#651 (permalink) | |
Granite State Guru
Member # 32585
http://summitcrawlers.com/forums/ind...showtopic=1856
'90 YJ |
#653 (permalink) |
Member # 155053
buy my shit please need cash will travel wont ship
Got a ford 203/205 triple stick dbler never ran need to b finished bein buil like cpl bolts and weld up shifters its from jeds
A art carr shifter that's new for c6 but will wrk for any tranny just need diff linkage A set of 14 inch coil overs from tk-1 racing 150 over 200 new griffan rad from t fab for yj part#5-587 I paid 575 A built 302 heads cams efi all forged h-beam rods I never ran it all new gaskets custom grind cam for crawlin etc Some yj body part a grille tailgate good tub all sanded down and truck bed coated underneith hi-line tube fenders in primer never run and cut hood to match a set of links for rear 4 link uppers7/8ths and lowers 1.25 hiems r from ruffstuff have ruff stuff truss/link mount for uppers and 10degree brackets for lowers a clean ass frame needs the tubes I have for back half welded on but has custom shackle reversal with winchmount flat bottom skid out of 1/r ince plate gennright rear 4 link brackets I got a new daystar bodylift for yj Idk I'm sure there is more make me offers I'm a motivated seller txt for picsim not here much so dnt send pm. 716-908-8686/ in buffalo ny will travel cpl hrs to meet
i've always been crazy its kept me from goin insane 02 350 4+3 38/15.50 claws d60/10.50 5.13's |
#654 (permalink) |
Member # 164604
Looking for a 42" tire for a trail spare. Some tread still left would be nice, but anything is better than what I have now. Needs to be 16 or 16.5, wheel not needed. An Irok would be my first choice, but whats out there? I'm in southeast pa, but will travel some for the right tire. Thanks.
Scott
81 CJ7, 60, 14 bolt and 42 Iroks 06 Belmont homebuilt toyhauler |
#655 (permalink) |
Member # 184680
lincoln 180HD mig
I bought this welder not too long ago. I need to rewire to use it and Im selling the house in a year so I dont want to spend the money to wire it right now.
The welder has minimal use and looks like new. 180 amp, 230v. Comes with everything but a gas bottle and wire. Has gas regulator to go with it also. I would also trade for 110v welder + cash. $550 This is the welder http://www.homedepot.com/buy/tools-h...er-158818.html
2000 XJ, BJ 60 front, welded, 5.13's, 3 link, hydro assist, ruffstuff heims. D70 rear, detroit, 5.13's, discs. stretched. trail ready beadlocks. Fo-dee" iroks. Build. http://www.pirate4x4.com/forum/jeep-...ild-cheap.html |
#656 (permalink) |
Member # 154345
TJ front D44 HD HP and D60 FF 5.13s 8 lug
$2,000.00 ******* Post for a friend of mine use this contact info: Call email or text Will @ 5706404336. Raibecwj@gmail.com************************* I have a set of axles coming out of my TJ. They are set up with 1/4 bracketry 4 link Clayton rear bracket setup. front is 79 ford Dana 44 heavy duty high pinion 5.13 gears, G2 alloys shafts. Flat top high steer arm and HD steering setup for 3/4 heims. Rear is Dana 60 full float 5.13 gears stock axles. Heavy duty diff cover. Disc brakes. These are full width. I can accommodate with additional and different bracketry if need be. For extra cost. Delivery is an option depending on distance. These are still in the jeep and can be seen running. I put them in last winter, they were completely rebuilt top to bottom, inside and out. Moog ball joints and new bearings and seals at the wheels and diffs. $2000 firm Lincoln locked. All done prior to installation, the carriers were check for trueness and reinstalled. Currently used with PSC hydro assist, cylinder can go with for more cash! Call email or text Will @ 5706404336. Raibecwj@gmail.com Installation available. WillFab.com |
#657 (permalink) |
Member # 177602
Look on craigslist in CT....i think there was a guy in Union? maybe sellin em...
Spotter Team #734 Shameless Racing...Thanx to the sponsors: Extreme Axle, High Angle, Raceline, PSC |
#658 (permalink) |
Member # 201028
SNAP-ON Rolling Toolbox + Toolsets + Airtools - PCT - $2500 (Gettysburg)
This set was purchased when I attended PCT a few years ago, I've since moved to CA and left to toolset at home with family due to the constraints of transporting this so far, it's not getting any use and I'd like to sell it. included is everything in the pictures. Everything that was bought in the original automotive technology set for $2300 and way more. This set includes a rolling bottom, complete impact set in metric/standard, super duty snap-on impact gun ($350, not pictured), electronic torque wrench, stubby ratchet wrenches mm/inch, flare nut wrenches mm/inch, 3/8 Hex set, extra length extensions and more. The set is missing a few pieces from some of the sets as seen in the pictures, but even at student cost's from PCT this price is VERY Discounted. GREAT toolset with room to build.
