Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Have you ever busted a H233B Rear Axle Shaft?
View Single Post
Old 08-02-2012, 09:51 AM   #128 (permalink)
Dion4x4
Member # 223518
Send a message via MSN to Dion4x4
I was able to break 1 y60 CV joint with 37 inch fedima sirocco tires in 3 years of extreme mudding.
The Y61 cv joint has been cut, to fit into the axle housing
Y61 housing vs Y60 housing, also bigger driveshaft mounts to fit the way bigger/stronger/heavyer drive shafts
Did not break a driveshaft or diff, but managed to break 3 transfer-case's.. The belt started slipping over the gears..
new one:
Weekly Updates!
Dion4x4 is offline   Reply With Quote
