Northeast forsale wanted and trade!!-POST ONLY HERE - Page 33 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Northeast
Old 06-17-2012, 11:07 AM   #801 (permalink)
ct67_72's Avatar
Member # 184680
2 tires are brand new, have maybe 300 miles on them, you can still see the mold lines on the tread.outer lugs have some chunks as I have wheeled them about 4-5 times
2 are worn a little uneven but about 60% tread. Typical wear for a tire wheeled in the rocks.
1 spare 10-15% tread
15x8 black d-windows. 2 are brand new procomps and 2 are older and a different brand. they are 3.75" BS
1 the spare is on is older and 4.5" BS. 5x4.5.
Ill get some better pics if need be. these are all I have right now
I just paid $636 for 2 of them.
Ill take 800$ for all 5
2000 XJ, BJ 60 front, welded, 5.13's, 3 link, hydro assist, ruffstuff heims. D70 rear, detroit, 5.13's, discs. stretched. trail ready beadlocks. Fo-dee" iroks.
Build. http://www.pirate4x4.com/forum/jeep-...ild-cheap.html
ct67_72 is offline   Reply With Quote
Old 06-17-2012, 06:32 PM   #802 (permalink)
Highrolleres's Avatar
Member # 131536
Originally Posted by Beaniam View Post
Selling my treadwright guard dogs 4x 8 lug 315/75/r16
Complete details here http://jerseyshore.craigslist.org/pts/3083402823.html
Located in New Egypt NJ.
what load range are they?would you selll just tires i have a tire machine.
95 ram 3500 cummins:nv5600, divorce np205, kingpin dana 60 on leafs.
84 ramcharger/buggy:360,727,np205,60,14bff,linked rear,fox air shocks,40'' rockers./forum/dodge/911907-no-ordinary-ramcharger.html
89 jeep wrangler:cj front clip,1 tons,37s and h1s.
R.I.P
Will/jeepon1tons
Highrolleres is offline   Reply With Quote
Old 06-17-2012, 07:31 PM   #803 (permalink)
lojim's Avatar
Member # 131580
http://www.pirate4x4.com/forum/showt...7#post14478787
1989 e350 diesel conversion van - $4500 - Jim Thorpe PA (make offers)
2006 Durango HEMI, SCX-10 JK, Losi Micro
...someone tell my wife i'm not crazy...
lojim is offline   Reply With Quote
Old 06-19-2012, 07:44 AM   #804 (permalink)
Member # 108937
http://maine.craigslist.org/pts/3056742478.html
Call or text is best
72c20 is offline   Reply With Quote
Old 06-19-2012, 07:45 AM   #805 (permalink)
Member # 108937
http://maine.craigslist.org/cto/3075992648.html
call or text is best
Old 06-19-2012, 07:47 AM   #806 (permalink)
Member # 130142
just picked up a 86 toyota truck and am looking for a good 6 foot bed, dont mind a few dents but prefer not rust or rot(the rest of the truck doesnt have any).
76 k-10 stepside 44/14 d60 going under soon 305 h.o huge cam roller rockers and megasquirt sm465/205
smokewrench is offline   Reply With Quote
Old 06-19-2012, 07:22 PM   #807 (permalink)
Member # 75424
BRY74, I just sent you a text about the Guard Dog tires.
Calvynandhobbs is offline   Reply With Quote
Old 06-20-2012, 12:21 PM   #808 (permalink)
the freeak's Avatar
Member # 41185
Another Garage Sale Post
All Located in Effort PA, 18330.
__________________________________________________ _____________
SM 465/ NP 205
Originally in my plow truck.
10 spline coarse output on trans, single shifter tcase, 1310 CV output on front, 1310 ubolt rear.
Includes new used GM hydraulic bell housing
Trans shifter was welded at shifter ball interface for more precise shifts.
Both shift smoothly, no metal in the oil, no popping out of gear.
Asking $600.
1986 Ford V8- 302/ 5.0
New water pump, new (never run) hydraulic cam (NOT roller cam) with a mild grind, good for low to mid range torque/ power. Recent Cloyes double roller timing chain (less than 10K since t-chain).
Includes fuel injection intake, (upper and lower, throttle body and spacer, fuel rails, NO INJECTORS)
This engine was removed from a car that I had driven for about 18 months. Did not burn oil, ran really well.
Asking $600
USED Rubicon Express Jeep XJ Long Arm kit, FRONT LONG ARM SUSPENSION ONLY
Needs new axle side lower control arm bushings (originals included, but they’re beat)
Does NOT include all mounting hardware.
Includes Crossmember and reinforcement brackets, upper and lower radius arm assemblies, track bar and frame bracket.
Upper arms were reinforced with heavy wall DOM; doesn’t look pretty, but it’s solid.
This kit came off a jeep that was used off road. It has rock rash on lower control arms, and the skid.
Asking $500.
Kentrol Stainless Steel CJ Windshield Hinges
Brand new, with hardware.
