*FAQ* The Official PBB Suzuki BIBLE-updated DEC 20 2019
219K views 60 replies 38 participants last post by  supazuk94
#1 · (Edited)
FAQ TOPICS
General Suzuki Informaion
Models/Types
AXLE INFO INCLUDING SWAPS
AISIN HUB INFO
hub interchangeability
Aisin locking hub tech: Interchangeability, and converting Samurai lockouts to Toyota - Pirate4x4.Com : 4x4 and Off-Road Forum
How to tell which hubs these are - Pirate4x4.Com : 4x4 and Off-Road Forum
STOCK ZUK AXLE INFO
Killer 300M axleshafts
Zook 27spline axles and spool upgrade?
Dilemma: D44 vs. yota
TT Double Tough shafts =1, Grade 12.9 hub bolts = 0
newfield thread
zuk newfields - Pirate4x4.Com : 4x4 and Off-Road Forum
Lunch box locker tech
**FAQ- ZUK Lunchbox Locker tech** - Pirate4x4.Com : 4x4 and Off-Road Forum
Sidekick & Tracker Axles
-General Information
-What Gears can use on a Samurai
DANA AXLE SWAP INFO
FAQ - DANA axle swap info... - Pirate4x4.Com : 4x4 and Off-Road Forum
-Gears
-Steering
-Swap Information
-Links
TOY AXLE IN ZUK INFO
FAQ: TOY AXLE INFO <---HELP BUILD the FAQ - Pirate4x4.Com : 4x4 and Off-Road Forum
-Gears
-Steering
-Swap Information
-Links
fitting 30 spline longfields in toys
what tool for 30spline clearance? - Pirate4x4.Com : 4x4 and Off-Road Forum
toy FAQ
Official PBB Toyota FAQ {Last rev. 11/2007} - Pirate4x4.Com : 4x4 and Off-Road Forum
shaved trussed and armored axle collection (from toy forum)
Shaved, Trussed, and Armored Axle Collection - Pirate4x4.Com : 4x4 and Off-Road Forum
Toyota Front Axle Information & Specifications
FJ AXLE IN ZUK INFO
FAQ: Toyota Land Cruiser FJ60 axles into a Samurai. - Pirate4x4.Com : 4x4 and Off-Road Forum
-Gears
-Steering
-Swap Information
-Links
General Axle Swap Discussion
Danas vs. Toys - Pirate4x4.Com : 4x4 and Off-Road Forum
d44's vs. Toy's - Pirate4x4.Com : 4x4 and Off-Road Forum
(note maybe later we can summarize those threads here...pro/cons etc...)
-Electrical
T-CASE/TRANNY INFO
What tcase gears should I (or you) buy?
Samurai – How to set up a transfer case for 2WD-Low
SOS RingeR and Lucky 13 Adapters
RingeR: Zuk 1.6 Bell Housing to Toy transmission
Lucky 13: Zuk 1.3 engine to 1.6 Bell Housing
Shifter
Q. Shifter problems/can't put it IN a gear or remove it from a gear.
A. Start with the shifter sheet. To remove it push down on retaining ring and turn CCW. Then pull shifter up/out. See vender list for new sheets, ALL VENDORS HAVE NEW SHIFT SHEETS
Front output pilot bearing removal
Front output pilot bearing removal... - Pirate4x4.Com : 4x4 and Off-Road Forum
AUTO Tranny Stuff
TH180 Mods and Upgradesl
Volvo AW71 Transmission install
Higher stall converter with TH180
1.6 Tranny/Tcase Gear reduction Stuff
-Gearing Thoughts/Concepts..
