Beware Of Desert Fab Motorsports - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Regional Forums > USA - Southwest
Old 02-20-2008, 09:23 AM   #1 (permalink)
Member # 109006
Email me at homecourt2001@yahoo.com if you want a link to the pic's.
Todd McCullen is the owner of Desert Fab Motorsports, 4961 S Pinal Rd, Apache Junction AZ and in my option a yahoo! Contracted him to build a turn key buggy for me on 9/16/06 and was to be complete by 10/31/06. Which is a bit unreal for one man operation, but he stated that was what he could do. I supplied him with the Hendrix frame, CRD diffs, & Atlas. Well I finally pickup on end of November 2007 (14 months). The buggy was like still in mock up, nothing tested, no much checked. The list of stupidity is about 2 pages long. I am still working on buggy in my spar time with fixing and also doing upgrades and having a quality shop fix the things that are beyond my knowledge, Precision Auto in Kingman.
A list of some poor work he did:
standard rubber hose (marked not for fuel) pressure side for EFI fuel system-HAZARDOUS
front wheel studs too short 1.5 turn on lug nuts-HAZARDOUS
blind bolts rear diff top link mount hand tight, also a lot of loose bolts everywhere.
remount & extend upper links and relocate lower link bars for diff travel
ram mounted wrong & binding up ends
steering shaft bearing defective
steering locked up, pump installed wrong
add frame cross bar at rear shocks to support frame twist-Todd had cut out
leak at trans/transfer-no gasket
correct size trans cooler & mounted correctly-with no plastic ties
adjust transmission shifter no park
cut down transfer shifter cover plate – just poor workmanship
brakes would not stop buggy, replace master cyl. with correct fluid size
relocate & replace brake & gas paddles forward, driver seat back-my personal setting for my height, but Todd is my height
no break lights as requested
install radiator overflow tank
relocate rear seat & seatbelts did not fit in space
move gas tank back for rear seat to fit, install vent back flow value on tank
refab hood frame to withstand rollover
refab transfer case bottom cross member at correct height
relocate fuel & break lines away from heat
leaking gas pump, relocate by tank
steel tabs & cables loops for break & fuel lines & wires (remove wire ties)
replace custom headers (very poor workmanship-holes and welds)
install muffler hangers as none provided
solder all wire connectors & splices everywhere with no solder
clean up sharp edges on all aluminum panels
replace all cheap zeus fastener-will not hold offroad
replace .035 drivers & passenger floor panels with .125” aluminum add real tabs to support adult
replace all .125 skid plates with .250” aluminum
air cleaner not tight
fit & trim yellow side panels to fit & add three tabs each side
mount rear winch switch to L-bracket, not Velcro as provided
relocate & replace rear winch mount at better angle
So the front wheels would have fallen off, but I would have most likely burn up first, as I rolled down the mountain side.
homecourt2001 is offline   Reply With Quote
Old 02-20-2008, 01:50 PM   #2 (permalink)
howyadoin's Avatar
Member # 84132
Wrong forum for starters. Some of those issues do sound pretty valid, have you tried to work with him directly, I would assume so. I know they spend some time on the AZVJC board, so you might want to talk to them there. Holy shiate, 1.5 months for a turn key buggy, there was obviously a substantial misunderstanding there! Anyway, best of luck.
howyadoin is offline   Reply With Quote
Old 02-20-2008, 02:04 PM   #3 (permalink)
Member # 7703
If I read that right...I was thinking the same thing. 1 1/2 months seems like a
fawking short time to get everything perfect. Do you have pics?
If you can't drink it, wheel it.....or sleep with it....It's not worth your time.
Save The Hammers #956
ohmscj is offline   Reply With Quote
Old 02-20-2008, 03:55 PM   #4 (permalink)
Arizona_Jeep's Avatar
Member # 99818
Same here, 1.5 months? Shit. It took me two years on a simple CJ7 build. Get some pics up! And sorry to hear that you got screwed over.
Beer is good: Jeep CJ7, under contruction....again
Nobama 08'
Arizona_Jeep is offline   Reply With Quote
Old 02-20-2008, 04:00 PM   #5 (permalink)
Newbie
Member # 8927
I think you missed some of the dates. He contracted the job in 2006 and did not pick it up until November 2007. That is 14 months by my count.
"I refuse to belong to any group that would have me as a member."
Hackle is offline   Reply With Quote
Old 02-20-2008, 05:39 PM   #6 (permalink)
Member # 7703
Yep...just caught that.
pics?
Old 02-20-2008, 06:20 PM   #7 (permalink)
howyadoin's Avatar
Member # 84132
He said was to be completed in 1.5 months originally! 1.5 years is obviously more realistic.
Old 02-20-2008, 07:03 PM   #8 (permalink)
Member # 18243
Heres a sample of some "kick-ass" Desert Fab work!