Asking $100
GM 305 V8, used.
Ran when pulled.
Carb intake.
Unknown mileage.
$50/ Make offer.
GM 350 V8, used.
TBI intake/ throttle body/ wiring harness.
Unknown mileage, turns over by hand
Asking $100.
Two (2) Ford NP205's nice condition, $200 each.
Delivery possible in NJ, PA, NY
Prefer Cash, Money order, or Paypal.
Delivery/ shipping possible on all items, buyer pays shipping/ gas.
EDIT: 21 July 2012:
Updated what is no longer available.
I'm also open to full / partial trades for the following:
All Terrain Tires in a 33-35" size (For a 15" Rim), and for MT tires in 35-37" size (For a 15" or 17" Rim)
Tires must be in good condition. 75% or better tread.
Also interested in a D300 for a jeep.
And/ Or Ford Explorer (or equivalent XJ 44/ 9") 8.8 with 4.10's (OR lower) and disc brakes.
Thanks.
Chris
the freeak is offline   Reply With Quote
Old 06-20-2012, 12:53 PM   #809 (permalink)
ct67_72's Avatar
Member # 184680
Dana 70 full float rear axle- 8 lug, 6.5” pattern.
5.38 gears, Detroit locker, 35 spline Dutchman shafts
GM ¾ ton disc brake conversion.
Stripped of all brackets.
Asking $900
Im very very interested in this axle. I am currently parting mine out. when do you need it gone by? how old is the ring and pinion/locker?
Old 06-20-2012, 01:03 PM   #810 (permalink)
ct67_72's Avatar
Member # 184680
Originally Posted by ct67_72 View Post
Time to go. Just tracked down a noise to a couple broken pinion teeth. So I guess its time to upgrade.
Front will have a brand new gear set installed before its sold.
Front 30
Nitro 4.88 gears, new bearings etc.
Aussie locker
New spicer carrier.
New ballistic lower mount on pass side, drivers side is plated but will come with a new ballistic mount.
Mini truss out of 3/16 square tube
WJ knuckles, JKS 1/4 spacers, new style, brand new (300 miles) Akebono dual piston calipers. Brand new rotors drilled for 5 on 4.5
one new spicer u joint. spare shafts. new yoke
very recent spicer ball joints
I think thats it for the front.
Rear 8.25
nitro 4.88 with new bearings
Aussie locker
Stock drums
welded bump plates from axle
yoke drilled for u-bolts.
newer wheel seals
will come with crossover steering to bolt into xj. stock WJ steering was shortened and sleeved with 3/16 DOM.
only pics at the moment. They will be ready to bolt in and run.
$1500
I might seporate but im not sure what I want seporate. I have a lot of money in the front, with the brakes and all
Located in Meriden CT
parting these out. some parts already sold.
still for sale
8.25 complete minus locker with 4.88's 29 spline. 250$
Front axle minus all outers and locker, although can include stock xj knuckles, with chipped pinion gear 175$
5 36" iroks. 2 brand new 800$
NEEDS TO BE GONE!!
Old 06-20-2012, 04:36 PM   #811 (permalink)
Member # 23452
Got a SRW 88 Ford dana 60. The axle is complete from locking hub to locking hub. Was pulled from a plow truck and has the normall NewEngland crust and rust.
3.55 gears, open diff, warn locking hubs and NON neck down shafts.
Asking 650.00 cash and sorry I can't ship the axle. The axle is located in central mass and I can load it with a skid steer.
I can get few Pics of the axle but It looks like your normall Ford dana 60.
Jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money.
420willys is offline   Reply With Quote
Old 06-21-2012, 06:05 AM   #812 (permalink)
Member # 137639
still for sale
NEEDS TO BE GONE!!
can you give me a call Interested in the tires as well maybe the rear axle
Im in Northern NJ 910-352-8367
02 TJ on 33 (working for now), 79 FSJ on 33 (Broke), 03 sas KJ on 36 irocks (Sold)
ohv_kj is offline   Reply With Quote
Old 06-21-2012, 06:07 AM   #813 (permalink)
KingTheZJ's Avatar
Member # 174855
pics please!
KingTheZJ is offline   Reply With Quote
Old 06-21-2012, 07:32 AM   #814 (permalink)
ct67_72's Avatar
Member # 184680
Originally Posted by KingTheZJ View Post
pics please!
