Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Has anyone ever revived a burnt engine?
View Single Post
Old 02-15-2002, 04:00 AM   #4 (permalink)
CRO
Member # 7588
Re: Has anyone ever revived a burnt engine?
Originally posted by Sundance
I have salvaged 2 fords that were burnt and I was wondering if anyone has had any sucess reviving burnt motors?
one is a 1997 7.3 Powerstroke and the other is a 1992 5 litre injected Windsor the fires were hot enough to melt alloy.
Obviously they will have to be stripped and all the seals, hoses, alloy bits replaced but is there anything else to consider?
If the fire was hot enough to melt aluminum. I would be suspicious of any steel parts that were hardened.. .
sustained high temperatures are just the thing to anneal the hardness from things like valve seats,pushrods,rockers, etc.
I would also be suspect of any alloy bolts (head bolts)
The cast iron was not likely affected but I would send the fuel pump in (on the diesel) because those are super big $$$$$ to repair.........
But you don't want to buy an engine from the parts department one piece at a time...........
1948 Willys
1952 M37CDN Powag
CRO is offline   Reply With Quote
