Member # 83230
Virginia here.
Been building off the wall stuff since I was a youngin'.
Here's the latest. Specs: I reworked the subframe and hung a Ford HP 44 radius arm and coil front and 4:10 ...soon to be replaced by the F350 D60 on my shop floor. Ford Sterling 10.25" out back from a E350 Superduty with discs and 4:10. NP241, 4l60E and 4.3L that still delivers 19 MPG. I fabbed the front clip up after a guy tried to run me off the road and I didn't let him. It's metal brake steel and some fiberglass. I'm adding a forward tilt right now. This started out as a joke and has evolved into a snowball of mods. I mount duallies all the way around and run it in local parades, and spend a couple of hours every day explaining what it is after some inquisitive person asks me... ![]()
Member # 4243
I like the radius arm setup.
Are the stock coils in the right place for the F150 axle? How about the overall width? (I assume the van is a tad wider than the trucks) Also, how much taller are you than stock now? (negating the oversize tires)
90-93 CTD jalopies |
#5 (permalink) | ||
Member # 83230