Q. Which is better axle gearing or a t-case kit ?
A. While doing transfer case gears is probably the biggest bank for buck and a quick-fix, it is definitely a lousy way to try and create a reliable, trouble-free drive-train. Think about this for a minute... You put on larger tires. Now your pinion becomes TWICE as hard to turn. This puts TWICE as much stress on the u-joints, the transfer case mounts, the transfer case itself, and the brackets on the side of the frame that holds the transfer case in place. "GEE I wonder why I need these big honkin' driveshafts now"...or "why do my bolts pull out of the transfer case on the long arm side"... or the mounting boss breaks off of the transfer case....or the short arm side bracket starts tearing off of the frame rail. "Gosh - maybe it is because I gave my transfer case almost 3 times as much power by putting in 6:1's and now it wants to do flip flops in its mounts because I must have FORGOT to change the ring and pinions relative to my tire size - which would have made the drive-shaft easy to turn again and takes all of the strain off of these parts - like it was made from the factory when the little tires were on it." It is a MISTAKE to do all of your gear reduction at one point. Especially that far up the mechanical chain. Do yourself a favor...reduce the ratio at the ring and pinions relative to the size tire you want to run, then select the transfer case gears that will best meet your 4-wheeling needs. By going this route, you will have a well thought out and trouble-free drivetrain working well within the parameters of strain that the parts can and will reliably handle. -Brent (Trail Tough Products)
T CASE REBUILDS
Suzuki Tech | iZook - Suzuki 4x4 Tech Information, Accessories, Travel & Adventure
Trail Creeper 6.5 Samurai Gear Instructions
TWIN STICK TECH
my twin stick also found a shift boot! - Pirate4x4.Com : 4x4 and Off-Road Forum
Anybody want a twin stick? - Pirate4x4.Com : 4x4 and Off-Road Forum
Starting my twin stick mod, got a couple ?'s - Pirate4x4.Com : 4x4 and Off-Road Forum
http://xfaktor.net:8082/Projects/Suzuki/4.16TCase/4.16TCase.html#TwinStick
Suzuki Drive-shafts
Samurai driveshaft length info
Lengthening drive shaft how to
Lengthening drive shaft - Pirate4x4.Com : 4x4 and Off-Road Forum
Doubler FAQ
ZUK doubler FAQ - please help build this FAQ - Pirate4x4.Com : 4x4 and Off-Road Forum
So, another home made tracker range box.......... - Pirate4x4.Com : 4x4 and Off-Road Forum
Suzuki/Geo Doublers are here! (Sidekick to Dana 300)
ZUK ENGINES
Engine
Engine Swap Bellhousings
Suzuki 1.6L Engine Swap
MSD ignition install writeup
1.3 Engine
G series specs database
Suzuki G Series Engines - Wikipedia
List of Suzuki Engines - Wikipedia
-Pullys
Q. What pullies can I swap on?
A. Chevy Sprint 1.0L is a great swap, has stock water pump pully AND an overdrive for power steering, and other accessiries.
The 1.0L is also made by suzuki, so other vehicles with this or similer engines should work....
Acks 1.6 16v wiring
Cylinder Head Tech:
writeup on suzuki 8V cylinder heads and crankshafts, differences/similarities, and planimetric schematic of combustion chambers for determining how much to mill for desired compression ratio: The Facts on Suzuki Cylinder Heads! - Pirate4x4.Com : 4x4 and Off-Road Forum (more engine tech to be added eventually)
Ignition Tech:
wiring an MSD ignition box into your samruai with separate diagrams for common combinations of computer control hitachi or TBI, carbs/propane, factory tach or aftermarket tach: MSD ignition install writeup (by request) - Pirate4x4.Com : 4x4 and Off-Road Forum
Turbo Tech:
1.6 16 valve Junkyard 5 hour turbol
2000 2-door Tracker/Buggy w/1.5 16V and a turbo
More with multiple links
ZUK CARB INFO
Samurai dead (HELP PLEASE!) - Pirate4x4.Com : 4x4 and Off-Road Forum
VACUUM
-Alternator Upgrades
1.6 L Engine
link to team swifts 1.6 forum (need to build a better 1.6 FAQ)
TeamSwift • View forum - 1.6L Conversions & Overbored Motors
1.6 wiring FAQ
**FAQ Wiring for a 8V 1.6 ** - Pirate4x4.Com : 4x4 and Off-Road Forum
PROPANE INFO
PROPANE INFO
-1.3 TURBO
1.3 TURBO INFO
-16 VALVE PROPANE
16 VALVE PROPANE INFO
2.0 info
Vitara Engine Tech - two liter
2.0 Liter tach fix
2.0 swap in first gen track/kick
22r swap
My 22RE swap reposted. - Zukikrawlers
other 4 bangers
ecotec conversions
4.3
BRAKES
ZUK rear disks with nissan calipers and Firebird master
Master cylinder help
Mazda 929 Brake Master Cylinder Upgrade - BOLT ON!
