I need a seal housing Assy from a Dana 30 ARB 27 or 30 spline are the same. Anyone have a busted or junked ARB locker?
In a pickle & need it before June 1st for a race.
Fixed it
Anyone ever need 411 on the copper line going into the seal housing. Its tig welded in the housing. Mine was cracked 1/8" from the weld.
So, I went to ACE hardware & bought a 1/4" flared end sleeve. Grinded out the weld on the down the sides of the copper tube. So, the
sleeve could run down to the housing flush. Brazed solder around it. Then brazed the top of the sleeve. After this put the housing back on
& tested it. It did leak from tiny pin holes but solved this by using a Dremel metal tip engraver. What this did was heat up the solder as it
grinded it away & sealed the pin holes up.
Another way to repair or replace the line is to cut the line flush & then drill or grind out the tubing & weld. Then insert a new line & tig weld
back in or brazed it in place.
