Power Steering Box Rebuild - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Northern California
Old 03-02-2013, 03:43 PM   #1 (permalink)
Scouty's Avatar
Member # 681
Anybody in Norcal want to rebuild a Scout II power steering box for me? Will pay reasonable labor cost and for parts. Box was tapped for hydro-assist by PSC. I bought the box used but it never worked. Give me a quote, I'm in Sac.
"Anything Less is Just A Pile of Chit"
Scouty is offline   Reply With Quote Quick reply to this message
Old 03-20-2014, 01:22 PM   #2 (permalink)
R290's Avatar
Member # 46467
When you say it never worked, do you mean it won't turn or it leaks like a sieve or no power?
I'm going to rebuild my box tonight. I pick up a seal kit and a watch a you tube video, plus have the service manual.
I would think its going to cost 2 12 packs of some decent beer, plus parts.
Depends on if the insides are FUBAR or not. I don't know all the makes and models of donor boxes that parts can be swapped from. But this is a common box from the 70's So I'm sure spares could be had a PickNpull.
The power is controlled by the piston and the little balls.
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 03-20-2014, 08:38 PM   #3 (permalink)
Scouty's Avatar
Member # 681
Only took a year for a response. How'd your rebuild go?
Old 03-22-2014, 07:19 AM   #4 (permalink)
Member # 186727
Try Red Head Steering in Washington
Runzoff is offline   Reply With Quote Quick reply to this message
Old 03-24-2014, 01:25 PM   #5 (permalink)
Member # 75114
Mine exploded into pieces after it was reinstalled.
keeptahoewhite is offline   Reply With Quote Quick reply to this message
Old 03-24-2014, 02:22 PM   #6 (permalink)
R290's Avatar
Member # 46467
Well...........
I have not got it back together as I need to order more parts.
To make Hollister, I just ran my spare box as is.
Will need to open your box and inspect the insides. If damaged then we know what the issue is. From there need to shop around at PnP. to find some donor parts boxes.
73 IH Scout
Old 03-24-2014, 03:47 PM   #7 (permalink)
Scouty's Avatar
Member # 681
I've got a spare box, only thing is its got the smaller input. The PSC box is got the bigger input, plus my steering joint is for the bigger input. The splines on the output shaft of the PSC box are twisted, and I can see hairline cracks, may need to find one of those. Doesn't a Ford Sagnaw box use the same output shaft?
Old 03-24-2014, 10:51 PM   #8 (permalink)
R290's Avatar
Member # 46467
good luck finding an early ford. Its like finding a Scout box.
I need the piston.
73 IH Scout