Subaru master cylinder how to
Shuduck's Subaru master cylinder how to
Transfer Case Emergency Brake
STEERING INFO
biggest setup without power steering?
Full Hydro info:
zuk full hydro on the cheap - Pirate4x4.Com : 4x4 and Off-Road Forum
Full Hydro On A Budget... - Pirate4x4.Com : 4x4 and Off-Road Forum
Full Hydraulic Steering from Performance Off-Road Systems By BillaVista
Hydro assist:
Toyota hydro assist tech (courtesy of the Toyota FAQ)
Toyota power steering and ram hose diagram
Power Steering:
Toyota truck power steering pump bracket to 1.3 Samurai
What are you running for steering??
Howe power steering bleeding instructions
2.0-2.3-powersteering-options
suspension
Spring Length Chart
post up your 4 link lengths with some pics
linky linky every where (aka what rod ends do you run)
Link suspensions for dummies?
THE GOD OF SUSPENSION...[for those of you who don't know]
Suspension geometry for GETIN IT!
General
Weight list: engine, axles, t cases, etc.
IF ITS NOT IN THIS FAQ THEN YOU CAN FIND IT ONE OF THESE:
ACKS FAQ Ack's FAQ Suzuki Sidekick and Geo Tracker 4X4 offroading information
IZOOK: Suzuki Tech | iZook - Suzuki 4x4 Tech Information, Accessories, Travel & Adventure
OTHER FAQ's
PBB ZUK BUILD TABLE OF CONTENTS
Toyota FAQ
Chevy TOTW's
Ford TOTW's
Isuzu FAQ
Mercedes FAQ
The Official Pirate4x4.com Jeep Talk Bible Triaged's 4-link Analyzer / Calculator
Vendors
SUPORT THOSE THAT SUPORT THE BOARD!
Pirate4x4.Com : 4x4 and Off-Road Forum - Supporting Pirate4x4 Vendors
ZUK vendor list: (listed in no order, preference; Some do not support PBB) If you have a question about a product bug these guys, not the PBB (unless you bought something, and reviewing it for us).
Bumpers, Rock Sliders, Rocker Protection, Skid Plates, ShrockWorks
The Spidertrax Store
Welcome to the Trail Tough Products
Low Range Off Road
Hawk Suzuki Parts is now part of Low Range Off Road
Roadless Gear
Petroworks Off-Road Products
Rocky Road
Asian Auto Parts of Arizona
Wheelers Offroad
Davesport
Calmini
PRODUCT REVIEW THREADS
Product reviews - Pirate4x4.Com : 4x4 and Off-Road Forum
Sites Worthy of Mention
AZ Rockcrawler.com
SAMURAI WIKI
izook
ITEMS THAT NEED FAQS
if anyone has one PM your MOD
General Steering Stuff
Stock Steering
Power Steering
Spring Swaps
CJ spring swap FAQ
YJ spring swap FAQ
SEARCH TIPS
Search feature for three letter words
Search leaves out three letter words. If you want to search for IFS (or any other three letter or number combination), use an asterisk (*) like this: IFS* or *IFS. The search will use that as a wildcard.
USING GOOGLE TO SEARCH
If you DON'T have a red star you can not use the the search feature - you can either pay the $20/yr https://www.pirate4x4.com/forum/payments.php or use just use Google Advanced Search. Just put "www.pirate4x4.com" into the domain search field along with what you are looking for. For example to find info on 2.0 motor swaps, type into the google search field - "site: pirate4x4.com 2.0 motor swap".
I decided not to take away from "zukipuke's" (Yager) original FAQ thread, But edit out what was missing and outdated.
I figured it was best left similar for posterity. and since it links all the other FAQ's I unstuck all but this one. Feel free to PM me or reply to this thead or any other of the FAQ's as i will review them all and push all the best tech to the top.
