Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Who to calculate what CO spring rate you have
View Single Post
Old 05-03-2010, 01:43 PM   #6 (permalink)
SpineTx
SpineTx's Avatar
Member # 1499
Originally Posted by vetteboy79 View Post
You don't need to be that scientific about it.
Find something that you know how much it weighs, put it on the spring, measure the deflection.
Hell, put the spring in a doorway and stand on it yourself. Use the door frame to balance while someone else measures the spring. Good enough for a ballpark estimate anyway.
How far does it need to compress to get a somewhat accurate estimate. For example if I (220 lbs) stand on one of the 16 inch 2.5 spring it compresses about 1/2 inch. Does this mean its a 440 lb spring?
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote
