Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - After Market Injection - 4.6V8
View Single Post
Old 05-05-2014, 10:23 PM   #39 (permalink)
robertf03
Member # 161728
There was some confusion when I set up the original XDF that stuck through all the revisions, hopefully you didn't tune the limp mode which I intended to be map 0. Were you using the trace function in tunerpro? That could cause some confusion since it just looks for row and column, not map number. Response time was awful so I recommend sticking with rovergage.
I was only concerned with our NAS locked in map 5 and eventually I'll switch to the the green tune resistor map to see if I can squeeze a little more MPG out of it.
robertf03 is offline   Reply With Quote