-jay
#52 ·
great info
Maybe this will help, there is a "idle up" micro switch, and idle up "VSV" and some other vacuum/electric things that could be your problem. I know if you remove the vacuum hose from the "idle up actuator" The carb goes into warm up high idle instantly. Take a Look at these #7, #19, #22, #26, and #35. I am not sure if the thermal switches control the idle up or not, but they are worth looking at. Then again, with that high of an idle you could just have a major vacuum leak at the carb base, manifold, or PCV valve.
Hope the emission diagrams help
--Sky
More here
http://www.scribd.com/doc/20829612/Section-5-Emission-Control-System-Part-1
#53 · (Edited by Moderator)
I think condensing what is already there will make it easier start to see what is missing. All of this:
Can look like this:
General Suzuki Information
Wikipedia - Suzuki Samurai
izook history
Samurai specs
LWB Samurai dimensions
SWB Samurai dimensions
[edit] I just checked and the wikipedia link seems to be the only one of those that actually work[/edit]
All of this:
A. While doing transfer case gears is probably the biggest bank for buck and a quick-fix, it is definitely a lousy way to try and create a reliable, trouble-free drivetrain. Think about this for a minute... You put on larger tires. Now your pinion becomes TWICE as hard to turn. This puts TWICE as much stress on the u-joints, the transfer case mounts, the transfer case itself, and the brackets on the side of the frame that holds the transfer case in place. "GEE I wonder why I need these big honkin' driveshafts now"...or "why do my bolts pull out of the transfer case on the long arm side"... or the mounting boss breaks off of the transfer case....or the short arm side bracket starts tearing off of the frame rail. "Gosh - maybe it is because I gave my transfer case almost 3 times as much power by putting in 6:1's and now it wants to do flip flops in its mounts because I must have FORGOT to change the ring and pinions relative to my tire size - which would have made the driveshaft easy to turn again and takes all of the strain off of these parts - like it was made from the factory when the little tires were on it." It is a MISTAKE to do all of your gear reduction at one point. Especially that far up the mechanical chain. Do yourself a favor...reduce the ratio at the ring and pinions relative to the size tire you want to run, then select the transfer case gears that will best meet your 4-wheeling needs. By going this route, you will have a well thought out and trouble-free drivetrain working well within the parameters of strain that the parts can and will reliably handle. -Brent (Trail Tough Products)
Can just be linked to where it came from
Transfer case gears or axle gears? by Trail Tough
All of the links that are just a cut and paste of a link with a title above it can become one, so the title of the thread or website or whatever is the link itself. Same with the untitled ones. No need for all the http//:www.232432/131131blahblah.com This would reduce the length of the FAQ and still retain all the links and info
another example:
can be shortened to:
BRAKES
Most importantly
... ASIN ... pullys ...
are spelled AISIN and pulleys :flipoff2:
Later posts can be linked back to the first post
Engine specs and more
Torque specs
Capacities
Samurai SJ413 transmission and transfer case gear ratios
Samurai transfer case dimensions
Engine, axle, transmission, and transfer case WEIGHTS
Instead of cutting and pasting posts from other threads, just ad a link to them in the first post.
Examples:
post 51 could be linked from the original thread and added to the first post here
Samurai fuel line ID
as could post 52
Emissions / vacuum help
ok thats enough for now, i am tired, some actual new things to ad later :)
There always seems to be alternator questions, (plus it starts with an 'A' :D ), so here are a few links to start
GM alternator install
Mad Electrical - Alternator and electrical tech
This is a pretty new thread but the 4th post has some great info already Suzuki alternator info
what number alternator do I get?
Trail Tough GM alternator bracket, plus how to wire it
Not really sure what to categorize these as, but they are great threads for the newbies and old timers alike. There is definitely some overlap with a few, maybe they all shouldn't be included, but it is another starting point
*FAQ* PBB ZUK BUILD table of contents--HELP BUILD!
(I know thats already in the FAQ, but seems like it could go with the rest of these)
Pic's of zuk's
how long are you aka strech post your pics
The "Cleanest" Samurai out there?
