#751 (permalink) |
Member # 121903
I'm selling a 98 ZJ, looking for $1500. It has ~170k, 4.0, 42re, NP231 with AA SYE, 2" OME coils and shocks, 8.8 with IRO brackets, 31" Goodyear MTR's with ~50% tread, IRO HD tierod, KOR radiator support, Rusty's trackbar, Durango box, 5.9 rack and soundbar, Black WJ leather front seats a B&M tranny cooler and some other things I'm sure I'm forgetting. It runs and drives fine, and would make a good trail rig, but it could pass inspection with minimal work. The jeep needs a bumper, has a check engine light for insufficient catalyst efficiency, most likely caused by the high flow cat, and can be fixed with an o2 sensor spacer and the rockers are a little rough. Otherwise there aren't any major issues.
I will consider trades for a 4 cyl 5 speed commuter car in decent shape, don't really care what make/model, a Toyota truck, possibly a Zuk, or a KX250. ![]() ![]()
94 ZJ 4.0/AX15/HP44/8.8/5.13's/35's In the northeast? Check out [url]www.undergroundjeeps.net[/url] Last edited by CTeunuch; 05-15-2012 at 04:38 PM. |
#752 (permalink) |
Member # 184680
35"km1 back for sale. 22 miles
Friend of mine bought this and before he got to pick it up he got a deal on 5 new tires. So back for sale.
22 miles on it, only driven off the trail and home. always stored inside vehicle or inside garage. Mounted on a 15x8 4"BS 5x4.5 rim thats bent. Ok to drive on but not straight. 100$ with or without rim ![]() ![]()
2000 XJ, BJ 60 front, welded, 5.13's, 3 link, hydro assist, ruffstuff heims. D70 rear, detroit, 5.13's, discs. stretched. trail ready beadlocks. Fo-dee" iroks. Build. http://www.pirate4x4.com/forum/jeep-...ild-cheap.html |
#753 (permalink) |
Member # 184680
trade GM 44 for ford
I have a mid 80's chevy 44. not sure on ratio, can find out easy enough if need be. 6 lug. complete end to end, flat top knuckles. Bought it for the outers then changed my plans.
will trade for 8 lug drivers drop 44
#755 (permalink) |
Member # 184680
36x13.5x15 irok spare
36x13.5x15 Bias Irok. maybe 10% tread. Holds air fine. I actually just dismounted it, had been on my jeep until yesterday.
Bad pic, but its the third one down ![]() 30$ In Meriden Ct.
#757 (permalink) |
Member # 27978
http://www.quadratec.com/products/12112_221_07.htm
These came off the wife's JK. Put them on but she needed steps (she is only 5'1") to get in once the lift was on the JK. 200 takes them SE PA
www.rauschcreekoffroadpark.org |
#758 (permalink) |
Member # 131958
Custom Crawler For Sale
Click on link to Redirect
/forum/vehicles-trailers-sale/1067667-custom-crawler-sale.html
"It takes only one drink to get me drunk. The trouble is, I can't remember if it's the thirteenth or the fourteenth." 1995 Jeep Cherokee built for TREC #10 1982 Toyota with a few minor adjustments [URL="http://www.myspace.com/stumpdaddy"]http://www.myspace.com/stumpdaddy[/URL] |
#759 (permalink) |
Member # 23452
Dodge 241 passside with a chevy 27 spline input in it, have the Dodge 23 spline for it also. clean and painted black 100.00.
