Dodge Dana 60 CAD axle - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Yukon Gear
Old 10-25-2012, 04:57 PM   #1 (permalink)
Member # 85007
do you make one piece right side axle shaft to eliminate the cad system on a 1997 dodge ram 2500 front dana 60?
wilco is offline   Quick reply to this message
Old 10-26-2012, 07:04 AM   #2 (permalink)
jpcrawleram's Avatar
Member # 18734
I know they are working on it but dont think they are out yet. I can have a blank cut to fit that axle.
I also have a 4340 stub to fit that axle now using a Yukon shaft.
LetzRoll Offroad / LetzRoll offroad Racing 4493
480 797-0469
All your Hardcore Crawling / Racing needs!
PSC Motorsports, 4340 Axle shafts (many brands) Custom or factory, Gears, Lockers, Yukon gear and axle, Reid racing, Advance Adapters, TeraFlex, Ballistic Fab, RuffStuff, 7075 t-6 links, Custom axles, 9'' 3rd members, Mads Smarty, Solid (spintec), Rock Krawler, Artec Industries, ADS racing shocks, Rugged Radios
jpcrawleram is offline   Quick reply to this message
Old 11-01-2012, 09:27 AM   #3 (permalink)
Member # 102918
How much is a custom shaft to be cut providing it has the proper sections/diameters for the current seals? Thanks!
TOPTRUK is offline   Quick reply to this message
Old 11-01-2012, 02:55 PM   #4 (permalink)
Member # 5326
What is the cost on that stub? Will it fit the 2001.5-2002 axle also?
Mieser is offline   Quick reply to this message
Old 11-23-2012, 08:04 PM   #5 (permalink)
TrailTamer XJ's Avatar
Member # 140878
I may want one when I get locking hubs on my dodge D60. I'll want the 35 spline shafts for sure.
What can we do about the axle shaft seals though?
You can't say that you have wheeled hard till you have broken something or gotten stuck.
TrailTamer XJ is offline   Quick reply to this message
Old 01-02-2013, 09:38 AM   #6 (permalink)
Member # 102918
Any updates? Looking for a CAD replacement shaft.
Old 01-02-2013, 01:23 PM   #7 (permalink)
Member # 18734
Yukon does not have a production shaft yet but I can have them made out of a blank
480 797-0469
Old 01-02-2013, 03:51 PM   #8 (permalink)
Supporting Vendor
Member # 210911
The part number you are looking for is YA W48221. This axle is 38" from center of u-joint to end of splines.
this is a 30 spline inner axle. we also offer it in a 35 spline upgrade if you are looking to do left and right axles
YukonGear is offline   Quick reply to this message
Old 01-02-2013, 07:09 PM   #9 (permalink)
Member # 18734
Sorry I was thinking about something else.
480 797-0469
Old 01-03-2013, 04:23 AM   #10 (permalink)
Member # 22267
Send a message via AIM to HEEPJEEP
You sure? Thought Dodge inners (CAD era) were 32 spline?
YJ and Corey-So buy some then. I've always wanted a pony. Ponies are badass. Do I have a pony? No.
HEEPJEEP is offline   Quick reply to this message
Old 01-03-2013, 08:55 AM   #11 (permalink)
Member # 102918
I believe HEEPJEEP is correct, they are 32 spline. Its been a year since it has been apart and I forgot the spline count, but pretty sure they are 32. Do you have an axleshaft for 32 spline inner and a seal that works with the shaft?
Old 01-15-2013, 08:02 AM   #12 (permalink)
Supporting Vendor
Member # 210911
according to the Dana tech website Dana Holding Corporation - The Expert Axle Bill of Material 1994-1999 Dana 60 front differentials use a 30 spline inner and 33 spline outter stub axles. 2000 they changed to 32 spline inners.
Old 01-17-2013, 05:15 PM   #13 (permalink)
Member # 133589
Are these designed to use the seal in the CAD? Or a seal at the end of the axle tube?
I hate everybody, don't it feel great.......... to hate?
mvanhelden is offline   Quick reply to this message
Old 01-29-2013, 09:32 AM   #14 (permalink)
Supporting Vendor
Member # 210911
The seal would install behind the carrier bearing race like the standard D60 seals.
Old 01-29-2013, 02:19 PM   #15 (permalink)
Member # 85007
How much for left and right 35 spline inner axles for a 1997 truck. Can the spider gears be swapped for 35 spline ones? Can I get a price for the above plus the seals that are required.
Thanks
Old 01-29-2013, 09:04 PM   #16 (permalink)
Member # 133589
Never had mine apart that deep, and heard mixed stuff about the housing being machined to accept a standard seal, is it? Or does it need machining?
Old 01-31-2013, 03:45 PM   #17 (permalink)
Member # 227919
wandering the same thing???
sscamaro is offline   Quick reply to this message
Old 02-06-2013, 07:39 AM   #18 (permalink)
Supporting Vendor
Member # 210911
Thanks
Here is a link to our distributor list. The part number you are looking for is
YA W26032. This part number includes LH & RH inner 35 spline axles, the block of plate, gasket and seals.
Yukon Gear & Axle. Distributors.
Old 02-06-2013, 07:41 AM   #19 (permalink)
Supporting Vendor
Member # 210911
The seals that come with the kit are a "universal" seal. designed to fit in the axle tubes from 2 1/8" to 2 1/4 " and fit axle shafts that are 1 3/16" - 1 1/2".
Old 02-06-2013, 09:03 AM   #20 (permalink)
Member # 85007
What about the spider gears. will any 35 spline spiders fit the carrier I have now?
Old 02-06-2013, 09:40 AM   #21 (permalink)
Member # 159341
As long as they are from a standard open carrier, they should work fine. Or you can purchase a YPKD60-S-35 internal parts kit - that contains the 35 spline side gears you are looking for.
Buy with confidence from the #1 Authorized Dealer of Yukon Gear and Axle Off Road Products
the ONLY Yukon Dealer to offer a COMPLETE Lifetime Warranty on ALL Yukon ring and pinion sets*
888-233-9667
Yukon, USA Standard, ARB, RCV, Warn, Currie, Bubba Rope, Master Pull, Trail Defense, and more
Authorized Yukon Dealer since 1998
*Yukon ring and pinion sets must be purchased at full retail price to be eligible for warranty
Complete Off Road is offline   Quick reply to this message
Old 02-06-2013, 05:16 PM   #22 (permalink)
Member # 227919
who has YA W26032 and whats the price..
Old 02-06-2013, 08:05 PM   #23 (permalink)
Member # 133589
Would like a price on the 30 spline 1 piece shaft and seal, thanks.
Old 02-07-2013, 10:45 AM   #24 (permalink)
Supporting Vendor
Member # 210911
Here is the link to the authorized Yukon Gear & Axle distributor list.
Thank you
Old 02-07-2013, 12:16 PM   #25 (permalink)
Member # 227919
Any idea when the 35 spline kit ya w26032 will be available ??
