#626 (permalink) |
Member # 84464
81 chevy DRW 4.56 open dana 60 with twist hubs $500
77 chevy SRW 4.56 open Dana 60, torn down, blasted and jetwashed, painted. ready to go back together with your rotors, calipers, studs and hubs $550 (2) late 80s kingpin SRW dodge Dana60s with twist hubs and 4.10 open gears. both complete, $450 each ford Dana60 SRW wheel hubs, $140 a pair cast iron trans-->tcase adapter. mates trapezoidal ford NP435 to ford NP205 $70 pair of 5.13 geared dana 80s. see sig empty HPDana30 housing from XJ thats been stripped of all coil bracketry for someones aborted leaf conversion. just a housing, carrier and 3.55 gears. $40 (2) ford explorer 8.8 disc brake rears with verified 3.73 posi carriers, 31spline, 5 on 4.5 BC. $250 each 98 explorer 4dr body parts in blue, nice shape hood $40 rear lift gate with glass and struts $90 tail lights $50/pr dodge freespin kits for 94+ BJdana60, everything from balljoints out (knuckles, spindles, bearings, wheelhubs for SRW or DRW, stub shafts and locking hubs. uses ford twin piston calipers.) $400 a set with all fasteners all in springfield mass.
God Bless America Last edited by mike_belben; 03-05-2012 at 08:11 AM. |
#627 (permalink) |
Bring the Fail
Member # 14085
Lincoln 255c MIG Welder
The welder works perfectly, just looking to get something a little easier to transport (Lincoln 255c weighs 220lbs.), since I do not have a shop anymore. Would consider a trade for a TIG welder. Looking to get $1,500. There was one on Pirate for $1800, one on ebay for $1600, and 5 on craigslist within 3500 miles of me for $1,750 and up. Looks like everyone keeps this welder once they get it. Wish I had a permanent workspace for it. |
#629 (permalink) |
Member # 83330
Chevy Trannys, T-case, 6.2 diesel parts & misc 87 K5 stuff.
4x4 700r4, $150
NP208, 27 spline $ 100 4x4 Th400 $150 87 K5 glass $25ea or $110 for all 6 87 K5 A/C system working when disconnected $75 Maroon Front and back seats, $75e Front & Rear 10 bolt axles 3.08 gears, $40ea Factory Aluminum wheels w/31” tires $80 Maroon seat belts (all 5) $40 shipped 6.2 diesel starter less than 200hrs (like new) $100 ea + shipping 6.2 diesel injection pump less than 400hrs $150 + shipping 6.2 diesel non-egr intake $75 + shipping 6.2 diesel fuel filter (square type) $35 shipped Pictures on request
Mark 86 M1009, D60, 14B, sm465/205, Diesel, 38 TSL's |
#630 (permalink) |
Member # 36072
Chevy K30 One ton frame (From military CUCV), Good shape - $400 I can load or will deliver for 1.25 per mile.
Buy some of my crap in the classified section , mkay? |
#632 (permalink) | |
Member # 18048
#633 (permalink) |
Member # 54585
Anybody have a gooseneck trailer 26-28ish feet for sale? Looking to pick something up before summer!