Post a pic of your rig?
lets see ur flex!!
post pics of your favorite zuki's
I am partial to this thread :D, and would like to see it in the FAQ/Bible too
The tube door / half door thread
A few more links for the gearing section
Gear Ratio Calculator
Sidekick gear ratios
Tracker and Sidekick gear ratios
I'd also like to know what the actual driven/drive ratios are for all the different t-case gear sets, not just the 2XX% reduction in low, 20% in hi crap. Anybody counted teeth? Probably have to call some vendors to get the numbers
and a few good links for steering
#54 ·
Suzuki Driveshafts
Key Search Words: Stock 1991 Suzuki zuke zook zooki Samurai sammy front driveshaft drive shaft measurement length including slip yoke ....All of these are only to be considered "Ball Park" - UZi9mm
All figures include both u-joints and flanges, flange mounting surface to flange mounting surface unless stated otherwise.
-Fully collapsed compressed: 27.25"
-Fully extended, with the slip yoke and drive shaft physically touching but
NO spline engagement: 31.25"
1" of splined engagement: 30"
2" of splined engagement: 29"
3" of splined engagement: 28"
3.75" of splined engagement is maximum engagement (now back at full compression)
Note:
The slip yoke has aproximately .25" inside it's end that has a non splined section. (the outside of this area is the groove where the stock rubber dust boot attaches)
The drive shaft splined section itself, has a smooth shoulder at it's base of about .50", where it meets the face of the tube. (so total splined section is 3.75" , total length of the "stub" inc. shoulder and splines is aprox. 4.25")
Drive shaft without slip yoke, but with flange and u-joint, from spline face to flange mounting surface: 24"
Drive shaft alone with no flange or u-joint, splined face to yoke ends: 23.25"
Slip yoke alone without flange or u-joint, from dust boot end face to yoke ends : 6.25"
Yoke ears
Outside width : 2.75"
Inside width : 1 & 5/8th's
Thickness : .50"
Length : 2"
Flange mounting surface thickness: 5/16th's
Flange ("large" style, late model Samurai) mounting holes centre to centre : 60mm x 60mm Diagonally: 85mm
Tube diameter: 2"
#56 ·
*FAQ* The Official PBB Suzuki BIBLE-updated MAY 02 2011
Well I have been on here for a bajillion years, and think I found my first useful bit of knowledge to share here. One of the biggest questions I hear from two liter people is how to make the tach work with the old cars. Well its pretty cheap and simply, just need some soldering skills. All you have to do is open the tach up and replace a resistor with the right value, and blamo! Working tach. See below...
This first picture show the critter you need to replace
And replace it with a 24K ohm resistor
And here is a crappy picture I took with just the marker lights on, it works all the way to 6500 rpm.
So there you go, any questions just ask.
Matt
#57 ·
Just a lil tidbit I have to throw in. 1996-2000 honda civic front brake hoses for soa lift or 3-4" lift, they are about 6-7" longer than factory and bolt right up, you need to modify the factory frame mount for the female hose end a lil to get the clip in. 1988-1995 may fit too, I haven't checked yet, 1992-1995 should be the same.
#59 ·
My Birfields needed replacing on my 85 which of course is a narrower diff width,As i could not find replacements in that width, i bought new axles in the wider width (inner and outers )which comes with new birfields.I replaced the new inner which is where the extra length was added and installed my inners which were fine.
#60 ·
I cut and pasted the first post but there is more with pics in the thread:
https://forum.suzukiclubuk.co.uk/viewtopic.php?t=2801
Quick linksFAQLoginRegisterSCUK Main Site
Suzuki Club UKHome of all things Suzuki 4x4Skip to content
Forum HomeMaintenance and Tech (Click here for stickies)SJ series Transmission, Axles, Brakes, wheels and tyres.
Search…
SJ axle info
Search this topic…
13 posts 1
User avatarScottieJ
The Boss
The Boss
SJ axle info
Post by ScottieJ » Fri Feb 25, 2011 1:27 pm
Thought I'd start a post detailing lots of info about and the specs of suzuki axles, I will be adding to it in time but if you have anything you would like to add please post it up :mrgreen: (I'm sure Darrell will have some useful diagrams ;) )
Pretty much all external components on SJ axles are interchangable i.e. Stub axles, hubs, swivels, seals, bearings, freewheeling hubs. Internal components differ between the 410/413 and Samurai axles i.e. diffs, axle shafts and CV's are not always interchangable.
Ratios & diff interchangability
410= 4.11:1 (37crown wheel > 9pinion)
LJ 80= 4.56:1
Front are 22spline and rears are 26spline.
