Member # 24146
Custom 1986 Toyota Land Cruiser FJ60 ARB Adventure Truck
1986 Custom FJ60......
Absolutely No Rust outside inside or under, Interior is in great condition (no rips or tears) Truck sits identical to the pics: http://www.wired2.com/FJ60 Location: Berthoud Colorado Sound: -Eclipse 3414 ESN E3 high power DC with MP3 decoder -Eclipse Mid's custom in door design -Power Amplifier by MTX -Custom Box with Pioneer thunder 10" speaker (thumper) CB with 15 Ft. Whip antena A Complete mechanical restoreation/upgrade of a rust free, 120,000 mile, Western Truck. Only 4k miles on original, custom built and balanced 2F, 3F manifolds with a 2.5 " Flowmaster exhaust. Only 2K miles on rebuilt transfer case, rebuilt front and rear diffs with new ARB lockers front and rear, new OEM brake rotors and calipers, new seals and Toyo bearings throughout. Recently outfitted for ARB's American Outback Adventure Series with a complete 2.5" Old Man Emu suspension system, new BFG 33x9.5 all terrains, ARB compressor, ARB Bull bar, Warn M10K (never used) IPF 9000's, IPF 7" driving lights with a optional white Max Blue after burner, Dual Optima batteries, dual battery Isolator, ARB safari snorkel with a custom airtight fabricated 6061 aluminum air box, K&N air filter, Custom bomb proof bolt on sliders , Kaymar Tradesman Full length roof rack with custom rubber mounted floor, OEM Hand throttle installed, Machanical Gauges, water/oil, all equipment, parts and rebuild is all new as of June 2004 Front Axle: Completly Serviced with all new seals bearings oils and Pro Longfields.... Motor Specs: Balanced and blueprinting by: http://www.perpetualbalance.com Runs absolutely perfect... Bored .030" Decked .012" (to get 9 to 1 CR) Crank grind Resize rods High Torque Cam Complete balance to within 1/2 gram All new valves All new guides All new upgraded springs Head milled .030 (to get 9 to 1 CR) Delta 254's New Water Pump Non USA 3F in/ex manifolds (big improvement over stock 2F) Valves adjusted after 4000 miles .012-.012H All New OEM Clutch Kit A) Pressure Plate (B) Throw-out Bearing (C) Pilot Bearing (D) Clutch Disc (F) Rear Main Seal (G) Master Clutch Cylinder Slave cylendar Flywheel re-surfaced and Balanced This is only a partial list... I have all detailed reciepts of work complete adding up to over 15K without Labor or truck itself. Asking: $14.5K Pics: http://www.wired2.com/FJ60 Direct E-Mail: remerson@wired2.com FJ63.... ![]()
66 Land Cruiser, 77 Land Cruiser, 89 Land Cruiser 85 Toyota Rock Crawler 85 Toyota x-cab 85 Toyota 4runner 91 Toyota Supra 95 Toyota Supra 95 Geo Tracker...:-( 2001 Toyota D-Cab Last edited by Razor; 01-02-2005 at 09:08 AM. |
Member # 24146
^updated my add:
66 Land Cruiser, 77 Land Cruiser, 89 Land Cruiser 85 Toyota Rock Crawler 85 Toyota x-cab 85 Toyota 4runner 91 Toyota Supra 95 Toyota Supra 95 Geo Tracker...:-( 2001 Toyota D-Cab |
