Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Project f-runner
View Single Post
Old 03-07-2011, 08:17 AM   #16 (permalink)
MT4Runner
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
You're right, one is the motor, the other is the locked indicator.
IIRC, use the locked indicator to stop your relay.
SeaBass has two different schematics out there for rewiring the e-locker. One uses relays, the other doesn't.
I didn't use the relay one; just used a fuse and a 10A DPDT switch.
Originally Posted by crawled View Post
E lockers
One has the motor the other doesnt so I think im going to convert it to a cable. Should I convert both or run the motor? Also if i run the the motor what do I need for it? just switched power and a ground? the reason I ask is there is two plugs coming out of it. One has two wires I think thats just a sensor for the dummy light, but the other plug has five wires.
Help please
MT4Runner is offline   Reply With Quote