I posted some pics farther up the page but no close ups. when I get home I can take actual tread pics.
here are a couple more
Old 06-21-2012, 07:33 AM   #815 (permalink)
KingTheZJ's Avatar
Member # 174855
shoot, they are probably 15". thanks anyway
Old 06-21-2012, 07:36 AM   #816 (permalink)
ct67_72's Avatar
Member # 184680
Oh and this is the spare
Old 06-22-2012, 04:40 AM   #817 (permalink)
Member # 81923
Send a message via AIM to akaphilly
84 pickup longbed. bobed 18 inchs. 94 22re with ORS standalone 22re harness. dual cases, driveshafts, fuel cell and some more.
comes with no axles. no springs. no steering box. and no bumpstops.
lookin for 1300, or trade for like new 37-38 inch tires. dual sport dirtbike, or decent lightweight car trailer.
fj 80 steering box... just got off ebay and dont need it. still can return but thought i'd list it for a few it cost me 170... n gona cost another 20 if i return it. so 170 takes it.
akaphilly is offline   Reply With Quote
Old 06-22-2012, 08:21 AM   #818 (permalink)
EStenzJ4's Avatar
Member # 42369
Send a message via AIM to EStenzJ4
2002 Chevrolet Silverado 1500 Extended Cab LS 4 Door Z71
162000 Miles
5.3 liter V8
Automatic Transmission
Shift on the floor 4WD
Truck has Wheels from a 2003 Silverado on it with 265/75/16 Michelin LTX Tires
Bed Has Line-X Spray in Bed liner
Remote Start with Keyless Entry and Factory Alarm
Power Locks
Power Windows
Power Mirrors
Factory Radio CD Player
Work done and parts replaced within the past couple years:
Emergency Brake Pads and Backing plates
Rear Differential Fluid Changed
Fuel Filter
Transfer Case Fluid Changed
Spark Plugs and Plug Wires
Brake Pads and Rotors All Around
Front Wheel Bearings
Passenger Side Rear Brake Caliper
Starter
Battery
Truck will need the rockers done on both sides of the truck.
The driver’s side rear door has a couple small dents in it, does not affect anything but looks.
There are some spots that could use a little touch up paint.
The Tailgate has something broke inside the handle so the regular handle pops the right side but you have to reach in and pull the metal thing to pop the left side. (I’ve always thought of this to be extra security)
The Center Console Lid is broke off but still sits in where it should. (I hit the button to open it and it flung back so hard it broke off)
$4000 No trades. Dracut MA Truck is still on the road being driven currently so delivery is a possibility. All pictures can be seen here http://s88.photobucket.com/albums/k1...%20For%20Sale/
EStenzJ4 is offline   Reply With Quote
Old 06-23-2012, 04:56 AM   #819 (permalink)
ct67_72's Avatar
Member # 184680
sterling 10.25 rear, complete drum to drum 100$
also chevy d44. complete hub to hub, flat top knuckles, one side apart 100$
Old 06-24-2012, 07:27 AM   #820 (permalink)
Member # 140918
can am renegade 800 x for sale
2008 can am rengade 800 x for sale $5,900.00 Graet condition, one owner, still has the original tires on it in good condition, low miles just 229 total, adult owned, stored in a garage, just a great great machine a 4x4 sport quad ! call 914-403-5686
http://hudsonvalley.craigslist.org/mcy/3093854344.html
charlie melchner
charlie melchner
charlie marina is offline   Reply With Quote
Old 06-25-2012, 04:24 PM   #821 (permalink)
Member # 154345
Buy don't build
ZJ - BUY Dont't Build
$6,000.00
Why build when you can buy and SAVE HUGE!
Here is the CL post of a local Jeep, ready for anything, proven HIGHLY capable and one of many solid Jeeps built by Warren.
http://allentown.craigslist.org/cto/3060454457.html
Check out this list for 6K!
5.2 V8
Dual Flowmaster
Auto
NP 231, AA SYE Kit
38.5x11x16 Boggers only 500 miles on them.
Black Rockcrawler Wheels
Full size spare on matching wheels
Narrowed Dana 60 HP
PSC Hyro Assist Ram Box and Pump
5:13s
Detroit Locker
Chromoly Axles
½ Ton Chevy Calipers
Great Lakes Offroad Bulletproof Cover
High Angle Drive Shaft amd Forged Yoke
1 Ton Solid Tie Rod
Shaved and Narrowed 14 Bolt
5:13s
Detroit Locker
1350 High Angle Driveshaft and Forged Yoke
F/R Clayton Longarm with High Clearance brackets
ARB front Winch Bumper
Warn 9.5 XP with Amsteel Blue Line and Spare Steel Cable
Rock Sliders
Skid Row Gas Tank Skid
Schuylker is offline   Reply With Quote
Old 06-25-2012, 04:26 PM   #822 (permalink)
Member # 154345
Originally Posted by Schuylker View Post
ZJ -
No way? How much was that?
Old 06-25-2012, 04:27 PM   #823 (permalink)
Member # 154345
ZJ -
No fawkin way? Leavin the winch on too for 6k
Old 06-25-2012, 04:28 PM   #824 (permalink)
Member # 154345
ZJ
Damn, thats a chunk of change right there.
Old 06-25-2012, 07:52 PM   #825 (permalink)
zr2sonoma's Avatar
Member # 148844
Wtd: Fj45 lwp bed
Looking for a fj45 lwp bed
/forum/wanted/1074700-wtd-fj45-frame.html
pat
65 fj45
zr2sonoma is offline   Reply With Quote
