Member # 163404
93 suzuki sidekick jx 4door
Located near salt lake city utah. $6000 or trade for a couple of good stock sidekicks so I can have one to drive and have one to replace my wifes crappy dodge neon as well.
Parts not installed but included: spare radiator with fan shroud, brand new manual hubs, 5spd trans with tcase and ott kicker 1 doubler setup along with stock samurai tcase, spare hood, brand new clutch disc and pressure plate. Rebuilt 1.6 16v SOHC motor. [work done at Cleggs auto.] Rebuilt Head, all new valves seats etc [work done at Warrens in Spanish fork. ] Full Calmini Exhaust and headers Calmini 3" Suspension Lift with 3" articulation lift and 2" body lift. Can run 33s without trimming Calmini differential Drop Brackets Recently tuned up Iridium plugs, Cap, Wires, and Rotor installed after rebuild. CD player NEW Stabilizer links NEW Shocks NEW Struts, Strut mounts NEW EGR Valve NEW Tie Rods [all around] NEW ball Joints [All of them] Calmini Drop Brackets Upper Rear Ball Joint Spacer NEW Front and Rear Brakes NEW Vacuum Control Valves NEW Valve Cover Gasket New Timing Belt, Tensioner and Timing Cover Custom Steel bumpers front and rear Gas Tank has a Skid Plate. Installed 5.625 Gears to match the 31" tires [$1000 gears if you can even find them] Speedo is dead on and the low range is lower than most 4x4s . These gears can handle up to 33 tires without killing low range gearing and highway driving. Motor and head has less than 11K on them. Car has 156K ![]() ![]() ![]() ![]() ![]() ![]() ![]()
