Member # 94248
wtb.. chevy or dodge dana 60
i know this is the wrong forum for this but im not getting any responce in the for sell section...i know someone has one they need gone? let me know
Member # 13880
pm me your number, I got a couple of dodge 60's
84runner with tons,r151,duals with 4.7s in the rear, a little tube and some tenderized sheetmetal. [URL=www.lucky13offroad.com/phpbb2]Lucky13[/URL] [URL=http://www.bluehost.com/track/Luckyone/text1]CLICK HERE TO SIGN UP FOR BLUEHOST.COM NOW[/URL] |
I've got a dodge dana 60 (actually 61... just add the $40 spacer from reider racing or gearman on the board and its the same as a d60) that I'll let go for $800. Let me know if your interested. I'm in Hillsboro.
I am offended by reality all the time. My 1 ton fj60 build: /forum/toyota-land-cruiser/708363-fj60-build.html Last edited by brokenparts; 03-04-2008 at 11:32 AM. |
Wanted Dana 60..
I believe this truck has a pair of them..
![]() Which I'm yanking the wiring harness, motor, trans and t-case. Everything thing else will be sold cheap. It's an '89 3/4 ton 4x4. make an offer..
'99 TJ Sport, ragtop, RE 4 1/2 lift, Magnum 318 V8, Atlas II, 4.88's, Dana60's, 35" BFG MT's, Detroit\ARB, 9500lb DualForce powerplant winch '93 toyota std cab sb 4x4 on 32's, MM 9500 winch o_o_o_o /| ,[_____], |ŻŻŻL--O||||O- ()_)Ż()_) ŻŻŻ )_) Last edited by jeep_freek; 03-05-2008 at 08:29 AM. |
that looks like a 2wd to me?
I am offended by reality all the time. My 1 ton fj60 build: http://www.pirate4x4.com/forum/showthread.php?t=708363 |
Wanted Dana 60..
Trust me.. it's 4 wheel drive. Here's another picture:
![]() You can see the t-case shifter.
'99 TJ Sport, ragtop, RE 4 1/2 lift, Magnum 318 V8, Atlas II, 4.88's, Dana60's, 35" BFG MT's, Detroit\ARB, 9500lb DualForce powerplant winch '93 toyota std cab sb 4x4 on 32's, MM 9500 winch o_o_o_o /| ,[_____], |ŻŻŻL--O||||O- ()_)Ż()_) ŻŻŻ )_) |
yep...IFS.
any interest in my dodge 60 (61)?
Member # 94248
possibly i need to figure out if i wanna go 5.13s or not. randys didnt have anything over 4.56s for the 61. i might though. i might just do 4.56s and a doubler
#12 (permalink) |
Wanted Dana 60..
ok.. MYBAD! yup.. but the rear isn't..
Just kidding. Would $500 be too much for the rear alone..? I'd hate to see it goto waste in a junkyard.
#13 (permalink) |
______________
Jeep freek, not a Dana 60 rear. It would be a GM 14 bolt. Craig, are you looking for a front or rear? FYI: a Dodge (kingpin)front Dana 60 is 2" narrower than a Chevy, and the spring perch center to center is wider.
#16 (permalink) |
yep, just run the spacer and its no big deal to run what gear ration you want. If you do some searches here on pirate there is tons of info.
