Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Ecoboost Maintenance
View Single Post
Old 11-28-2015, 06:14 PM   #13 (permalink)
Jeepermat
Member # 67907
Originally Posted by IDASHO View Post
Regardless of application if you are removing the plugs for ANY reason, you may as well replace them. They are cheap insurance. Just the act of removing them may damage them.
And you have already performed the labor of removing them, so replace them.
Not to mention the factory spec's intervals. Even your 6.0 should have a factory spec'd spark plug change at 80-100k
Most DOHC V6's spark plugs are typically 60k or so.
And before you say "they are still fine at 200+K miles" again...
They are not.
The rig may run "fine" but it isnt running as designed.
Im curious what on the plug is worn out? They gap to new specs, the electrode has not appeared to wear at all.
The Beepster
Jeepermat is offline   Reply With Quote