For local pickup in Gettysburg, PA. Want to get these sold THIS WEEKEND. $2500 if you pickup THIS WEEKEND 3/16-18 Matt 714 - five zero one - 5419 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#660 (permalink) |
Member # 174692
38x12.50x15, 5 brand new
I got 5 38x12.50x15 super swamper tsl. All are new and have no dry rot, patches or any wear. In pa zipcode 17053, $1200 takes all of them. Call or txt 717-574-2786. Can txt you pics, will try to post them here later.
90' toyota p/u sas,38" swampers, monkey cage, flat belly, yadda yadda yadaa... |
#661 (permalink) |
Member # 200568
looking for a 40s willys flatfender tub in NH, doesnt need to be perfect, just mostly there and repairable
Also in search of a set of 31 to 33 inch tires and jeep rims as wide as possible, need to be serviceable but not new have lots to trade, little to spend |
#662 (permalink) |
Learn to swim
Member # 174079
Neighbor has a 68 fj40 for sale.
http://www.cruizers.com/classifieds.cfm?adID=2232
Right der _______________________________________
#665 (permalink) |
Member # 208816
Saw it on the local CL the other day and drooled over it. I REALLY wish I had the money for it, it's a VERY nice set and I see idiots trying to sell an empty snap on tool chest for what you're asking for a full one! Good luck with the sale.
07 JK Unlimited Rubicon. 2.5" RC spacers. 35" MTR/K's on black MB72 15x8" wheels |
#666 (permalink) |
Member # 18614
That box has old school friction slides yet by the looks?
#667 (permalink) |
schleprock
Member # 88698
It has ball bearing slides. The top and bottom were about $1000 of the truck a few years ago...I bought one to have something smaller to take in the race trailer.
$2500 might be a bit high compared to what I've seen in the $5000 range on Craigslist. Your best bet is to sell all that stuff on eBay, or even talk to a snap-on guy...if the stuff is like new, he'll probably help you sell it. |
#668 (permalink) |
Member # 18614
The pic of the top with a drawer open does not look like roller slide's.
#669 (permalink) |
Member # 125507
Wanted: Dana 60 srw outers
Looking for a set of chevy dana 60 srw outers to convert over from drw. The axle is from an 82 if that helps. Thanks.
78 cj5 350sbc sm465 97 one ton s10 in the works Last edited by rstycj; 03-19-2012 at 05:38 AM. |
#671 (permalink) | |
Member # 84464
God Bless America |
#672 (permalink) |
TJ parts
Well since my GenRight stretch package will be arriving tomorrow I'll have some parts for sale. I should have the armor removed by the weekend. Nothing structurally wrong just cosmetically. All items are for 97-06 TJs. I can take some pics tomorrow in the daylight for anyone interested. Post up your email. Message me here or at beerman77@aol.com.
*First item is Smittybuilt XRC corners with the optional 3" flare. They will need to be repainted. New from 4WD they would be almost $400 plus shipping. Asking $175 OBO for both. http://www.4wd.com/Armor-Protection/..._pn=S%2FB76874 *Also have a pair of Sun Performance rocker guards. Again nothing structurally wrong but could use some paint. Asking $75 OBO. /forum/body-armor/752142-rocker-guards-jeep-tj-yj-cj.html * Factory gas tank with factory skid and Sun Performance tank skid. I'll be keeping the pump, etc to swap onto my GenRight tank. Asking $50. /forum/body-armor/874553-sun-performance-tj-gas-tank-skid-clearance.html By the end of April I will also have a complete set of Clayton short arms as I swap to their long arm stretch. Arms are in great shape. Asking $650. http://claytonoffroad.com/product_in...products_id/77 |
#673 (permalink) |
Member # 201028
Bottom box DOES have ball bearing slides, the top I think has ball bearing slides but I can check.
Honestly fellas, anyone who's bought Snap-On tools off the truck knows what a killer deal this is. Last edited by ls1impulse; 03-19-2012 at 08:48 PM. |
#674 (permalink) | |
Member # 125507
PM sent
78 cj5 350sbc sm465 97 one ton s10 in the works |
#675 (permalink) |
Member # 84464
yes. i think i drilled those for a long dually rear stud (with thicker knurl) so id have the option to make a 1/2" spacer if anything rubbed... id have to check to be sure. but they definitely are drilled for a stud, id just have to poke around and figure out which dorman # theyre set up for.
God Bless America Last edited by mike_belben; 03-20-2012 at 11:22 AM. |
