Northeast forsale wanted and trade!!-POST ONLY HERE - Page 90 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Northeast
Old 03-04-2017, 08:43 PM   #2226 (permalink)
Member # 155134
box4rocks, 23 spline in and out, was on a AW4/D300 combo. $750
Toyota 2.28/4.70 doubler, 21 spline throughout, rear case converted to top shift, marlin 10* clocked adapter. $1200
V8 700R4 with advance adapters toyota output shaft, and toyota t-case adapter. still have factory 27 spline output shaft that can go with it if you want to swap it back. shifts great, very low miles on new filter/fluid. was mostly on the street behind a 4.3 in a 4runner. $750
brand new 15x8, 8x6.5 chevy, toyota, etc. 2.5" backspace, bought new and mounted tires to mock up on my buggy but went a different direction, wheels have never been driven on. painted black. I would trade for 16.5 H1 military hummer wheels.
$200
Located in tilton nh, phone or text is best as i dont get on here much. 603-845-6366 just mention you saw this add.
Silver GT is offline   Reply With Quote Quick reply to this message
Old 03-05-2017, 03:25 PM   #2227 (permalink)
JEEPTHANG MD's Avatar
Member # 159915
2000 TJ Dana 44s and 37" pit bulls 7000 obo
http://www.pirate4x4.com/forum/vehic...-pitbulls.html
TRAIL RIG 2000 TJ DANA44s TERALOW231-300 DOUBLER 3LINK FRONT 4 LINK REAR 37" PITBULLS
JEEPTHANG MD is offline   Reply With Quote Quick reply to this message
Old 03-07-2017, 07:03 AM   #2228 (permalink)
Member # 718738
Warn 9.5ti PA 18036 $750
works good. some paint chipping off. $750
PA 18036
Warn 9.5ti
1985tug is offline   Reply With Quote Quick reply to this message
Old 03-15-2017, 01:00 PM   #2229 (permalink)
That guy
Member # 144281
SOLD
wesfab is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 02:14 PM   #2230 (permalink)
Member # 89364
37 1250 15 tires and wheels
4
37 1250 15 parnelli jones dirt gripz
Somewhere around half tread.
Work good off-road. And run down the road fine. On my daily driver.
Also have a spare old style Goodyear Mtr 37 1250 15
All 5 on black wagon wheels "d window" style
5 x 4.5 bolt pattern.
3.75 back spacing.
Would like to sell all 5 together. Tires rims and all.
They are all balanced.
1 tire has a small tear in the bead. Not visible.
Has plugs in it and bead sealer.
Has leaked when I've run them at single digit pressures and bulged it on rocks.
Otherwise it's perfectly fine.
As I said before. They are driven daily with no problems at all.
Looking for $700 for all 5 tires and wheels.
I will take offers.
Would also split up. But the price goes up.
Best way is call or text.
570 nine seven seven 3743
In stroudsburg pa 18360.
Thanks
Paul.
Trying to figure out how to add pictures
three is offline   Reply With Quote Quick reply to this message
Old 03-18-2017, 06:19 PM   #2231 (permalink)
Member # 493553
Selling a bunch of stuff...
Four brand new never mounted TSL SX's 38/12.5/16.5 with used Trailworthy Fab H1 double beadlocks. Brand new unused PVC inserts and O-rings from Trailworthy Fab as well as the old O-rings.
Wheels are 8x6.5
$2600
GM Dana 60 front axle with....
TMR simple truss and panhard mount
TMR diff cover
Stock shafts
Stock cover
Stock knuckles
Stock brake brackets
Stock tie rod
Stock carrier
Stock gears (3.73 I believe)
Stock spindles
Superwinch lockout hubs
No hub/bearing assemblies
Housing is stripped, cleaned and straight...no brackets as it was going in my Jeep.
$900
GM 205 transfer case
Around 36k original miles
Tail housing converted to newer VSS electronic style
Clocking ring
Tail support with bushing
Yoke rear
Flange front
32 spline input
Case was completely disassembled, cleaned and reassembled with new seals, new gaskets and painted with POR15
$550
16.5x10 steel wheels
8x6.5
Need paint
$200
Everything located in East Haven, VT
showjyr is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 01:05 PM   #2232 (permalink)
Member # 118892
1993 SAS Suburban, Wiscasset Maine
1993 SAS Suburban,
350 Chevy crate engine with 85,000 miles. Body has 171,000 miles. This is a southern truck with no rust on body or frame except for some small patches of surface rust where paint has chipped. There are some dents. 9" lift, King Pin D60 front, 14 bolt rear. (LS in the rear/open front) Crossover steering. Automatic with overdrive and shift kit. Glass is tinted. Great stereo with 2 10" subs, 2 amps, and 4 speakers. 37/12.5/16.5 MTRs on 24 bolts. Front tires are brand new. Rear about half tread. Also have 2 others mounted and balanced for spares with about 25% tread. Pretty sure the gears are 4.56 or 4.88. Goes down the road great. 7 passenger seating in great shape. Third seat is removable. Custom stainless rear bumper, push bar, and steps. Towing mirrors. Train horn. Power windows and locks. Rear defrost. A/C does not work. $5600.
I listed this for a buddy so PM me if your serious, have cash, and I'll put you in touch with him. Thanks.
badlarry is offline   Reply With Quote Quick reply to this message
