Member # 193441
Offroad Snow Tire??
I'm building up a Toyota, sas, locked in the rear and open in the front (till I get money for arb) and geared to 5.29s.
I want a second set of tires to run in the deep WA snow, 35x12.50x15 or a 35x13.50...My question is, what tire? I always air down. I've looked at Toyo MTs, MTRs, STTs, KM2, super swampers... |
Member # 848
You want a radial for the snow. I've been running 36x12.50R15 tsl radials for many many years. I sipe them heavily and they work great. Try to get the tallest radial you can afford. I'd like to step up to a little taller tire for the snow...maybe some day.
SNOWTREK.org |
Bogger or implement seem to be the best ive seen run snow especially deep snow. But ice is a big factor for non siped tires. I certainly love my boggers in the snow
'94 F350 CC .030 460 Auto 4x4 "Tow Rig" '78 F350 Sittin Pretty On 39.5 Boggers R.I.P. '94 Ranger 3/4 ton 5.8L 38.5 Boggers Taylor |
Member # 193441
I run a set of 33x12.50 Goodyear Dura trac tires as my run around tire. Love the tire.
But as I said above, I want a second set of tires for just off roading in the snow. I have been leaning towards the Super Swamper IROKs. Thanks for the reply, I'm still open to hear what others think. |
Member # 191559
I run 37" Pitbull Rockers on my 85 Toyota and love them I would not recommend them if you are going to daily drive it but it doesn't sound like they will be your main road tire. I also am a big fan of Super Swampers and ran them before these. The sets were both Bias ply which I really like but I don't daily drive my rig. I don't know how much of a difference there is between Bias and Radial in the snow between. I do know both sets I have had have done great in the snow.
Member # 848
Radials really do make a big difference. They do a much better job of distributing weight evenly on the contact patch, where bias tires tend to put more pressure on the sides of the contact patch. Most bias tires have a stiffer sidewall as well, which effectively raises your ground pressure. On many occassions we've had to literally pull the cores on the bias tired folks just so they can keep up. At zero psi, they have a hard time steering.
SNOWTREK.org |
Shifting for all
Member # 68266
IROKs
I run Bias, 36-13.50x15 IROKs on 8" rim, I run them with low single digit tire pressure, they work, steers fine. Rim width has a lot to do tire profile too, there is a whole argument for that one and it's been covered here several times.
Large irrregular blocks of tread with more gap that tread! Second choice would be a Pitbull Rocker.
RADesigns Products LLC - Shift to the Best The 2nd Amendment is not to be screwed with, I am a card carrying member of the NRA. If this offends you please don't buy my products. http://radesignsproducts.com/Accessories.html Jeep, Toyota and Nissan automatics, Shift controllers and shifters, Toyota Triple Stick levers! My stuff: /forum/toyota-truck-4runner/996438-2rz-82-w-a340-duals-radesigns-way.html John 3:16- He is the answer. |
Member # 193441
I was almost gonna get a set of pit bulls but then I just found a good set of used 36x12.50 Super Swampers radials on craigslist mounted on some nice wheels. Price was right and they should work fine.
#12 (permalink) |
Member # 99840
Irok radials, for an off road snow tire would be my choice as well.
They seem to keep moving quite well while keeping you on top of the snow. Although, for a one tire does it all.. I run the MTR Kevlars, get them into single digits and I have seen these tires do better in the snow then any all around tires.. Like any tire if aired up too high, duratracs especially will pass you right bye..lol |
#13 (permalink) |
Member # 143895
I love my Iroks in the snow. I wanted to run the Kevlars since i was DD'ing my runner but got a DD from DWT and ordered up the Iroks since the Kevlars weren't available. The iroks just flat out work
#16 (permalink) |
My Kevlars work awesome in the snow, unless you're on a slick sidehill. I notice that the rear doesn't seem to follow the front which makes for some interesting crabwalking. Out of 7 rigs, 2 of us had Kevlars and both did the same thing (Range Rover and a TJ).
51 CJ3A future trail machine 88 Range Rover Truck Cab |
#18 (permalink) |
IROKS hands down. Over here in Walla snow is what we do. Its used to be the 38 gumbo but thats gone now. Ive got a set of 42s ill be running this year. My buddy has ran them on his buggy and they flat kicked ass. Radial or bias either way will work. I really havnt seen a difference in performance between the two. If you can go with 36 or 37s instead of 35s id recomend that. Throw em on a 10-12 wide rim with 1-5 psi and you will do just dandy. I know some brothers one who runs 39.5 IROKS and one that runs 39 pitbulls on bout identical toyotas. The IROKS did better than the pitbulls. I do however think if he took the time to grove the pitbulls they might pull ahead of the IROKS. Just my 2 cents.
Link to my 85 yota build: http://www.pirate4x4.com/forum/showt...ight=snowdemon |
#21 (permalink) | |
Member # 226
You guys are delusional. If you're going to go for purple unicorn tires that they don't make any more you may as well hunt down some 38.5 gumbo radials. If you want tires that you can actually buy nowadays get some iroks and drive circles around the clowns clutching desperately to their old style mtrs. |
#22 (permalink) | |
Member # 848
Of course I think the bias ply folks are delusional too.
SNOWTREK.org |
#23 (permalink) | |
Beer crawler
Member # 39901
. And your picture is pointless, our trails aren't flat paved highways here.Add to that radials are heavy and have weak sidewalls.
my 90 project Save a tree, eat a beaver. There are two keys to life, leverage and lubrication. Sometimes you need both. Because there is no 2nd chances on Pirate! Last edited by 2manyprojects; 09-22-2011 at 12:07 PM. |
#25 (permalink) |
Beer crawler
Member # 39901
Around here? Definitely. Already been proven, even swapped tires.
my 90 project Save a tree, eat a beaver. There are two keys to life, leverage and lubrication. Sometimes you need both. Because there is no 2nd chances on Pirate! |
