Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Who to calculate what CO spring rate you have
View Single Post
Old 05-04-2010, 02:33 PM   #12 (permalink)
SpineTx
SpineTx's Avatar
Member # 1499
Originally Posted by Triaged View Post
Next time use a dremmel and mark the spring rate on both ends before installing them...or just buy King springs because that is how they mark all theirs.
I bought these used and was told the spring rates were xxx, unfortunately when mounted one side sagged alot more than the other, after close inspection you could see that two springs were not the same. (the numbers were worn off when I got them)
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote
