Northeast forsale wanted and trade!!-POST ONLY HERE - Page 30 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Northeast
Old 04-29-2012, 07:59 PM   #726 (permalink)
Member # 85204
Send a message via AIM to CtChevy
hope you added an extra 0 by accident
CtChevy is offline   Reply With Quote Quick reply to this message
Old 04-29-2012, 08:50 PM   #727 (permalink)
Member # 17423
Send a message via AIM to BeerStud
TJ parts
Few things for sale left over from my stretch install. All items for 97-06 TJs. May work on others but thats up to you.
Set of 4 Rubicon Express Extreme-Duty Mono-Tube Shocks for a 97-06 TJ with 3.5 to 5.5in of lift. They aren't gonna work with the long arm stretch setup so they gots to go. Part #s RXJ701 and RXJ702. Looking for $150 OBO.
http://www.rubiconexpress.com/JeepPa...TB&part=RE1620
RE part # 1620 for TJs with 4-7in of lift. Bushing is in ok shape and heim is tight. Only reason for sale is switching to a 4 link. $80 OBO
Also have a Tom Woods Constant Velocity (CV) double cardan type drive shaft. Had it on my TJ with RE 4.5in springs. Approximate running length is 18.25 inches from end of yoke to yoke. Recently rebuilt the centering ball and with new Spicer 1310 ujoints. $225 OBO.
All items are in Bethel, CT. Email me at beerman77@aol.com or post here.
BeerStud is offline   Reply With Quote Quick reply to this message
Old 04-30-2012, 07:28 AM   #728 (permalink)
Member # 157355
Np 208
NP 208
$50
Corning NY area. PM me
Minimal mech. knowledge, overly ambitious
Pokeman is offline   Reply With Quote Quick reply to this message
Old 04-30-2012, 08:19 AM   #729 (permalink)
Member # 108937
Yes, fixed now
72c20 is offline   Reply With Quote Quick reply to this message
Old 05-01-2012, 06:23 PM   #730 (permalink)
Member # 108937
Stock long dana 300 output shaft needed asap.. let me know of anything you have... can contact me at 207-478-7342 thanks, Nick
Old 05-02-2012, 07:08 AM   #731 (permalink)
ct67_72's Avatar
Member # 184680
35" bfg KM1
35" KM1. This was my spare. it literally has 22 miles on it. Its mounted on a 15x8 3.75 backspace d window, that is bent. Will sell with or without the rim. 5x4.5.
100$ with the rim.
2000 XJ, BJ 60 front, welded, 5.13's, 3 link, ruffstuff heims. D70 rear, detroit, 5.13's, discs. 4:1 Klune/twin sticked D20. stretched. trail ready beadlocks. 39" reds. PSC full hydro.
Build.
CHECK WITH ME FOR GREAT PRICES ON YUKON, PSC, USA, EATON, SPARTAN AND MUCH MORE.
ct67_72 is offline   Reply With Quote Quick reply to this message
Old 05-02-2012, 09:25 AM   #732 (permalink)
rstycj's Avatar
Member # 125507
14 bolt c&c hubs $150, RUFF STUFF 14 bolt c&c caliper brackets $40 c&c axle shafts $100, drum backing plates in good shape $30, (2)dana 44 and (2) 10 bolt flattop knuckles $40 per pair, DRW 60 hubs $100 pair. Also have 2 Ford dana 60 fronts BOM# 610313-3 and 610220-2 $475 each. All best reasonable offers
78 cj5 350sbc sm465
97 one ton s10 5.3/sm465/NP203/205
rstycj is offline   Reply With Quote Quick reply to this message
Old 05-02-2012, 10:20 AM   #733 (permalink)
bobbing for fries
billy bones's Avatar
Member # 190574
I could use the chevy 44 flat tops. PM sent.
If Everyone Is Thinking Alike, Then Somebody Isn't Thinking
billy bones is offline   Reply With Quote Quick reply to this message
Old 05-02-2012, 10:23 AM   #734 (permalink)
ct67_72's Avatar
Member # 184680
Originally Posted by ct67_72 View Post
or complete housing with knuckles. I bought the axle for the spindles out.
Good flat top knuckles, good housing, not sure on gear ratio. complete minus spindles out and outer axle shafts. good inners.
100$ OBO
50$ for the pair of knuckles or 100$ for the axle with good inner shafts, no outers.
Build.
Old 05-03-2012, 01:40 PM   #735 (permalink)
Member # 217358
still for sale
still for sale?
OLDESOUTH43 is offline   Reply With Quote Quick reply to this message
Old 05-04-2012, 11:12 AM   #736 (permalink)
Member # 118372
ct67...tire still for sale? PM sent
gregor0585 is offline   Reply With Quote Quick reply to this message
Old 05-04-2012, 02:33 PM   #737 (permalink)
ct67_72's Avatar
Member # 184680
All tires are sold.
I am not using the 44 outers anymore so u have the complete gm 44 hub to hub, even rollers. All in good shape. One side dissasembled.
$150
Build.
Old 05-07-2012, 02:12 PM   #738 (permalink)
Member # 131958
Crawler For Sale
Bad Ass 1982 Toyota 4x4 Tube Chassis Crawler. Full exo-cage with a truggy rear, Custom four linked Front and Rear with Poison Spyder Parts, At the corners it has Walker Evens Air Shocks. For axles: Up Front: Toyota axle with Longfield Super axles, Detroit Locker, 4:10’s, and Six Shooter Steering Knuckles. Rear: Stock Toyata Welded with 4:10‘s. Engine is a stock 1982 Toyota block with 1989 Fuel Injection, custom snorkel, Fuel Cell. T-case is a Marlin Ultimate Crawler twin stick with a 190:1 crawl ratio. Drive Shafts are custom made from High Angle Driveline (you can park these shaft on a rock…..they are that tough). Custom disk brakes on the rear with a FJ 80 Master Cylinder, Up front it has 38" TSL SX‘s, and on the rear there are 38" TSL Boggers they are mounted on Eaton 32 Bolt Beadlocks. Full Hydraulic Steering by PSC with a huge 2.5” bore ram, PSC pump as well as a PSC Orbital Valve, Cooler and Reservoir. I have a Superwinch Epi 9000 winch up front and a Superwich GT 3000 in the rear. I have mounted 8 KC lights on the cage. All powered by 2 Optima Blue Top Batteries. On the inside of the cab I have made a custom dash cover with all my switches for the lights, starter, etc (nothing to special) . Two APC racing seats with RCI Platinum 5 point harness’s and of course I have tunes in the form of a JVC CD player pumping out sound thru Bose speakers. Storage Rack, High Lift Jack, Extra Fuel Jug
Email Me for Info dave@ls-usa.com
Click On Links Below For Pictures
Serious Inquires Only
http://www.facebook.com/media/set/?s...type=3&theater
http://www.facebook.com/profile.php?...type=3&theater
"It takes only one drink to get me drunk. The trouble is, I can't remember if it's the thirteenth or the fourteenth."
1995 Jeep Cherokee built for TREC #10
1982 Toyota with a few minor adjustments
StumpDaddy is offline   Reply With Quote Quick reply to this message
Old 05-08-2012, 05:19 PM   #739 (permalink)
Member # 200826
looking to do a solid ax;e swap on an 80-96 f150
in need of a dana 44 around nj, if its completely set up for the swap that would be awesome!
rclark12 is offline   Reply With Quote Quick reply to this message
Old 05-09-2012, 06:18 AM   #740 (permalink)
rugg2kwgp's Avatar
Member # 50551
Send a message via AIM to rugg2kwgp
Parting out Samurai
Specs:
New Flat Belly Skid
Tubed Front Clip w/lowered hoodline
Tubed Rear w/spare tire mount
Wilwood Proportioning Brake Valve
New Master Cylinder
Full Cage with "X" brace behind seats, fully tied into frame, cowl and rear tubing work.