It tastes like burning
The MULE is offline   Reply With Quote
Old 02-20-2008, 07:27 PM   #9 (permalink)
Member # 99818
Damn, nice seat brackets.
Nobama 08'
Old 02-20-2008, 07:45 PM   #10 (permalink)
Member # 18243
That shit looks like it was welded with a coat hanger and a battery. At least they painted it up to cover the welds.
Old 02-20-2008, 07:53 PM   #11 (permalink)
silversuper's Avatar
Member # 108950
Send a message via AIM to silversuper
wow that is bullshit, sorry to hear.
you didnt pay him did you?
Richie-01 silver nissan frontier CC, SC, lift, tires, armor
2003 Ford F250 6.br0 crew cab lariat
silversuper is offline   Reply With Quote
Old 02-21-2008, 08:05 AM   #12 (permalink)
Member # 109006
oh yes I did, about $27429.12. Did not see the BS until I got it back to kingman.
Old 02-21-2008, 08:09 AM   #13 (permalink)
Member # 109006
No, never contacted him as of yet. So much BS wrong with his workmanship. I figured it would go nowhere, but jsut piss me off more. He either does not care about his workmanship or is just that stupid.
Old 02-21-2008, 08:35 AM   #14 (permalink)
Member # 109006
Wrong forum for starters, where should I have done it?
Old 02-21-2008, 09:56 AM   #15 (permalink)
howyadoin's Avatar
Member # 84132
There's a bad seller/disputes forum here on the board, but I can actually see why you posted here since it is a local issue. Sucks, and doesn't seem to be an isolated incident, so best of luck and thanks for the heads-up.
Old 02-21-2008, 08:56 PM   #16 (permalink)
Member # 109139
That sucks about your buggy and would like to see some pics of the work in question.
As for the pics of the seat mount fab work, it is acceptable for a beginner with a Harbor Freight welder to do in his garage on a Saturday but for a shop to turn out that kind of poor workmanship is appalling.
T-Bag is offline   Reply With Quote
Old 02-22-2008, 11:56 AM   #17 (permalink)
Member # 109006
pic's
Well get some and post next week.
Old 02-22-2008, 04:30 PM   #18 (permalink)
Member # 12716
Wow....
KOT 2013
Team 4725
FatBob309 is offline   Reply With Quote
Old 02-23-2008, 08:21 AM   #19 (permalink)
Member # 18671
Originally Posted by FatBob309 View Post
Wow....
Indeed.
no sig
Gen. Nonsense is offline   Reply With Quote
Old 02-23-2008, 06:04 PM   #20 (permalink)
Member # 102531
And to think, I was about to contact them to backhalf my Jeep into a Juggy too, and do my stretch, and build a set of D60s, and............................
Remember, I am the Instigator, NOT the leader!
Yellow POS-AZ Undertakers
lancetkenyon is offline   Reply With Quote
Old 02-23-2008, 06:08 PM   #21 (permalink)
Paying for others
jeepcrazie's Avatar
Member # 38032
Looks almost exactly like every other desert fab rig I have ever seen. That is the type of work they do. Lesson: Do your homework before you lay down the cash to a builder people. Had you looked at any of the other rigs they built, you would have seen that stuff.
Sorry bout your situation, it's a bummer.
Shady Lady VIP #13
jeepcrazie is offline   Reply With Quote
Old 02-24-2008, 10:11 AM   #22 (permalink)
JackHammer's Avatar
Member # 81286
A little more tub damage and you might as well call it a juggy.
Stick with Joesus.
I was gonna have DF do my steering.
JackHammer is offline   Reply With Quote
Old 02-24-2008, 11:12 AM   #23 (permalink)
Member # 91974
Location: At the edge of the gene pool, with a bucket of bleach.
For the record, those are my seat brackets and my pics above. Todd contacted me the next day to say that he saw the pics and realized he hadn't finished the welds. He asked me to stop back in so he could weld them completely.
There are some things Todd is dealing with within the shop that have had him a little distracted over the last week and I do not consider those welds as being indicative of a poor quality of his work. It was an oversight and its not something I will use against him or his shop in future needs. My experience with DF has been entirely different than the subject of this thread and I'm sorry to hear yours was so bad. I trust him and Dave up there and will continue to use them as my local shop.
And yes, I broke the link to those pics. If you want to post pics of DF's "trash" work, use your own.
Pac8541 is offline   Reply With Quote
Old 02-24-2008, 11:45 AM   #24 (permalink)
Member # 18671
no sig
Old 02-24-2008, 12:19 PM   #25 (permalink)
Member # 102531
Honestly, it should not have taken them seeing the pics to realize they screwed up, they should have caught it in the first place. I have never met Dave or Todd personally, but they have always gotten back to me in a timely manner when I asked for a quote, just never contracted them to do any actual work. This is not the first time I have heard, and seen incidents like this, sorry.
