1986 Jeep CJ-7 Brute project - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Vehicles and Trailers For Sale
Old 12-17-2008, 02:00 PM   #1 (permalink)
Member # 90681
Im putting my 1986 jeep cj7 up forsale to lower my project count. When i got it, it was disassembled and not running, but the tub was already chopped and i was told it was professionally bedlinered. I reassembled it, put new brake lines from the master cylinder to the prop. valve. It has a 258 stright 6 with the 2bbl motorcraft carb swap and TF999 automatic followed by a dana 300. It runs and drives and the 4 wheel drive works. How ever the ubolt straps on the front yoke broke so the drive shaft is just hanging there. It has a widetrac dana 30 and narrow trac model 20 rear. i was told both have the same gear ratios but i do not know. I also cut down a stock top and refiberglassed it to fit the new tub(not finished, could use more tlc). Has two plastic seats that are mounted in it but could go for some new mounts. Dash is mostly complete with a speedo,temp guage,oil pressure,volts, and fuel guage. the only guages that are hooked up are oil and volts. When i swapped the new carb on it also switched it over to GM HEI distributor. Comes with JCR front bumper. It has full hard doors with working latches and good glass and roll up and down.
GOOD-
runs and drives good.
no rust
full hard doors
custom hard top
GM HEI distibutor
Motorcraft carb upgrade
automatic
Dana 300
new power steering hose
Skyjacker 2" lift-looks new
very clean
new rear tail lights and head lights with chrome bezel
JCR front bumper
2008 ORV sticker
box of extra parts
BAD-
needs some wiring work for all lights to work
comes with title and vin plate-never tried to register it-unkown condition
needs rear brakes
carb needs adjustment
finishing tlc
needs windsheild and rear hatch
bed is only partially mounted
If you have any question feel free to ask. I am asking $2500, i do not need to sell so no low ball offers please. Located in Brighton, MI
RDK_YJ88 is offline   Reply With Quote Quick reply to this message
Old 12-18-2008, 02:40 PM   #2 (permalink)
Member # 90681
ttt