Rocker Skids Attached to frame and cab.
Engine:
Hand built from the block out:
1.8L VW 8 Valve Gas engine
German Cast Block (the good stuff)
Forged Crank
Forged Rods
Lightened flywheel
Factory Lightened Cam Gears
CIS Mechanical Fuel Injection
Solid lifter head w/big valves
10.5:1 Compression Pistons
Electronic Ignition
Chromoly Rings ($400 alone)
168 Grind Cam
Bigger A2 Throttle Body
A2 Intake
Dual Outlet Exhaust Manifold
Gear Reduction Starter
GM 1 Wire Alternator
GM Power Steering Pump
Rear Mounted VW Radiator with 2 Fans
Runs Cool in the woods all day long
Brand new water pump
New Timing Belt
Custom Adapter to Sidekick Bellhousing
Runs very strong
$500
Driveline:
Toyota G52 Transmission
AA Dual Toyota T-cases
2.28 Gears in front case
4.71 Gears in rear case w/twin stick
$1300
SOS RingeR adapter to mate to sidekick bellhousing $350
Cable Operated Clutch
Axles:
1985 Fully Trussed Front, Shaved,30 spline Longfields, Bobby long hub fuses, 4:10's, Lock-rite, 4 Cyl third, V6 4 Piston Calipers, Vented Rotors, Stainless brake lines, setup for 3 link front. $650 Pending.
1985 Rear, Fully Trussed across the rear (pre-runner style), Shaved and Plated, V6 Gears with 29 Spline Pinion, 4:10 gears, welded, disk drakes, new brakes in the last year, 3/8 Grade 8 Third Mounting Studs and Hardware (huge upgrade over stock), Stainless Brake Lines $300
1.5 wheel spacers-SOLD
2 12inch SAW air shocks SOLD
Steering:
Psc full hydro with 8 inch 2.5 ram,p-pump. SOLD
Wheels and Tires:
4-37 inch red label Krawlers on pro comp wheels, like new
Brand New Full size spare mounted on back
1 brand new never mounted 37 inch
6 in total. SOLD
Everything without a $ is BO.
fuel cell- 28.5h 12w 10h
holds around 15 gallons
$75
4 skyjacker shocks
center of eye to center of eye- 20compressed 34.5extended
$45 a set
T-Max 6500 winch
needs control box, i do have 2 of these if someone wants to redo the wiring inside and make a good one. Wires corroded
$400
Miller Motorsports #4421
rugg2kwgp is offline   Reply With Quote Quick reply to this message
Old 05-09-2012, 06:31 AM   #741 (permalink)
Member # 36072
Lots of activity here! Nice.
Anyone have use for a 4L80E trans? Was bolted to a military diesel (6.5L H1?)
Anyway, trans is a used take-out, should be considered a core, because I don't know the history. $400 obo.
Buy some of my crap in the classified section , mkay?
BIGJMCCONNELL is offline   Reply With Quote Quick reply to this message
Old 05-09-2012, 08:43 AM   #742 (permalink)
5zukyard's Avatar
Member # 139059
Originally Posted by 88lsiroc View Post
For sale 88 sami front clip 8 out of 10. No dents battery tray good. Little rust front and rear of the flare mounts. Flares or hood are not included. $100.00 local pick up. Northeast Pa./Poconos zip 18353.
Pm for pics.
pm'd you
When in doubt...gas it!
5zukyard is offline   Reply With Quote Quick reply to this message
Old 05-09-2012, 08:51 AM   #743 (permalink)
Member # 149057
Looking for any JD2 Model 3 dies, please pm if you have any for sale?
