Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - How To Deal With LiPo Batteries Safely; Knowledgeable Ones Please Entre'!
View Single Post
Old 01-04-2016, 08:21 PM   #14 (permalink)
makya
Apple
makya's Avatar
Member # 41250
Originally Posted by 87manche View Post
I always charge at 1c.
I dont give a shit if the battery manufacturer says it will go 5.
1c is the best for battery life.
I also only charge at 1c. 1c means charging at the same rate as the battery is listed for, so a 5000mah battery can be charged at 5 amps and will be charged in an hour. I also charge and store my batteries in Ammo Cans.
If you decide you want to charge faster than that, MAKE SURE that the battery is rated to charge at a higher rate. It will be posted somewhere on the battery or in the documentation that comes with the battery, saying it can be charged at 2c, or higher. 2c x 5000mah battery= 10 amps, so 5c x 5000mah = 25 amps. the math is easy to do.
ALWAYS USE A LIPO BAG, OR OTHER FIREPROOF CONTAINER! That is the biggest and most common mistake I see happen, and what caused the fire to spread so quickly in Lance and Renee's RV. It's also what caused a big fire in a hobby shop I used to frequent in Carrollton Tx.
Here's what happens when you get a lipo fire in a structure:
makya is offline   Reply With Quote
