Yukon dana 60 lockouts - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Yukon Gear
Old 04-06-2012, 08:45 AM   #1 (permalink)
Member # 31143
Any info and specs on the new Yukon dana 60 lockouts?
norcalbronco74 is offline   Reply With Quote
Old 04-07-2012, 10:01 PM   #2 (permalink)
Member # 104710
i seen a set up close! WOW! i want one!!!
hummertech is offline   Reply With Quote
Old 04-08-2012, 10:25 PM   #3 (permalink)
Member # 31143
Rumor has it a couple weeks until they are officially released. Sexy units from the picture I saw
Old 04-09-2012, 05:10 PM   #4 (permalink)
Supporting Vendor
Member # 210911
What you saw was a prototype. We thought they would be ready to release pretty quickly, but testing on a few Jeeps last week at EJS prompted us to extend the release date further out until we have a proven product we can stand behind.
There are units being sent to trusted people right now to get more feedback. Once we have release a date we'll let everybody know
YukonGear is offline   Reply With Quote
Old 04-09-2012, 07:18 PM   #5 (permalink)
Member # 186604
Any chance these could eventually be offered in a 40 spline version, or is that just totally beyond the realm of possibility with the existing design?
BRORSAM is offline   Reply With Quote
Old 04-09-2012, 07:22 PM   #6 (permalink)
wannabe
joshua1086's Avatar
Member # 129373
Are they going to be stronger or better then the Warn's? Will the be as good as the Dynatrac's. Why buy the Yukons over others. I know your warranty is easier to deal with then Warn but I like a product that I don't have to deal with Warranty issues.
97' TJ Gone wild!
http://www.pirate4x4.com/forum/showt...973&highlight=
"Everyone has a plan until they get punched in the mouth."
joshua1086 is offline   Reply With Quote
Old 04-10-2012, 02:32 PM   #7 (permalink)
Valley Auto's Avatar
Member # 78079
Originally Posted by brorsam View Post
any chance these could eventually be offered in a 40 spline version, or is that just totally beyond the realm of possibility with the existing design?
x2
Master of the wire Wheel!
Coastal Fabrication the " best damn shop in town"
Poly Performance
Pacific Fabrication
http://www.pacificfab.net/
Valley Auto is offline   Reply With Quote
Old 04-10-2012, 07:08 PM   #8 (permalink)
New Beginnings
jpfrk2001's Avatar
Member # 99513
Same question/concern. I am considering these when available instead of drive slugs.
jpfrk2001 is offline   Reply With Quote
Old 04-11-2012, 12:31 PM   #9 (permalink)
GubNi's Avatar
Member # 25927
Are you willing to openly post the price or PM only?
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here
Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here
Dana 60 front 3/4 ton kits $350--> click here
GubNi is offline   Reply With Quote
Old 04-11-2012, 01:50 PM   #10 (permalink)
Supporting Vendor
Member # 210911
When these are closer to being released we'll have pricing info available.
As far as there being 40 spline versions, not in the near future, but if there is a large demand down the road we'll consider it.
Old 04-14-2012, 07:29 AM   #11 (permalink)
Yukon Gear and Axle
waynehartwig's Avatar
Member # 35700
I hope I don't step on any toes, but this is my answer
Based on the current design, maybe. The only problem is the bigger OD of the shaft, leaves less spline engagement between the two drivers. So I'd think without a little bit of work, I think a 40 spline version of these might be weaker than the 35 spline. But I think with some material changes, and maybe some tooth engagement changes, it could be done.
Should be 3 times stronger than the Warn's and equal to the Dynaloc's, IMO. I've not seen any numbers from any of them yet, so I'm speculating based on what I know of the design and the materials being used. These should be strong enough, that no matter who's axle shaft you have, these should be plenty strong for that application and not be the weak link.
Exactly. No warranty is worth that. It's like the Precision u-joint. Yeah, it has a lifetime warranty where the Spicer doesn't. But 1 Spicer u-joint will far out live several Precision's and for not much more on the cost And you know as well I as I do, how easy Yukon is to deal with on warranty issues.
When I had them on my website for the few days when I thought they were released, I had them listed at $339.04, which was current MAP pricing.
