Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Glenn's build thread
View Single Post
Old 12-30-2013, 06:35 PM   #225 (permalink)
Glennwoudenberg
Member # 232365
made a little progress this weekend. I got the steering in. i used an ididit tilt column and a grant banjo wheel. I made a bracket for the dash out of 2" ID pipe and tapped it for a few set screws to hold it.
my gas tank is about 1/4" thick aluminum. if i drill and tap it to hold a ring to secure the fuel pump will the bolt holes leak gas? is teflon tape good enough to seal them or is there some other stuff I should use?
Glennwoudenberg is offline   Reply With Quote
