#101 (permalink) | |
International Dan
Why you selling ryan?
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html facebook.com/hardenedways Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you. |
#104 (permalink) |
Member # 208306
Southern OR
Looking for 7/8"s flip ring to mount Dana 300 Lefty style to AX-15 . Also looking for shifters or cable setup for that flip, maybe even 4-1 gears . Have "Texas" adapter for Dana 300 I dont need, sell or trade . Going out of the Cherokee business, have lots of stuff there .
#105 (permalink) |
Member # 153951
SAS 93 Jimmy. $3500, SOLD SOLD
(Copied from my Craigslist add)
SOLD I am at a stopping point with my crawler project, I had more plans for it, but college forces sale. I built it slowly on breaks from school, so alot of the parts dont have much use on them at all. I have a folder full of receipts but Im sure ive lost some. I also have a bunch of spare parts, and 2 spare tires (TSLs w/ good tread ) on hummer bead locks with the run flats cut down. some specs: 36" bias ply military tires. 80-90% tread Hummer double beadlocks, and 2 spare rims front axle: 79 3/4 ton Bronco, This was the biggest and best Dana 44 ever built. rear axle: Full Float 14 bolt, welded. 4.10 gears 4.3l CPI vortec: 230hp 260ft/lbs NEW sensors and gaskets: EGR, knock, TPS, oil pressure, upper plenum gasket, exhaust donuts, oil pan gasket, oil pump. ALL less than 500 miles 4l60e w/ recent Amco rebuild (bought). trans cooler, trans temp sensor Flowmaster exhaust just went through and resealed the np 231 Tcase, (less than 500 miles) new ujoints in drive lines, (less than 500 miles) aftermarket Tachometer new plug wires and distributor cap, have new spark plugs (less than 500 miles) new deep cycle battery 1000 cca (bought 2 months ago), and battery leads, Autozone 3 year warranty new fuel pump Custom SAS (all less than 500 miles): new cross member and winch mount (Beefy as hell), K20 rear 54" springs, new bushings with grease-able bolts, adjustable slide boxes with UHMW sliders (great ride quality), 4 new 14" travel pro-comp shocks, new shock mounts (upper and lower), 1 ton steering joints, and .250 wall steering links, (less than 500 miles) new ball joints, (less than 500 miles) Winch: Warn XD9000i The build nickle and dime'd me (all those little things) , but I just had to finish it, and not part out. Ive driven to Bend and back and to the coast and back since i finished it. no problems. just continuing to fix little things. B/c of the slide boxes (limit side to side movement of the leaf springs), it handles the twistys exceptionally well for a SAS vehicle. SOLD Trades im interested in: solid axle yota (no 3.0l), dirtbike +cash, cool Subaru, cummins 4x4 5spd, Tacoma. Im most available on weekday evenings, but can make arrangements. email, call or txt Scott ![]() ![]()
Irregardless Last edited by hckstr09; 10-08-2012 at 09:50 PM. Reason: SOLD |
#107 (permalink) |
Member # 153951
I know!
but finishing school is more important. I don't have the time to enjoy it or build it. I would trade for a DD solid axle yota tho...
Irregardless Last edited by hckstr09; 08-14-2012 at 12:31 AM. |
#108 (permalink) |
Member # 208306
Dana 300 E brake kit in OR $75.
Selling brake kit that goes on the back of Dana 300, basically a driveline brake . It was installed new, never used, then left outside for three years uncovered, along with my Tcase unfortunately, these are $365.+ new . This one has surface rust, which will do no harm to anything with the exception of the inside of the brake caliper, which should probably be rebuilt or taken apart and cleaned up . $75. + the ride, located in Sothern Oregon, Rogue Valley .
#109 (permalink) |
Stump Humper
Member # 137046
Hey guys I'm looking for a set of stock Dodge Ram 17x8 8lug Alloys like this.