Divorced 203 Ford case, good for a divoreced 203/205 combo. Have two of them, one with the input all ready out. 150.00 for the gear thats out and 100.00 for the other case. Divorced dana 20 from a nissan patrol truck. 100.00 Divorced dana 20 AA input gear and adapter, this will fit a model 20 case or a model 18 from a willys, just need to swap the gear on 100.00. Mostly all dana 60 stuff. Chevy housing with knuckles and 4.56's gears 175.00 OBO Chevy NON neck down shafts inners and outers 75.00 long side 50.00 short 20.00 for the stubs. Chevy brake caliper brackets, 20.00 a pair. Chevy DRW hubs machined down to SRW's still need the hole's drilled for the studs 125.00. Empty Chevy housing, no gears and no caps just the C's 100.00 OBO. Ford 85 up inner axle's 75.00 long side 50.00 short. 5.13 LP used gears, not sure the brand 100.00. With all the parts I have I can make a SRW Chevy axle with 4.56's and the SRW machined hubs. I can do this as a package deal just dont' have time to assembe it. 400.00 OBO for the package. Pics if you need them, just post up. All parts are located in Holland mass. Sorry don't really have the time to ship and cash talks. Jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money. |
#760 (permalink) | |
under house arrest
Member # 208357
#762 (permalink) |
Always Busted
Ford dana 60 stubs, H1's, 38's
2 - 30 spline dana 60 stubs, good joints. $100
3 - Ford 1/4 turn hubs - $50 4 - stock h1's with o-rings and nicely cut down mag inserts - $250 Sale pending 4 - 38/12.50/16.5 tsl's slightly above the wear bar - $300 ![]() Will post pics tonight of the wheels, inserts and tires. Throwing the drive flanges in later this weekend so when the stubs are out I'll post those up as well. Uniontown, PA
Fawk yea, redline that shit Last edited by Stranger ranger; 05-25-2012 at 05:41 AM. |
#763 (permalink) | |
Member # 131536
95 ram 3500 cummins:nv5600, divorce np205, kingpin dana 60 on leafs. 84 ramcharger/buggy:360,727,np205,60,14bff,linked rear,fox air shocks,40'' rockers./forum/dodge/911907-no-ordinary-ramcharger.html 89 jeep wrangler:cj front clip,1 tons,37s and h1s. R.I.P Will/jeepon1tons |
#767 (permalink) |
Member # 131536
I was intrested in the h1s but I see sales pending now.let me know if it falls through
95 ram 3500 cummins:nv5600, divorce np205, kingpin dana 60 on leafs. 84 ramcharger/buggy:360,727,np205,60,14bff,linked rear,fox air shocks,40'' rockers.http://www.pirate4x4.com/forum/showthread.php?t=911907 89 jeep wrangler:cj front clip,1 tons,37s and h1s. R.I.P Will/jeepon1tons |
#768 (permalink) |
Member # 200826
Looking for either
-35 or 36 inch tires, 12.5 - 14.5 wide for a 15 inch rim, mud terrains or/and - any set of 4 tires 30-35 inches for a 15 inch rim litterally if its 10% tread I can live just need these to move truck around on drive way need em cheap and asap text or call ryan at 908 227 5747 or just pm me |
#769 (permalink) |
Member # 184680
I need a set of xj leafs. Preferably 3.5" lift springs. but any lift spring will work. I bent a main leaf today and my pass side is riding on the bump stop.
#770 (permalink) |
FS: 2005 Dodge Ram Quad Cab Diesel 2500. Southern Vermont.
/forum/vehicles-trailers-sale/1067947-fs-2005-dodge-ram-2500-quad-cab-diesel.html |
#771 (permalink) | |
Member # 114810
#773 (permalink) |
Member # 200826
TRADE or Sell 15" rims 5x5.5
Hey guys I have a nice set of after market rims on my 93 f150, 15 inch, 5x5.5 deep dish not sure of width at the moment, 2 of them have real good 33x12.5's
I really hate to sell 'em but doing a solid axle swap and the axles are 8 lug I will trade for preferably a 15" 8 lug set up, will pay more if they have 35-36 on them or sell out right for 600 will take offers but trade saves me some time pics- text 908 227 5747 |
#774 (permalink) |
Member # 135814
Bilstein 7100s. One pair of 12" travel short bodies 255/70 valving. Never been run but a few scratches from being installed once. $350. located in 07764 NJ. Not looking to ship at the moment but can meet up within a reasonable distance. PM me if interested.
94 XJ.. RE 3.5. 31's etc 96 XJ.. 5.5 3link Locked F/R Caged etc. |