94 Ranger-1 tons, 5.38s, linked, 1354/dana 20 doubler, caged, hydro, 4D's, and always breaking Tow rig: 99 F250 PSD, 6-speed, South Bend Clutch, 38R, Swamps 176 Single shots, Gearhead tunes, Airdog 150, water/meth, on 37's DD: 01.5 S4 Avant....stock for now |
#634 (permalink) |
Member # 77925
37" Super Swamper Trxus, 02 Superduty dana 60, t-case, V10 PI heads, CT
I have 4 Super Swamper Trxus Radial mud terrain 37x12.5x16.5 tires, about 30-50%, 2 are a little unevenly worn but still are fairly quiet onroad, 1 has a nail in the shoulder and has a slow leak, should be fine with a tube, $300 or BO
I have a transfer case out of a 2001 F350 V10 4x4 with 60k miles, good working order, $400 or BO Finally a Ford Front dana 60 out of a 2002 with roughly 80k on it, it is disassembled and needs hubs and ball joints, gears are good; 3:73s, shafts are good, $500 or BO Also a set of Ford V10 PI heads out of a 2001 F350, might need valve job, $350 or BO Paul Gun trades welcome.... http://good-times.webshots.com/photo...48904338UUsSqR http://good-times.webshots.com/photo...48904338VjfNmJ
"It doesn't look that deep..." 99 Ford F350 SuperDuty 7.3 PSD Ext. cab, LB, Garret GTP38R, AFE stage 2 intake, Bank Monster 4" catback, SCT Cortex, 05 grill, 4" lift, Bushwackers, ARB bumper, Warn 12K winch, 39x14.50 Pitbull Maddogs. |
#635 (permalink) |
putting the shitbox up for sale
97 f250 gas 351 4x4 auto 195,xxx +/-..............$4500.00
SAS (solid axle swap) 37/12,5/16.5 BFG baja TA's on 24 bolt beadlocks(military tires and rims) with rock rings welded,tires 85% or better,no plugs or gouges f350 front axle,f250 rear springs up front sterling 10.25 rear with 5.13 gears and a detroit locker threw away the rear drums and did the disk swap in the rear dana 60 (ball joint) front 5,13 gears and welded spiders 35 spline chromoly outers MM 35 spline lockouts 2" body lift dual electric fans with a custom stainless shroud,auto switch with a internal switch big ugly solid front bumper almost new(one pull) on a m15k warn winch with remote dual 1100 CCA batteries brand new 220 amp alt new smog pump new starter new water pump new u joints im in pittsburgh pa pm me,text,email or call 919 225 5413 carthief007@yahoo.com ![]() ![]() short video on daniel trail @ URE
97 f250...little bit of this n that rollin on 37's keith klos 919 255 5125 durham nc Last edited by carthief007; 03-08-2012 at 06:11 AM. Reason: put price |
#637 (permalink) | |
Bobbing for Fries
Member # 190574
Everything must go.
If everyone is thinking alike, then somebody isn't thinking.
#639 (permalink) |
Member # 146379
Big Rockwells and Tractor Tires
I have some big Rocks 18,000 lbs Axels with 9.33 gear ratio.and some 18.4 -26 R2s and two R1s, on rims 8 lug patten now. 2.5 gz for the Axels and 2,000 for the tires! Call or text 603/765/8318 I can send ya some pics!
TTC 2010- WELDOR |
#640 (permalink) |
Member # 121903
I'm parting a 98 ZJ, but I will sell the whole thing for $1500 if someone wants it. It has ~170k, 4.0, 42re, NP231 with AA SYE, 2" OME lift, 8.8 with IRO brackets etc. It runs and drives fine, and would make a good trail rig. It could pass inspection with minimal work. All prices are OBO, I will ship anything, but BUYER PAYS SHIPPING.
![]() ![]() All tires have at least this much tread left ![]() Parts details below: 31x10.5R15 Goodyear MTR's on steelies, good tread, see picture - all 4 - $300 Ford 8.8 set-up for a ZJ with IRO brackets, professionally rebuilt ~800 miles ago with an open carrier and 3.55's, will include fresh ebrakes, rotors and calipers - $300 LP30, stock with 3.55's - $50 2" OME kit, 4 medium duty springs, 4 shocks(one is dented but works well) and steering stabilizer, all with ~2000 miles - $300 NP231 with Advance Adapters SYE, unknown miles, shifts fine in all ranges, no leaks - $200 JCR stage 1 sliders, good shape and still line up well - $150 KOR radiator support - $25 Rusty's trackbar, with upper bushing conversion and frame bracket - $75 HD steering setup, V8 draglink and IRO HD tie-rod, with newish TRE's - $60 Durango steering box, <500 miles - $75 Full set of Alpine type S speakers - $50 5.9 soundbar with Alpines - $150 5.9 roofrack, no cross bars - $50 WJ black leather front seats on power ZJ bases, good shape, small tear on drivers side - $125 2" receiver hitch with shackle set-up - $50 Stock gas tank and transfer case skid - $50/both 2.5" catback Magnaflow exhaust with 5.9 tip - $50 B&M tranny cooler, <1000 miles, new fluid when cooler was installed - $30 Clear corner lights - $20 All OEM parts are for sale too, let me know what you need. Hood is junk, as well as both front fenders. Doors are OK, rear passenger side has a big dent, hatch is OK and has glass that opens.