410 and lj80 diffs are direct swaps although on late SJ410's the bolt spacing on the diff flanges for the props is different
LJ80s and skinny prop SJ410s (upto 84) are 50mmx50mm with 8mm bolts
Later fat prop (85 onwards) SJ410s are 56x56mm with 8mm bolts
413= 3.909:1 (43 crown wheel > 11pinion)
Samurai= 3.727:1 (41 crownwheel > 11 pinion)
413 and Samurai diffs are direct swaps Although some Samurai's built from 1990 onwards have a larger bolt spacing on the diff flanges.
up to 89 56x56mm with 8mm bolts
Later models from around 94 onwards are 60x60mm with 10mm bolts
SJ410 & lj80 diffs are smaller than SJ413& Samurai diffs so you cannot swap them.
You can fit Vitara and early GV FRONT ring and pinions into 413 and samurai diffs, the available ratios are as follows.
Vitara
swb manual=5.125:1 unless it's a later model 4u/4u2 etc then they have 4.875:1
auto=4.6:1 or 4.3:1 depending on transmission.
commercial & lwb= 4.88:1
Grand Vitara (to the best of my knowledge)
98-05 G16 manual and Auto= 5.125:1
98-05 J20a manual= 4.875:1 auto= 4.875:1 or 5.125:1
98-05 H25a manual= 4.3:1 auto= 4.875:1
01-03 XL7 H27a manual= 4.3:1 auto= 5.125
03-05 XL7 H27a manual= 4.3:1 auto= 4.3:1
98-00 RF 2.0 diesel manual= 4.3:1 auto= 4.3:1
00-03 RHZ 2.0 diesel manual= 3.909:1 auto= 4.3:1
04-05 RHW 2.0 diesel manual= 3.909:1 auto= 4.3:1
Front 22spline Vitara diffs are a direct bolt into Samurai/413 axles but if it is an alloy diff it is best to swap the ring and pinion into a steel Samurai/413 diff. Rear diffs are larger and do not fit Samurai/413 axles.
Axle widths
(all dimensions are wheel mounting surface to wheel mounting surface)
Samurai front= 1333.5mm (52.5") rear=1326mm (52.2")
410/413 front= 1232mm (48.5") rear=1224mm (48.2")
Jimny front= 1355 mm Rear= 1365 mm
Spring perch spacing width
(spring locating hole centre to centre)
Samurai front=720mm(28.34") rear= 950mm(37.4")
410/413 front=640mm(25.2") rear=870mm(34.25")
To fit samurai axles onto a 410/413
Each front & rear perch needs to be moved 40mm inwards.
Bearings & Seals
King pin bearings
15x42x14.25 metric taper roller bearing 30302
Front wheel bearings
LM 3008 49 inner/LM 3008 11 outer
41 x 68 x 17.5mm
Seal should come in the bearing kit fram any motor factor
if desperate could try a 50x68x7mm oil seal but it doesnt have the extra lip to keep the crap out.
Rear wheel bearings
Suzuki part numbers
Bearing 09269-35009 (bearing code DG357222DW)
Bearing retainer 43485-73000
Oil seal 09283-48007
Spacer (not needed if bearing above is used) 43429-77201
From bearing supplier
Bearing 6207-2RS 35x72x17mm (you will need a 4mm spacer ^^^^)
Oil seal is 48x62x8mm
From motor factors:
SKF Kit = VKBA1972
Front halfshaft oil seal
26x38x8mm
knuckle seals, main stealer part numbers
# 45623-80001] 4x Oil Seal Retainers.
# [09285-00002] 2x Oil Seals.
# [45600-82810] 2x Felts (come in pairs).
# [45625-63001] 4x Oil Seal Covers.
Kits available from singapore on ebay
http://stores.ebay.com/mantra4x4/Axle-P ... 34.c0.m322" onclick="window.open(this.href);return false;
Other front axle info, useful diagrams
Axle Shaft Diameter
Front: 23.87mm (.940")
Rear: 26.67mm (1.05")
Axle Tube Material: HREW
Diameter:65mm (2.56")
Wall Thickness: 3mm (.120")
axle info.JPG (70.01 KiB) Viewed 51117 times
Zuki Build
