Member # 69243
Xmas Eve Wheeling
Hit the woods by myself on christmas eve while the gf was at work. Not much for action shots without a photographer but I did what I could
poser got sucked down into a rut that we made the last time the trail was ran and it was all muddy: |
Member # 69243
Thanks
![]() I think it is time to move away from the pizza cutter LTB's and get some wider tires ... that might have helped quite a bit with regards to breaking through the ice ![]() probably a 37x13.5 or 36x12.5?? I dunno gotta look around |
Member # 144694
sounds like a good plan, especially on such a light truck that should help allot. what are they now 10.5" the only issue is if you go to wide you start to loose traction, again, especially on such a light truck
Member # 46175
Looks like you were out having fun.
What tire pressure are you running in those pics? Wider, less aggressive tires are your friend in the snow.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST Specializing in Axles and Transfercases |
Member # 69243
Yeah they are 10.5" wide currently
I do have some weight in the bed from tools, junk, etc plus the cap so it's at least a little heavier than a standard pickup in the rear The snow wasn't very deep as you can see, but that was at 16psi front/rear for the tires. It was breaking through the ice and then the mud underneath that got me stuck twice, the spots where there weren't hidden mudholes it was going great. I zipped right up a trail that I had problems making it up before the ground froze Hoping to head back out the end of this week, we just got some fresh snow that should make things fun
Member # 69243
I'm way upstate in NY around potsdam/canton/massena area
Definitely glad I had the winch for the mud hole, being totally by myself in an area that doesn't have cell phone service unless you walk a ways and climb a ridge. Not the smartest way to wheel but I more or less know the limits of my rig and know the trails pretty well. That and I've had to go to the top of the ridge before to make a phone call, it's not really that bad |