Also looking for a recommendation for regular (non-DOM) tubing in the Delaware/Philly area.
hyghlndr is offline   Reply With Quote Quick reply to this message
Old 05-09-2012, 02:32 PM   #744 (permalink)
Member # 130142
looking for a 2 or 3 cylinder kubota diesel engine, preferably running. let me know what you got
76 k-10 stepside 44/14 d60 going under soon 305 h.o huge cam roller rockers and megasquirt sm465/205
smokewrench is offline   Reply With Quote Quick reply to this message
Old 05-11-2012, 07:24 AM   #745 (permalink)
Member # 154345
sold
Schuylker is offline   Reply With Quote Quick reply to this message
Old 05-11-2012, 07:02 PM   #746 (permalink)
Member # 121139
305/70/16 AT/S x 5
Sold tires
Also have a set of Big Beige Disco 2 cupholders (WITH INSERTS) 40$ + shipping
Email is best at Gt3454 at aol . com
Grant
2002 Disco 2 4.6/TT/Detroit/7100 3"RTE and RTE Front/back/sliders SD rack OBA
Gt3454 is offline   Reply With Quote Quick reply to this message
Old 05-12-2012, 04:26 AM   #747 (permalink)
Member # 172856
Wanted to get a feeler for my axle setup. Off a 2008 JK.
D30:
Yukon 4.88s
Yukon Grizzly Locker
EVO sleeves
EVO c-gussets
EVO LCA skids
PP drag link
RK bent tie rod, lol
Rough Country LCAs
Warn lower half diff cover.
Sets of passenger and driver spare axle shafts
Set of unit bearings
Set of front spare driveshafts
Stock control arms
D44:
Yukon 4.88s
Detroit Locker
JKS weld-on trackbar reinforcement (axle end)
Set of spare axle shafts with bearings pressed on already
Set of spare driveshafts
Stock control arms
Axles will be rolling on 15x8 3.75" BS Cragar V5 with custom rock rash on 50% 35X12.50 MTR Kevlar. Ready to be bolted into your truck and wheeled. One is brand new, never mounted, still has shine. 5 total rims/tires.
$2,500 located on Long Island, NY.
Suffolk JK is offline   Reply With Quote Quick reply to this message
Old 05-15-2012, 12:03 PM   #748 (permalink)
Member # 178027
Race Jeep
Looking for a Race Jeep to run at southwick mx needs to be set up for wheel to wheel racing 860 942 2377 thanks
Jeepman401 is offline   Reply With Quote Quick reply to this message
Old 05-15-2012, 05:37 PM   #749 (permalink)
CTeunuch's Avatar
Member # 121903
I'm selling a 98 ZJ, looking for $1500. It has ~170k, 4.0, 42re, NP231 with AA SYE, 2" OME coils and shocks, 8.8 with IRO brackets, 31" Goodyear MTR's with ~50% tread, IRO HD tierod, KOR radiator support, Rusty's trackbar, Durango box, 5.9 rack and soundbar, Black WJ leather front seats a B&M tranny cooler and some other things I'm sure I'm forgetting. It runs and drives fine, and would make a good trail rig, but it could pass inspection with minimal work. The jeep needs a bumper, has a check engine light for insufficient catalyst efficiency, most likely caused by the high flow cat, and can be fixed with an o2 sensor spacer and the rockers are a little rough. Otherwise there aren't any major issues.
I will consider trades for a 4 cyl 5 speed commuter car in decent shape, don't really care what make/model, a Toyota truck, possibly a Zuk, or a KX250.
94 ZJ 4.0/AX15/HP44/8.8/5.13's/35's
In the northeast? Check out
CTeunuch is offline   Reply With Quote Quick reply to this message
Old 05-16-2012, 11:19 AM   #750 (permalink)
ct67_72's Avatar
Member # 184680
35"km1 back for sale. 22 miles
Friend of mine bought this and before he got to pick it up he got a deal on 5 new tires. So back for sale.
22 miles on it, only driven off the trail and home. always stored inside vehicle or inside garage. Mounted on a 15x8 4"BS 5x4.5 rim thats bent. Ok to drive on but not straight.
100$ with or without rim
Build.