94 ZJ 4.0/AX15/HP44/8.8/5.13's/35's In the northeast? Check out [url]www.undergroundjeeps.net[/url] Last edited by CTeunuch; 03-12-2012 at 06:04 PM. |
#641 (permalink) |
Member # 184680
I wish I had a little more cash to take the whole thing. I will take the trans cooler though.
2000 XJ, BJ 60 front, welded, 5.13's, 3 link, hydro assist, ruffstuff heims. D70 rear, detroit, 5.13's, discs. stretched. trail ready beadlocks. Fo-dee" iroks. Build. http://www.pirate4x4.com/forum/jeep-...ild-cheap.html |
#642 (permalink) | |
Whatever Works
Member # 128472
Looking for a Samurai transfer case. All I need is the housing that has no snapped bolts or anything. Don't need the gears.
Lakes Region NH. Parents live in Lowell area MA so I can be flexible. Thanks.
Samurai Build on a Low Buck Budget: The Tin Can Quote:
#644 (permalink) |
Member # 146379
1973 fj 40
Real nice shape, original paint, very very clean, all apart have everything but rear end, asking $1,200! Call /text for detailes
603-765-8318 I can send pics!
TTC 2010- WELDOR |
#645 (permalink) |
Member # 77925
WTS/WTT Ford F350 99 V10 6" lift, 39s, 4.56s,...
My 99 F350 V10 mud truck is back with a 01 V10 engine, trans, and rebuilt axle that actually goes straight now and sorta stays in one lane!!!! And 38.5" TSL SXs(75%) that scream at me at 50mph but dont shake the hell out of the truck like the last tires. New engine makes 35hp and 15 more Torque from the factory.
Truck has 6" Superlift, dual shocks up front, 2" SS headers, 3" exhaust, 4.56 gears from the factory, AFE intake, some rust, ladder bars, rear locker, ext cab, short bed. The bad; it has a hesitation and misfire from one or two of the cylinders, seems to be a COP, maybe a loose ground is sending codes. Looking for a SUV or car, $8K cash, guns, or a mix of all of the above. Please dont make stupid offers, there's $12K worth of truck here for $8K. I'm in Marlborough.
#646 (permalink) |
Member # 69547
Can you PM me pics?
95 Taco 4x4 2.7 - 4 linked front - 3rz-R151-4.7s - FJ80 axles F+R Build-up Northeast Toyota Crawlers |
#647 (permalink) |
Member # 124054
Looking for a driver drop 241c 27 spline input. Located in Springfield Ma. If you got one with the JB Conversions super short SYE I'd be interested in that too.
99 Wrangler Project Detroit Mongrel 5.3/4l60e, HPD60/14B coilovers etc... |
#648 (permalink) |
Hey anyone one in the southern new england or even NY or northern NJ have a Long Bed for a 1985 chevy. Shoot me a PM with the price and location if you got one. OH not looking for a Rotted mess needs to be useable but not perfect. and would like a tailgate too.
#649 (permalink) |
Member # 177602
Call Todd or Sully at Endangered Species Jeep 413-five three two- 0732....I am sure they have something lying around....
Spotter Team #734 Shameless Racing...Thanx to the sponsors: Extreme Axle, High Angle, Raceline, PSC |
#650 (permalink) |
Member # 152637
looking for a set of goodyear 37x12.50x16.5 mt military tires, located in southcoast mass, but dont mind making the trip for a good deal. PM me if you have any for sale or know of anyone selling them. thanks!