Let me know if you have some you want to get rid of, Thanks. ![]() ![]() ![]() ![]() Any of these would be acceptable. Last edited by Chaps; 08-15-2012 at 06:28 PM. |
#110 (permalink) |
Member # 97975
7500 dexter trailer axles
http://seattle.craigslist.org/sno/for/3210462315.html.
looking to trade for 38x12.5x16.5 TSL swampers 75% tread or better or $800 obo
91 xj 2dr 4x4 8"lift 34x9.5x15 swampers |
#111 (permalink) |
Member # 1040
YJ wanted in OR
Anyone have a 87-95 Wrangler for sale in OR or WA? Just wanting plain Jeep. About $3000 or so is what I have to spend.
Thanks Rick Last edited by WyoJeeper; 08-17-2012 at 10:40 PM. |
#113 (permalink) | |
Member # 128879
http://www.off-camber.com/forum/topi...ng-for-a-jeep/ |
#114 (permalink) |
Member # 183727
FOR SALE!! 1986 f350! Diesel 6.9 4x4 crew cab $1500
FOR SALE!! 1972 ford maverick grabber $800 Text 971-240-9362 both are complete. Truck is daily driver maverick runs just needs a little work |
#117 (permalink) | |
Member # 149566
Pacific North West Jeeper My HEMI, ROCK JOCK, 4-LINK, etc Build:: /forum/jeep-hardcore-tech/850159-1997-tj-2-5-l.html Seattle Fabricators: www.crawlmag.com www.bentmetalcustoms.net www.auburncarrepair.com www.home.comcast.net/~thoseguys/ www.xo-fab.com www.metalhavoc.com |
#118 (permalink) |
Member # 11491
Got the wheels i bought off toyoturd mounted up on my C10!
Before, ![]() After, ![]() Thanks again man!
Now takeing donations, For the "GET MICHELL A DANA 60" fund........... :) |
#119 (permalink) |
Member # 77531
8 lug loading tires/ pizza cutters
I have a set of 4- 8 on 6.5 tires and wheels. No tread. But great for getting your project in and out of the garage. $50 OBO.
K5: locked and geared, one-tons, LT1, doubler, 42s youtube.com/user/onetonk5 |
#120 (permalink) | |
Member # 208306
#121 (permalink) |
Member # 158437
6 lug 15x8 steels
6 lugs steel chrome mods..$100 obo
Dana 70 rear complete 3.73 gears..out of a late 90s dodge 3/4 ton $150 obo Call or text 503-949-6413__ located in salem,or Thanks
What i lack in patience and grace, I make up for in hitn it harder |
#122 (permalink) |
Member # 153928
This is a custom 4 seat offroad rig. I have a trailer available if you want. Serious turn-key setup. $10,500 OBO ( trailer sold seperate) Call/text Brian @ 509-899-4850. Serious offers only please and NO SPAMMERS
Vehicle Specs. * Dana 60 Front w/ lockright * Sterling 10.25 rear/welded * Camaro 3.4 V6 * GotPropane injection system * MSD ignition * 14" 2.0 Fox Resevoir Shocks front * 16" 2.0 Fox Resevior Shocks rear * Link suspension front and rear * Hydro Assist steering * 39.5 Iroks w/ 95% tread * 17" Allied beadlock wheels * Co2 air tank plumbed * 207/208 dual transfer case setup * 5.38 gears * 5spd trans * dual winch setup * Warn M8000 with synthetic rope on front * TMax 9000 with synthetic rope on rear * 5 point harnesses front and rear * Fully intergrated cage both inner and exo * axle airbag plumbed for COG adjustment * GPS * Cobra CB * tilt steering * Grant steering wheel * Sterio w/ MP3 port * Hand throttle * Custom interior with toggle bank * Toggle start * Removable full doors for winter * Partial rock doors for summer ![]() ![]() ![]() Here's the trailer in case anyone is interested. I don't want to sell the trailer w/out the chuggy or at least not until after it sells. Trailer/toyhauler $4,000 * Partially enclosed * shower * laminant flooring * LED lighting * Separate battery * Dropdown fenders * Deck entrance * Storage/Changing area ![]() ![]() ![]() ![]() ![]()
Check out KFinney Photography at [url]http://www.kfinneyphotography.com/index.html[/url] Last edited by kfinney; 08-27-2012 at 11:16 PM. |
#124 (permalink) | |
Member # 11491
