... Ive gotta find that again cause that would suck. What would you do different so it wouldnt warp?
and how do you like your Iroks? looks like the 36x13.50/15r radial?
Ok no more ?s lol
Old 07-30-2010, 01:42 PM   #21 (permalink)
Member # 161461
Nice! Shit I've fully welded both my gussets on and no warpage. I jus kept most of the heat on the gusset and not the axle. Waikane this Sunday!
Old 07-30-2010, 01:46 PM   #22 (permalink)
Member # 161461
Ok no more ?s lol
Just stitch weld it if your worried about warping. Do 2" beads every 4" and let the axle cool between beads. No way you'll warp it.
Old 07-30-2010, 01:48 PM   #23 (permalink)
Member # 161461
Oh and one more thing. How do you guys make your pics so big??
Old 07-30-2010, 02:07 PM   #24 (permalink)
Member # 78331
You put ANY heat with a welder into a toy axle you WILL warp it. Check out surftacos homebrew front end build. My springs front and rear are Marlin 4" I set the rear shackle angle up steep hoping it would be perfect when they settled but they haven't settled much if any. I will be redoing the rear when I do my cab swap in the next few months.
Old 07-30-2010, 02:34 PM   #25 (permalink)
Member # 146853
cool, thanks.
