86 Toyota 22r - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Southern California
Old 03-26-2012, 07:15 AM   #1 (permalink)
DRT
Member # 214107
86 Toyota 22r
I have a 86 Toyota with a 22r I want to put a single wire gm alternator on it does anybody know of one that may fit right in or need lil fab work to make work?
DRT is offline   Reply With Quote
Old 03-26-2012, 07:45 AM   #2 (permalink)
Chubby Chaser
Mustard Dog's Avatar
Member # 7889
Send a message via AIM to Mustard Dog
I'm pretty sure Aaronn on here makes a bracket for that.
Eric Anderson
TIN BENDERS
Hendrix XR Chassis #001
Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS
Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse.
Accepting the things I cannot change.
Mustard Dog is offline   Reply With Quote
Old 03-26-2012, 08:10 AM   #3 (permalink)
Member # 2413
toolboxguy sells them now .
TINBENDERS.ORG
Aaronn is offline   Reply With Quote
Old 03-26-2012, 03:36 PM   #4 (permalink)
DRT
Member # 214107
How would I get a hold of thetoolboxguy? And which alternator would you guys recommend?
Old 03-26-2012, 10:05 PM   #5 (permalink)
osv
Member # 183438
i did a lot of research on this, and ended up with the powermaster pm47294, mounted on a 22re, with a trail gear adapter... used some coupons at advanceautoparts.com.
it's not a single-wire gm unit, because if i recall correctly, those alternators don't allow you to hook up the alt warning light(?)
i cut the end of the adjustment arm off, because it was fouling some power steering hoses, and i replaced the long bolt because the diameter was kinda small... i also welded in the factory brace off of the original arm.
osv is offline   Reply With Quote
Old 03-26-2012, 11:29 PM   #6 (permalink)
DRT
Member # 214107
I'm not worried about the warning light I have no cluster in the truck for it to show up on. I already replaced the coil and control module over 2 a gm to make it simple.
