What do you use? If it comes with a paper gasket do you use it? Do you add RTV to it? Do you just use RTV all together?
Did a timing belt/water pump on my parents e30 and the damn thing is leaking. Surface was 100% clean and I scrubbed it with some wheel wool. I'm kicking myself for not adding some RTV to the flimsy, thin paper gasket :mad3:
If the parts are new, clean and no pitting just a little blue Hylomar. Another replacement is 3-Bond. Sometimes called "Yamabond"
Its used when the surfaces are precision machined and you don't use a gasket. I would have used it in the application you described, and it would not leak)
If the surface is pitted, sees high temps or pressures I "upgrade" to High Temperature Anaerobic Flange Sealant. (Permatex)
Why not to use silicone?
1. It actually does not stick as well as you think it does.
2. Once cured, its "done". Any movement will cause it to "fail"
3. It can "Spit" the gasket under clamping force. (Its "Slippery, and can shear off the sealing surfaces)
4. You don't see silicone used to seal gasket surfaces on aircraft on in anything that "counts"
Do I have a tube of silicone in my trail box? Hell yes.. works great on sidewalls.. :flipoff2:
I do both sides of pretty much any gasket with Permatex non-hardening gasket sealant. I hate leaks & rarely get any gasket surfaces leaking if I do it this way. It is a royal pain to clean up though when you pull things apart....and its pretty much permanently on anything it gets smeared on.
ultra black rtv, if you prep it right the shit will need a a hammer and pry bar to get it off. any time i have a problematic area that is what i use, works great.
I use a skim coat on both mating surfaces of the gasket with the Permatex gray stuff meant for anti-freeze, otherwise I usually use the ultra black for everything else.
366.7K members
