22re and 1600lb marlin clutch - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Northeast
Old 10-31-2009, 04:00 PM   #1 (permalink)
Member # 54522
pulled my motor today its a 22re from an 86 runner. it was rebuilt at 198K and now has 222K. the engine ran great and was NEVER ran on its side. at the time of the rebuild the head was replaced with a napa reman, i think i needs new valve seals. any thing but factory valve seals never seam to last long. i did a compression test about 10K ago and they are all around 155psi. the head gasket was replaced with a felpro higher end one, no graphite impregnated paper, genuine toyota T stat was done at the same time. engine ran great and pulled 38s with 5.29s decently.
small oil leak from rear of valve cover.
you get the ECU and uncut wire harness.
asking $700
22re radiator plastic end tanks and is about a year old, has inner trans cooler.
asking $45
Marlin 1600lb clutch comes with flywheel with .026 or something step. this has 6K on it and is about a year old. you can have the slave if you request it also
asking $125 willing to ship this
my zip is 12484 map quest it if you want to know my location
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote
