Swag Off Road is now selling the following die sizes listed below to compliment the advertised 1.75" die set. With these additional dies you will now have at your finger tips.
0.625" Round
0.75" Round
1.00" Upgraded Drive Roller Only
1.125" Round
1.25" Round
1.375"Round
1.50" Upgraded Drive Roller Only
1.625" Round
1.75" Round
2.00" Round HF
0.75" Square
1.00" Square
1.50" Square
2.00" Square
Universal Flat Bar Edge Roller
.50" Pipe Die
.75" Pipe Die
1.00" Pipe Die
1.25" Pipe Die
1.50" Pipe Die
These dies are CNC machined out of bar stock 1018 steel for precise fit.
Each die set Includes 1 Drive Roller, 2 Driven Rollers, 1 Replacement Drive Axle made out of 4130 chromoly & 8 Set Screws.
Each drive roller has 8 set screws for increased durability not 3 like the HF rollers.
A new replacement drive axle is included and has 8 machined flats for the drive roller and 4 machined flats for the crank wheel.
In addition I am selling some weld on wings for the HF tubing roller. These wings are laser cut out of high strength A-572 Gr50 1/4" thick steel . They extend the total width of the bottom rollers 6" for the first hole and 12" for the second hole. These plates reduce the total effort required in rolling tube ~50%.
If you have used this tubing roller previousley then you can understand how the extended wings can be a real time saver.
I have not bent up any DOM, I'm sure the dies will take it added stress no problem as far as that goes. However you will have to get creative creating a larger crank wheel, bending up HREW takes a bit of mussle, so I would recommend a larger crank wheel to off set the increased force it will take to roll DOM.
Are you constantly changing die sizes from project to project and tired of swapping the (4) roller bearings on the outer driven rollers from die set to die set? We now offer factory direct replacements, a set of (4) for just $12.00.
I don't need the 1 3/4 dies. Do you sell the drive axle seperately? I also noticed that you were thinking of having 1 1/4 dies made. Let me know if you do. I would be interested in those.
any chance of making a square die??? does anyone know if the HF sqaure roller set is really 1/2", as all my HF dies are marked wrong, ie. die marked 1/2" really = 1"
any chance of making a square die??? does anyone know if the HF square roller set is really 1/2", as all my HF dies are marked wrong, ie. die marked 1/2" really = 1"
I have a prototype set of universal square dies that are adjustable from .5" to 2" wide. I have ran a few pieces of tubing thought the die set and the square tubing distorted much more than round tubing. I was bending 1.5" .095" square tubing and it compressed the top surface .175" and elongated the width .175"
I sent the dies out to a customer of mine who uses square tubing on a regular basis for him to use and give me feed back.
I could create 7 different die sets for every size of square tubing, but If I can create one universal die set that can be adjusted while on the machine it would save you a ton of money, reduce my inventory.
I will report back when I have more feed back on the square dies.
I have not personally tried bending flat bar, however I have no reason to believe these dies would not work for this application. How thick of material are you wanting to bend? I will pick some up and give it a try.
could have used these square dies a month ago... but i might have another project coming soon to justify buying the complete set...
thanks for making these
Troy, I have interest in a die set that would bend steel rods. I was wondering about 1 die with grooves for 1/2,3/8 and 1/4. Just wondering if there is enough interest in this and can it be done?
Thanks
366.7K members