Another fine Yukon product. Dynaloc strength at the Warn price
#4502 "The Rental", Team Yukon Gear and Axle
Good Seller/Buyer List!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
10% PIRATE COUPON CODE: pirate4x4
Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote
Old 04-17-2012, 10:10 PM   #12 (permalink)
Member # 5632
To echo Wayne's response, I was testing a prototype set at EJS as well, and they're substantially stronger than the Warn units. I have broken several Warn 35spline hubs, and ran stuff with the Yukon's that I KNOW would have broken the Warn's. These things are incredible, and will be released fully once a couple minor bugs are finalized.
John
pnwjeep.com
Avanteone is offline   Reply With Quote
Old 04-18-2012, 06:15 AM   #13 (permalink)
jpcrawleram's Avatar
Member # 18734
Looking forward to these!
LetzRoll Offroad / LetzRoll offroad Racing 4493
www.letzrolloffroad.com
480 797-0469
All your Hardcore Crawling / Racing needs!
PSC Motorsports, 4340 Axle shafts (many brands) Custom or factory, Gears, Lockers, Yukon, Reid racing, Trail Ready, Advance Adapters, TeraFlex, Ballistic Fab, RuffStuff, 7075 t-6 links, Custom axles, 9'' 3rd members, Mads Smarty, Solid (spintec)
jpcrawleram is offline   Reply With Quote
Old 04-23-2012, 09:37 AM   #14 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
While touring the Yukon facility Friday we were able to see these hands on, and watch the install of a set onto a test vehicle. The machining, fit, and finish on the part's is impressive, and meeting the engineer who had been on the project since day 1, and seeing how hands on he was with install and fitment was impressive to say the least.
These hub's i highly doubt would ever be a weak link in a front drive system, they look to have 5x more engagment than most mechanical lockers do!
TRENT FABRICATION
www.trentfabrication.com
775-358-5337
Tfab is offline   Reply With Quote
Old 05-01-2012, 12:09 AM   #15 (permalink)
Member # 106340
Any news? Needing these in time for Memorial weekend.
FoMoCoOffRoad is offline   Reply With Quote
Old 05-02-2012, 12:40 PM   #16 (permalink)
Member # 39734
Yes Release date please! If close then I will wait to but these.
Idiot
GWBronco is offline   Reply With Quote
Old 05-02-2012, 08:11 PM   #17 (permalink)
94toytruck's Avatar
Member # 18614
Eric
www.rightcoast4x4.com www.dazednconfuzed.net www.atozfabrication.com www.alltechmotorsports.com www.davesoffroadsupply.com
Originally Posted by FLEXYSAMMY View Post
Yes you are correct Eric.
94toytruck is offline   Reply With Quote
Old 05-02-2012, 08:27 PM   #18 (permalink)
Yukon Gear and Axle
Member # 35700
Getting close! Hopefully very soon!!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 05-02-2012, 08:53 PM   #19 (permalink)
mudslinger021485's Avatar
Member # 130661
How close?
mudslinger021485 is offline   Reply With Quote
Old 05-03-2012, 08:15 AM   #20 (permalink)
Yukon Gear and Axle
Member # 35700
Originally Posted by mudslinger021485 View Post
How close?
As far as I know all of the test rigs have been trouble free for the past month or so..... I'd imagine they've finalized the drawings and ordered parts to start making kits.
...Just a guess. I don't really know for sure.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 06-02-2012, 03:56 PM   #21 (permalink)
Member # 76583
Send a message via AIM to avery4jc Send a message via Yahoo to avery4jc
I saw an ad in 4 Wheel and Offroad for these, what's the scoop on hitting the market?
K10 350/700r4-241/205 doubler
14FF/5.38's/Grizzly~'79 Ford HP60/5.38's/ARB/35 spline cromo shafts
avery4jc is offline   Reply With Quote
Old 06-02-2012, 06:02 PM   #22 (permalink)
Yukon Gear and Axle
Member # 35700
Hopefully soon... I believe just waiting on parts to build kits now.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 06-02-2012, 11:40 PM   #23 (permalink)
Member # 130661
i called randy's in Everett, WA on 5/31/2012 and they told me it should be anyday now cuz they have a bunch ordered.
Old 06-08-2012, 04:47 PM   #24 (permalink)
Yukon Gear and Axle
Member # 35700
Yukon hubs are AVAILABLE!
Drop me a PM for special introductory pricing
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 06-10-2012, 10:12 AM   #25 (permalink)
Member # 104710
Sorry, Wayne's account on here is all messed up and can't get/send PM's etc. until it's fixed.
Feel free to drop him an email at info@diffsonly.com in the meantime.
