Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - LQ4 LS throttle body questions
View Single Post
Old 09-14-2013, 11:23 AM   #6 (permalink)
Bo185
Bo185's Avatar
Member # 48545
First picture is the EVAP canister purge valve remove it and plug the hole its not need unless you need to pass emissions.
Second picture is your fresh air inlet for the PCV system should go to the pass side valve cover. You need this.
Third picture is the TB heater lines remove them and run the steam lines from the drivers head in to the top of radiator.
'73 IH Scout II Vortec 6.0L 4L65e np241
'73 IH 1210 Travelette SV392 V8, T34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote
