22rte build for sale / part out - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Northwest
Old 05-15-2012, 06:59 PM   #1 (permalink)
Member # 218889
Toyota factory turbo 22rte. Comes with everything you need. Wiring harness, ecm, everything under hood.
Comes with
*Block - Completely Stripped, Bored Over .060 and surfaced
*Head - Valves Reground, New Stem Seals
* Rocker Arm Rails
* Oil Pan
* Flywheel
* Timing Cover
* Oil Filter Adapter Housing
* Crankshaft
* Factory Camshaft
* Brand New Dished Pistons .060 Over
* Rear main Cover
* EGR Valve
* Airbox with Mass air Flow Sensor
* Engine Fan + Clutch
* Alternator
* Ignition Coil
* Wiper Motor
* Turbo Down Pipe
* Oil Pick up tube
* EVAP Canister
* Coolant Overflow Bottle
* Throttle Body
*Exhaust manifold with turbo + Heat shields
*Upper + Lower Intake Manifold, with all trimmings
* ECM + UNCUT Wiring Harness
* All Various Coolant hoses, Fuel Lines, Mounts and brackets
*Various Hardware in individual Baggies.
This Stuff Has Been Sitting for a while, INSIDE & Covered, It will Need to be cleaned. But Anything on it is all surface that will wipe off
$500 Firm, need gone! Or going to part out soon
Gearing grace is offline   Reply With Quote Quick reply to this message
Old 05-15-2012, 08:34 PM   #2 (permalink)
Mr Stubs's Avatar
Member # 102813
I would be interested in the whole shooting match but I see that you posted firm on the price....
If you part I would like the exhaust manifold if it isnt cracked and the timing chain cover/oil pump assembly.
Help bring back Swartz Canyon, Join
The good guys...
Marlin Crawler, Hellfire Fabworks, Dave'z Offroad, gearinstalls.com (Zuk), Diamond Axle, RADesigns, Advanced Adapters, Jantz Engineering, G-Fab motorsports, Got Propane, JHF
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 06-08-2012, 03:58 PM   #3 (permalink)
Member # 214735
If u part out i would get the ecm off you
an harness
NOISYBOY is offline   Reply With Quote Quick reply to this message
Old 06-08-2012, 06:18 PM   #4 (permalink)
Member # 183889
Wink
Ill take the turbo if decide to part out!!
bennett7784 is offline   Reply With Quote Quick reply to this message
Old 06-24-2012, 06:35 PM   #5 (permalink)
Mr Stubs's Avatar
Member # 102813
Bump..... is the OP checking this?
The good guys...
Old 11-15-2014, 07:41 PM   #6 (permalink)
Member # 444458
did this sale?
clutchdumper is offline   Reply With Quote Quick reply to this message
Old 11-16-2014, 05:42 PM   #7 (permalink)
Mr Stubs's Avatar
Member # 102813
Over two years ago and this was the OP's first and only post....
The good guys...
Old 11-18-2014, 01:25 PM   #8 (permalink)
Member # 446410
still got this
Nwyota2006 is offline   Reply With Quote Quick reply to this message
Old 05-08-2016, 06:14 PM   #9 (permalink)
Member # 674241
Is this still for sale?
2InchesHard is offline   Reply With Quote Quick reply to this message
Old 05-10-2016, 04:18 PM   #10 (permalink)
Provience's Avatar
Member # 138976
Originally Posted by Nwyota2006 View Post
still got this
it must be tough to read an entire page before responding Now we are up to 4 years though without the original poster returning to the board
To be clear, this is not to suggest that in similar circumstances, a person who engaged in this activity would face no consequences. To the contrary, those individuals are often subject to security or administrative sanctions. But that is not what we are deciding now.
- Comey on Clinton 2016
