Zip Locker manufactures rebate - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Yukon Gear
Old 08-06-2012, 04:10 PM   #1 (permalink)
Supporting Vendor
Member # 210911
When you purchase a Yukon Zip locker between the dates of July 15,2012 and September 16, 2012 you are eligible for a $75.00 manufactures rebate from Yukon Gear & Axle.
This offer is valid for the purchase of Yukon Zip Lockers between the dates of July 15, 2012 and September 16, 2012 only. Rebate claims must be postmarked by September 30, 2012.
go to http://www.yukongear.com/Rebates/Rebate.aspx to download rebate form.
YukonGear is offline   Reply With Quote
Old 09-06-2012, 02:24 PM   #2 (permalink)
Supporting Vendor
Member # 210911
10 Days left on the 75.00 MFG rebate.
Old 04-10-2013, 12:18 PM   #3 (permalink)
Member # 231539
Any current rebate for Zip Locker, Im having one installed today?
sunny1881 is offline   Reply With Quote
Old 04-13-2013, 09:44 AM   #4 (permalink)
183Beast's Avatar
Member # 198821
I would be up for a rebate on a zip locker! It would make my decision easy between the ARB and Zip.
92 YJ, 60's w/40MTRS on leafs
183Beast is offline   Reply With Quote
Old 04-13-2013, 09:54 AM   #5 (permalink)
Yukon Gear and Axle
waynehartwig's Avatar
Member # 35700
You guys could always ask a Yukon dealer for a price quote. After seeing the cost at several hundred less than an ARB, and the collateral damage warranty, it should be an easy decision. And if that doesn't help, buy the $50 lifetime warranty!
#4502 "The Rental", Team Yukon Gear and Axle
Good Seller/Buyer List!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
10% PIRATE COUPON CODE: pirate4x4
Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote
Old 04-13-2013, 03:49 PM   #6 (permalink)
Member # 231539
I emailed Yukon directly and they are not offering any rebates/discounts at this time.
Either way still I had my front Zip installed yesterday!
Old 04-13-2013, 03:50 PM   #7 (permalink)
Member # 231539
Do you think the Lifetime Warranty is worth it and/or necessary?
Old 04-13-2013, 05:06 PM   #8 (permalink)
Ajs biggest fan!!
RANGERROD's Avatar
Member # 172656
If they only made a 14 bolt zip
RANGERROD is offline   Reply With Quote
Old 04-14-2013, 04:48 PM   #9 (permalink)
Yukon Gear and Axle
Member # 35700
I have Zip Lockers in my rig. V8 power and 37" stickies. I've busted 4340 shafts around the lockers (front and rear) and have yet to have a locker issue.
Keep in mind this is the same rig that used to have ARB's in it, with the same Yukon 4340 shafts. I busted the front ARB, and only twisted the splines on a stub shaft.
I did not purchase the lifetime warranty with my Zip's. I've only sold a few Zip's with the extended warranty. I've sold a lot of Zip's and have never had one come back for warranty consideration.
...Believe me, with the Yukon vs ARB threads going on I think you'd hear by now if there was any problems....
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
